The bio-direction clip makes the flashlight a caplamp or pen light, Tank007 official website is written like this.
I’ve read that. Question remains: is the body reversible? Because there is only ONE groove for the clip.
This clip is bidirectional, which means that the grooves at the head and tail are all available as clips, so that the body don't need to reverse. I think this sentence should mean this although I don't know if this is feasible.
The Fenix CL23 is the first multi-directional camping lantern from Fenix. It provides impressive power, with a max output of 300 lumens. This new camping lantern is powered by 3 AA batteries, however, in emergency situations it can be powered by 1 or 2 AA batteries. Featuring compact size and a light weight, the lantern not only delivers the needs of campers but also satisfies backpackers' requirements. The multi-directional design is great for both camping outside or for inside of your tent. With good-looking appearance, IP66 rated protection and multiple ways of wearing, the CL23 will make for a stylish and more enjoyable outdoor life.
Main Parameters:
Output Modes: 3+ brightness levels, red laser
Beam Diameter: Max 20 meters
Impact Resistant: 1 meters
Light Source: LED bulbs
Compatible Batteries: 3 x AA
Product Certifications: IP66
Brightness Levels and Runtime:
High : 300 Lumens/7.5 hours
Med : 150 Lumens/13 hours
Low : 40 Lumens/ 45 hours
Down-1 : 2 Lumens/350 hours
Down-2 : 25 Lumens/80 hours
Red Light : 1 Lumen/150 hours
Red Flash : 1 Lumen/300 hours
Product Features:
● Compact and fashionable, max 300 lumens
● Powered by 1, 2, or 3 AA batteries
● Multiple-direction lighting for camping and tent lighting
● 65.5 ft./20-meter beam diameter
● Dual lighting sources - white and red
● Reverse polarity protection to protect from improper battery insertion
● Top positioned tripod socket for effective light directional control and fastening
● One-switch control for easy and fast operation
● IP66 rated protection (dustproof and waterproof)
The CL23 is available in 2 colors: vibrant red and fresh green at GearVita.com. With it you will always be ready for adventure: https://gearvita.com/fenix-cl23-compact-camping-lantern-300-lumens.html
Related product:
https://gearvita.com/supfire-t1-waterproof-rechargeable-outdoor-camping-lamp.html
The Fenix LD05 V2.0 flashlight is a easy to use dual lighting source penlight with warm white light and UV lighting also. The all new Fenix LD05 V2.0 uses a 90 CRI CREE XQ-E HI LED and a 365nm UV LED. Operating the Fenix LD05 is simple, the stainless steel tail switch controls all three warm white light outputs and the UV light output. A single click turns the Fenix LD05 on, and half clicks allows you to increase the outputs. The Fenix LD05 V2.0 is powered by two AAA batteries which deliver an amazing 100 Lumens of output. This light is perfect for doctors and dentists as well as helps with medical inspections in low-light areas, the powerful UV light also provide easy detection of counterfeit currency.
Main Parameters:
LED Type: Cree XQ-E HI LED (90-CRI / 3000K warm white)
Battery Type: AAA
Switch Mode: High / Medium / Low
Max Lumens: 100
Lighting Distance: 50-100m
Max Beam Intensity: 730 cd
Beam Color: 3000K warm white / UV
Waterproof and Submersible: IP68 / underwater 2m
Impact Resistant: 1m
Max Run Time: 70h (Alkaline batteries)
High - 100 lumens ( Alkaline Battery - 1 hr 40min / Ni-MH Battery - 2 hr 10min )
Mid - 25 lumens ( Alkaline Battery - 7 hr 50min / Ni-MH Battery - 6 hr 40min )
Low - 5 lumens ( Alkaline Battery - 70 hr / Ni-MH Battery - 36 hr )
UV Light - 200mW ( Alkaline Battery - 9 hr / Ni-MH Battery - 7 hr )
Product Features:
● 90 CRI CREE XQ-E HI LED with a lifespan of 50,000 hours
● Fitted with 365nm/200mW UV light
● 100 lumen output of warm white light
● Powered by two AAA batteries
● Digitally regulated output maintains constant brightness
● Color temperature of 3000K
● Color rendering index of 90
● Tail switch for one-handed activation and output selection
● Made of durable high-strength and oxidation-resistance aluminum and stainless steel
● Soft smooth beam
● Premium type HAIII hard-anodized anti-abrasive finish
● Stainless steel pocket clip
