Lumintop GT mini XPL HI 1200LM Stepless Dimming in CW/ NW 18650 LED Flashlight - $39.69 /// Coupon: AC18 /// Proceed to Store
FireFlies ROT66 Aux LEDs option and more lights coming soon.
NITECORE Concept 2 6,500lm LED Flashlight
$124.40 | Code: BLF
$124.40 | Code: BLF
NITECORE LR12 XP-L HD V6 1000lm Flashlight
$33.20 | Code: BLF
$33.20 | Code: BLF
NITECORE MT21C L-shaped 1000lm LED Flashlight
$39.64 | Code: BLF
$39.64 | Code: BLF
NITECORE TINI Copper XP-G3 380lm Keychain Flashlight
$21.24 | Code: BLF
$21.24 | Code: BLF
NITECORE TIP Copper XP-G3 360lm keychain LED
$24.99 | Code: BLF
$24.99 | Code: BLF
NITECORE GEM10UV Gem Identification Flashlight
$38.83 | Code: BLF
$38.83 | Code: BLF
NITECORE MT42 XHP35 HD 1800lm 2x18650 Flashlight
$57.20 | Code: BLF
$57.20 | Code: BLF
LUMINTOP BLF GT70, GT, GTmini!!!
VALID TILL Sep 20, 2018
LUMINTOP BLF GT 2000lm 2km CW/ NW Flashlight - Light Alone
$179 | Code: 3A54D0
$179 | Code: 3A54D0
LUMINTOP BLF GT mini XPL HI 1200lm Flashlight
$32 | Code: Ab8A87
$32 | Code: Ab8A87
LUMINTOP EDC25 XP-L V5 1000lm Flashlight
$33 | Code: 68125B
$33 | Code: 68125B
LUMINTOP TD15S XM-L2 U2 1000lm Flashlight
$27 | Code: A35A34
$27 | Code: A35A34
LUMINTOP ODL20C XHP35 2000lm Flashlight
$52 | Code: 705589
$52 | Code: 705589
LUMINTOP EDC05 XP-L 800lm Flashlight
$22 | Code: F36584
$22 | Code: F36584
LUMINTOP Copper Tool XP-G2 110lm
$17 | Code: C1E42C
$17 | Code: C1E42C
Interested in Ti Pen
$179 | Code: 3A54D0
$179 | Code: 3A54D0
$32 | Code: Ab8A87
$32 | Code: Ab8A87
$33 | Code: 68125B
$33 | Code: 68125B
$27 | Code: A35A34
$27 | Code: A35A34
$52 | Code: 705589
$52 | Code: 705589
$22 | Code: F36584
$22 | Code: F36584
$17 | Code: C1E42C
$17 | Code: C1E42C
ASTROLUX S43 4* XP-G3/ 4*Nichia 219C 2100lm
$29 | Code: 9F1297
$29 | Code: 9F1297
ASTROLUX S42 4* XP-G3/ 4*Nichia 219C 2023lm
$24.95 | FLASH SALE
$24.95 | FLASH SALE
ASTROLUX S42S 4* XP-G3/ 4*Nichia 219C 2023lm
$29.95 | Code: BC2D4F
ASTROLUX C8 XP-L HI 1300lm
$19.95 | FLASH SALE
$19.95 | FLASH SALE
ASTROLUX MF02 XHP35 HI 3000lm
$79.95 | FLASH SALE
$79.95 | FLASH SALE
ASTROLUX MF01 18*XP-G3/ 18*Nichia 219C 12000lm
$79.95 | FLASH SALE
$79.95 | FLASH SALE
ASTROLUX MF04 XHP35 HI 2700lm
$175.2 | Code: 7A3E05
ASTROLUX S1 XP-L 1600lm
$20.89 | FLASH SALE
$20.89 | FLASH SALE
BLF A6 XP-L 1600lm
$17.99 | FLASH SALE
$17.99 | FLASH SALE
BLF Q8 4*XP-L 5000lm
$49.99 | FLASH SALE
$49.99 | FLASH SALE
ThorFire S70S XHP70 3960lm 26650 Flashlight
$36.95 | Code: Pro
$36.95 | Code: Pro
ThorFire C8s XM-L2 900lm upgraded
$18.99 | Code: Pro
$18.99 | Code: Pro
ThorFire TK18 XP-L2 1200lm Stepless KIT
$18.99 | Code: Pro
$18.99 | Code: Pro
ThorFire TG06S XP-G2 500lm 14500/AA Flashlight
$11.95 | Code: Pro
$11.95 | Code: Pro
ThorFire TK15 XP-L2 1050lm Flashlight
$14.5 | Code: Pro
$14.5 | Code: Pro
Curious about the TiPen Thank you.
We will work on Ti pen after 12th Anniversary sale.
Invalid coupon for S70S
Sorry, ThorFire promotion for 12th Anniversary has ended.
moved.
NITECORE TINI SS XP-G3 380lm Keychain Flashlight - Tropical
$22.83 | Code: GOLDEN
NITECORE TINI SS XP-G3 380lm Keychain Flashlight - Black
NITECORE TINI SS XP-G3 380lm Keychain Flashlight - Glacier
ASTROLUX S41 4* XP-G3/ Nichia 219B 1600lm
$23.99 | FLASH SALE
$23.99 | FLASH SALE
NITECORE P12GTS XHP35 1800lm Flashlight
$55.08 | Code: GOLDEN
NITECORE EC4GTS XHP35 1800lm Flashlight
$61.62 | Code: GOLDEN
Hi Freeme,
Is there any chance to get this code for the Nitecore Concept 1 from your webpage alive again? Gearbest offers the Concept 1 but the code from your website does not work.
Cheers, Thomas
[AliExpress - Flash Sale] Sofirn New C8F 21700 Version Powerful LED flashlight Triple Reflector Cree XPL 3500lm Super Bright Torch with 4 Groups Ramping
Price: $30.93 ( usual $41.16 )
Coupon: Store promotion - additional USD$2 OFF (>$25 order).
Store: http://s.click.aliexpress.com/e/KmQ486k
Specification:
- 3* CREE XP-L LED with a lifespan of 50,000 hours
- Working Voltage: 2.8V-4.2V
- Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery(Suggest 21700 battery)
- Dimension: 149mm (length)*44.6mm (head diameter)
- Weight: 200±2 gram (without battery)
- Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
- Toughened mineral glass lens with AR coating.
- IPX8 Waterproof (submersion up to a maximum depth of 1.5 m underwater for up to 30 minutes).
- Reverse polarity protection from improper battery installation.
- Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating.
- Power Indicator:
- The LED indicator on side switch blinks in green for 5 seconds when turns on.
- LED indicator is Steady Green if the voltage is between 3.4 volt to 4.2 volt.
- LED indicator is flashing Red if the voltage is between 3 volt to 3.4 volt.
- LED indicator is rapid flashing Red if the voltage is between 2.8 volt to 3 volt.
- The flashlight turns off automatically if the voltage is lower than 2.8 volt. Please insert new battery.
TI Pen please
