All KLARUS deals request replied.
Lumintop GT mini XPL HI 1200LM Stepless Dimming in CW/ NW 18650 LED Flashlight - $39.69 /// Coupon: AC18 /// Proceed to Store
FireFlies ROT66 Aux LEDs option and more lights coming soon.
$124.40 | Code: BLF
$33.20 | Code: BLF
$39.64 | Code: BLF
$21.24 | Code: BLF
$24.99 | Code: BLF
$38.83 | Code: BLF
$57.20 | Code: BLF
LUMINTOP BLF GT70, GT, GTmini!!!
VALID TILL Sep 20, 2018
$179 | Code: 3A54D0
$32 | Code: Ab8A87
$33 | Code: 68125B
$27 | Code: A35A34
$52 | Code: 705589
$22 | Code: F36584
$17 | Code: C1E42C
Interested in Ti Pen
$179 | Code: 3A54D0
$32 | Code: Ab8A87
$33 | Code: 68125B
$27 | Code: A35A34
$52 | Code: 705589
$22 | Code: F36584
$17 | Code: C1E42C
$29 | Code: 9F1297
$24.95 | FLASH SALE
$29.95 | Code: BC2D4F
$19.95 | FLASH SALE
$79.95 | FLASH SALE
$79.95 | FLASH SALE
$175.2 | Code: 7A3E05
$20.89 | FLASH SALE
$17.99 | FLASH SALE
$49.99 | FLASH SALE
$36.95 | Code: Pro
$18.99 | Code: Pro
$18.99 | Code: Pro
$11.95 | Code: Pro
$14.5 | Code: Pro
Curious about the TiPen Thank you.
We will work on Ti pen after 12th Anniversary sale.
Invalid coupon for S70S
Sorry, ThorFire promotion for 12th Anniversary has ended.
moved.
$22.83 | Code: GOLDEN
$23.99 | FLASH SALE
$55.08 | Code: GOLDEN
$61.62 | Code: GOLDEN
Hi Freeme,
Is there any chance to get this code for the Nitecore Concept 1 from your webpage alive again? Gearbest offers the Concept 1 but the code from your website does not work.
Cheers, Thomas
[AliExpress - Flash Sale] Sofirn New C8F 21700 Version Powerful LED flashlight Triple Reflector Cree XPL 3500lm Super Bright Torch with 4 Groups Ramping
Price: $30.93 ( usual $41.16 )
Coupon: Store promotion - additional USD$2 OFF (>$25 order).
Store: http://s.click.aliexpress.com/e/KmQ486k
Specification:
- 3* CREE XP-L LED with a lifespan of 50,000 hours
- Working Voltage: 2.8V-4.2V
- Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery(Suggest 21700 battery)
- Dimension: 149mm (length)*44.6mm (head diameter)
- Weight: 200±2 gram (without battery)
- Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
- Toughened mineral glass lens with AR coating.
- IPX8 Waterproof (submersion up to a maximum depth of 1.5 m underwater for up to 30 minutes).
- Reverse polarity protection from improper battery installation.
- Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating.
- Power Indicator:
- The LED indicator on side switch blinks in green for 5 seconds when turns on.
- LED indicator is Steady Green if the voltage is between 3.4 volt to 4.2 volt.
- LED indicator is flashing Red if the voltage is between 3 volt to 3.4 volt.
- LED indicator is rapid flashing Red if the voltage is between 2.8 volt to 3 volt.
- The flashlight turns off automatically if the voltage is lower than 2.8 volt. Please insert new battery.