● Optimal quality optical lens
● IP68 rated waterproof, can submerse to 2 meters/6.5ft for 30 minutes
The versatile portable penlight like Fenix LD05 V2.0 is essential in our daily lives. Get it from GearVita today, let it be a part of your life, you will find your life much more convenient than before: https://gearvita.com/fenix-ld05-v2-0-led-penlight-100-lumens-with-uv-lighting.html
Related product:
https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
The Acebeam PT10 penlight is ideally meant for use by Law Enforcement professionals, mechanics, and as a general-use EDC, due to its small size and bright output. This handheld flashlight, though it measures just over five inches long, which is about the same as an average-sized pen, offers an incredible 360-lumen High mode. Compare that with other 2 x AAA penlights and you'll quickly see that the Acebeam PT10 is clearly the brightest of the bunch! This LED penlight is equipped with a Cree XPL-HD LED, which delivers the latest in illumination performance and efficacy. Over time, Cree has developed and optimized their lamps to deliver the most amount of lumen output from the smallest-sized lamp possible. The Acebeam PT10 runs on two AAA batteries, which power the LED penlight for approximately 48 minutes, when in High mode. If longterm use is your focus, you'll be happy to learn that this flashlight can run for 10 hours in Medium mode (30 lumens) and up to 36 hours in Low (3 lumens).
Main Parameters:
LED: CREE XP-L HD W2 high density LED with a lifespan of 50,000 hours
Max Output: 360 lumens ( 2*AAA NiMh or Alkaline battery )
Peak Beam Intensity: 1046cd
Max Beam: 65 meters
Compatible Batteries: 2 x AAA
Working Voltage: 0.9V - 3.0V
Impact Resistance:1.2 meters
Waterproof: IPX-8 standard
Mid: 30 lumens ( 10 hours )
Low: 3 lumens ( 36 hours )
High: 360 lumens ( 0.8 hours )
Product Features:
● Durable aircraft grade aluminum construction.
● Premium Type III hard-anodized anti-abrasive finish.
● Toughened ultra-clear glass lens with anti-reflective coating.
● Copper base plate for more efficient heat distribution.
● Orange-peel reflector broadens the beam throw.
● Tail switch on/off push button for one-handed operation.
● Capable of standing up securely on a flat surface to serve as a candle.
There are three colors for options on GearVita - black, silver, and gold. With a small gift-wrapped package box, PT10 is an ideal gift for you to send your family, friends, customers, etc. if you are looking for a compact pen style light that can be used for first aid, other medical and EDC: https://gearvita.com/acebeam-pt10-led-penlight-360-lumens.html
Related products:
Acebeam M20 flashlight may not be the biggest, but it is a high-powered keychain flashlight and lives up to Acebeam's legacy of quality products. Featuring a CREE XPG3-S5 LED and powered by a single AAA battery, this diminutive dynamo can produce up to 150 Lumens of incredible light output. An intelligently designed and highly efficient printed circuit board improves the performance of the equipment and maximizes its operating time, automatically providing protection against damage caused by high temperatures. By twisting the light head, you can select middle, low and high three unique lighting modes rapidly that can adapt to indoor or outdoor use. With the included keychain mount the Acebeam M20 can be hooked to any set of keys or even clothing for a portable hands free carry, it is your ideal partner whenever and wherever you need light.
Main Parameters:
LED: CREE XPG3-S5
Power Source: 1 x AAA
Working Voltage: 0.9 - 1.5V
Max Output: 150 lumens
Max Runtime: 25 hours
Peak Beam Intensity: 628cd
Peak Beam Distance: 50 meters (164 ft.)
IPX Rating: IPX-8 waterproof (2 meter submersible)
Impact Resistance: 1.2 meters (3.9 ft.)
High: 150 lumens ( 0.8 hours )
Medium: 30 lumens ( 4 hours )
Low: 2 lumens ( 25 hours )
Product Features:
● Use CREE XPG3-S5 LED light temperature of 6500K, maximum brightness of 150 lumens, maximum intensity of 628cd, wide beam of 50m, LED life of 50,000 hours.
● Crafted from durable, lightweight aircraft grade aluminum.
● Premium type III hard-anodized anti-abrasive finish is hard-rusted, heat-resistant.
● 2mm toughened ultra-clear glass lens with anti-reflective coating reduces glare, provides 98.3% light transmission evenly at all brightness levels.
● Special gold-plated contact system for maximum power impact strength of 1.2m.
● Waterproof to IPX-8 standard at 2 meter depth.
● Copper base plate for efficient heat management.
● Moderately texturing finished reflector disperses light for a smooth, even beam.
● High-performance circuit design, low power consumption, voltage 0.9 - 1.5V, use AAA alkaline batteries.
● The ability to stabilize the flashlight on a flat surface to fulfill the role of a candle.
A flashlight on your keychain can be negligible but until you suddenly need light in a dark room, on the side of the road, etc, you will thank its great role. Acebeam M20 is such a keychain flashlight that is inconspicuous but can play a huge role at a critical moment. It is available in three colors on GearVita, including black, brown, and silver. If you're looking for a daily use flashlight with powerful capabilities and a long service life, as well as the smallest possible size, it will be an invaluable companion for you: https://gearvita.com/acebeam-m20-led-flashlight-150-lumens.html
Related products:
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
The Tank007 F2 flashlight is a great practical light with special feature of double LEDs for both white light luminating and UV light. There are one white high power 3W LED and one high power 1W UV LED in its head. The maximum white LED output is 160 lumens and the range is 130m and the UV LED operates at a wavelength of 365 nm. The white light is used for portable lighting and the UV light is used for fluorescence detecting, application mainly in banking, police, metallurgy, jewelery, antiques, etc.
The exception of the Tank007 F2, except for the use of 2x LEDs, is that it is focussed and very small dimensions. The luminaire features a simpler focusing (zoom optics), and with one finger in a second, you change the light beam scatter. There is an aspherical lens in the head. By shifting the head, the light cone can be concentrated to a small square to achieve an excellent long-lasting lighting to light far distance, or extend the light cone into a very wide, uniformly illuminated circle without focus, which is suitable for illuminating the wide space in the vicinity. Control of the lamp is secured by the rear switch. Using a hanging clip, you can hang the light on your pants pocket, the shirt pocket.
Main Parameters:
White Light:
- LED: high power 3W LED
- LED Lifespan: above 50,000 hours
- Max Brightness: 160 lumens
- Max Beam Distance: 130m
UV LED:
- Power: high power 1W UV LED
- Wavelength: 365nm
- LED Life: 10,000 hours
Power Source: 1 x AA alkaline or NI-MH battery
Burn Time: 0.7 hours
Modes: Two modes ( white light LED and UV LED )
Input Voltage: 0.8 - 3.0V
Lens: Glass convex lens
Impact Resistance: 1.5m
Waterproof: IPX-7
Product Features:
● Adjustable Focus
It can be focused and zoomed, concentrate light to light far distance and cover large space with flood light.
● Portable Design
Small size with metal pocket clip, easy to carry.
● Convenient Power Source
Powered by one ordinary 1.5V AA battery or NI-MH battery, which are easy to get.
● Tail Button Switch
Designed with the button switch on the tail, easy to operate making it have tactical feature.
● Wide Application
This flashlight has double LEDs, with both white light and UV light. Its UV light can be used but not limited to:
- Counterfeit and banknotes distinguishing
- Fluorescent agents in various clothes and commodities detection
- Fluorescent reflection of special materials detection
Thanks to white and purple double light source, it is multi-purpose, really practical. With it, some small problems in life can be readily solved, come to GearVita to get it now: https://gearvita.com/tank007-f2-double-led-flashlight-160-lumens.html
Related products:
https://gearvita.com/tank007-uc17-usb-rechargeable-flashlight-800-lumens.html
https://gearvita.com/tank007-pa01-pocket-led-flashlight-90lm.html
Tank007 TC18 flashlight is a high power and brightness multi-functional rechargeable LED flashlight. It is powered by 3 AAA battery or 1 x 18650 rechargeable battery and features focusing, directly charging, and magnet and is designed and manufactured according to Chinese police flashlight standard, best for military, police, outdoor searching and rescuing, camping, vehicle and machines maintenance and repair. The flashlight is with a 350 lumen output and 400 meter range is focused. It has three flash and two flash modes, the battery can be charged directly in the lamp body. It also can be used as a backup power source with a charged battery.
Main Parameters:
LED: Cree XP-E2
LED Lifespan: Above 80,000 hours
Max Brightness: 350 lumens
Throw Beam: 300m
Input Voltage: 3.0 - 4.5V
Output Level: 5 modes (High-Medium-Low-Strobe-SOS)
Power Source: 1*18650 Li-ion batteries or 3*AAA batteries
Waterproof: IPX-7
Anti Dropping Height: 1.5m
Product Features:
● Tank007 TC18 can concentrate light to throw long beam as well as light close in wide angle.
● There is a high power LED light in the middle surrounded by three red, green and blue different color lights, which can meet some special requirement.
● The equipped signal diffuser can turn the flashlight to a signal lamp easily.
● With the white diffuser, it can be used as a table lamp for repair, camping and so on.
● Thanks to the magnet in the tail that can be strongly absorbed to metal surface, it can easily be fixed when users need to repair vehicles, machines, elevator, etc..
● Attack head can be used for self-protection in emergency, which can easily break automotive glass.
● This flashlight is specially added fluorescent silicone ring so that is can be easily found in darkness.
● No need of removing battery for charging for it support directly charging and charging in the car.
● This TC18 is also a power bank which can charge mobile phones, cameras, and other products.
● With battery box, this flashlight can use three AAA batteries as power source.
● Five modes to adjust the lighting type can meet different lighting needs.
● Head rotation switch, which is durable and easy to operate.
● Constant current circuit chip for constant brightness.
● IPX7 waterproof design, suitable for hunting, cycling, climbing, camping and other outdoor activities.
● It is super bright maximum 350 lumens and has strong power, the throw beam can be up to 300 meters and the light still not be reduced.
You went on a trip and you have a weak smartphone - no problem if you have the Tank007 TC18 that purchased from GearVita handy! Complete with a flashlight is an adapter and a USB cable, thanks to which you can recharge your gadget directly from the lithium battery of the flashlight.
Have you decided to have a dance party? Tank007 TC18 will be very useful, it's not just the presence of the strobe mode. In addition to the main LED, 3 additional color LEDs are installed in the flashlight - red, green and blue, which simulate light-emitting music in one of the flashlight modes.
If you also think it is a multi-functional and useful flashlight, you can check it here: https://gearvita.com/tank007-tc18-rechargeable-flashlight-350-lumens.html
Related products:
Tank007 WF01 flashlight is a compact and portable flat wearable lamp, which can be rotated 180 degrees, easy to adjust the light direction, in small size like a lighter. The body comes with a metal clip, easy to use and to carry in a variety of ways. In addition to holding in hand, other using methods including but not limited to hanging in the neck lighting, clamping hat brim, badges, pockets, belts, etc.
Main Parameters:
LED: USA Cree XP-G2
LED Lifespan: above 100,000 hours
Max Brightness: 280 lumens
Throw Beam: Above 50m
Lens: Tempering optical lens
Power Source: Built-in 250mAh rechargeable lithium-ion battery
Output Level: Two mode types (the two types switch by quick clicking the switch):
▹ High - mid - low
▹ Strobe - Blink 0.5Hz - SOS
Burn Time:
▹ High light - 1 hour
▹ Medium light - 3 hours
▹ Low light - 34 hours
Waterproof: IPX-6
Product Features:
● 180 degree lighting to adjust beam direction to meet different needs.
● The size is as small as a lighter, convenient to carry.
● Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable.
● Tank007 WF01 comes with a metal clip, easy to use and various ways of carrying.
● Built-in high-energy polymer battery, which can be charged through the micro-USB port from the side.
● Built-in charge protection circuit which can stop charging in case of over discharge, overcharge, short circuit to further protect the battery.
● With memory drive circuit, the flashlight can remember commonly used modes.
● Comes with low power indicators, the red light flashes 3 times every 3 seconds at the frequency of 3Hz in the on-state when the power level is lower than 10 percent.
● Can be used as a signal light, double-click switch to turn on the signal light when the light is off, the red and green light will flash in turns. Click the switch once to power off the signal light. This can facilitate to find the flashlight in the dark (if the signal lights are in work process, click the button to exit the flash mode).
● When the flashlight is powered on, each time the power indicator is flashing, it indicates the power level - 100 percent flash 5 times, 75 percent flash 4 times, 50 percent flash 3 times, 25 percent flash 2 times, less than 10 percent does not flash.
● Suitable for camping, fishing, hunting, hiking, searching, working.
WF01 is a new type of mini flashlight, which can be worn to your hat, sleeve, pocket, etc. It is small in size but bright in night and now available on GearVita, you can purchase it online: https://gearvita.com/tank007-wf01-mini-wearable-flashlight-280-lumens.html
Related products:
https://gearvita.com/nitecore-tip-ss-stainless-steel-metallic-keychain-flashlight-360lm.html
Wuben E503 flashlight is a mini portable keychain flashlight, with pocket clip provided, easy to carry everywhere. It an be used as an emergency light, powered by 1*10440 battery, with 150 lumens brightness, max 60m brightness distance brings further bright distance. It is switched on by simply revolving the head, with one mode design, easy to operate. With the waterproof design, you don't need to worry about rainy days, it is a great tool for people who needs to go out in the night.
Main Parameters:
LED: CREE XP-G2 R5
Lifespan: 100,000 hours
Max Beam Distance: 60m
Battery: 1 x 3.7V 350mAh 10440 lithium-ion battery
Mode: Low - High
Waterproof: IPX-8 ( 2m submersible )
Impact resistance: 1.5m
Product Features:
● Wuben E503 adopts 6061-T6 high quality aerospace aluminum material, solid and durable for use.
● Mil-Spec hard-anodized for extreme durability.
● Adopts latest CREE XP-G2 LED as light source to bring super high brightness, up to 100,000 hours lifespan.
● Up to 150 lumens output and up to 60m beam distance, you can see clearly in the dark night.
● Powered by one 3.7V 350mA 10440 lithium-ion battery.
● Battery is rechargeable circuit design.
● Micro USB general charging connector with charging indicator function.
● ATR technology can regulate the temperature to prevent overheating from your flashlight.
● IPX-8 waterproof level, no worry about the rainy days, 1.5m impact resistance to suit for harsh environment.
● Toughened ultra-clear mineral glass lens with anti-reflective coating bring up to 99% light transmittance.
● Two setting modes, low light and high light to meet your needs. Just twisting the head switch to change the mode, easy to operate.
● Tighten the head to turn on the light, fully tighten to max output, loose the head to turn off.
● Chic and compact, only 25g, easy to carry, you can put it into your pocket or bag.
Product link: https://gearvita.com/wuben-e503-led-flashlight-150-lumens.html
It does not matter when and where you need a flashlight. At the party, you can create an open flashlight atmosphere. At night, you can turn on the flashlight to light up. During the day, you can be used for decoration is very beautiful. Such a practical and cheap flashlight, don't you hurry to buy it on GearVita?
Related products:
https://gearvita.com/wuben-e01-mini-portable-led-flashlight-100-lumens.html
https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
Go lightweight with the new Nitecore LA10 CRI flashlight. This innovative camping light is incredibly compact, weighing only 2 oz, after battery installation. Despite it's petite size, this light packs an impressive 85 lumens of brightness and up to 11 yards of illumination with a Nichia NVSL219B LED designed to enhance natural color. With added functionality such as the lanyard for hanging, magnetized tailcap for added convenience, and a retractable diffuser for compact transportation and storage, this light is the perfect addition to your camping gear! Whether going out into the back country for an extended expedition, car camping over the weekend, or using for night photography or light-painting, this light is a great tool you'll want to keep on hand!
Main Parameters:
LED: Nichia 219B LED
Beam Color: High CRI
Max Output: 85 lumens
Max Beam Distance: 10 m
Max Runtime: 1h 30min
Battery: 1 x AA battery
Light Modes: High, Mid, Low + Location Beacon
Waterproof: IPX-6 standard waterproof
Impact Resistant: 1.5m
High: 85 lumens ( 1 hrs 30 min )
Mid: 30 lumens ( 6 hrs )
Low : 9 lumens ( 23 hrs )
Product Features:
● The body is constructed from solid and lightweight aluminum ally, protecting core components from damage.
● Nitecore LA10 CRI Utilizes a high CRI Nichia 219B LED outputting 85lumens with effective illuminated area of 10m.
● Color Rendering Index (CRI) of 90 which accurately resembles natural sunlight to reveal every subtle detail of an object.
● Three brightness level (high/mid/low) and 1 special mode available for you to choose, meet your different demands.
● Reverse polarity protection.
● Magnetic tail cap with tail stand capability allows for quick attach to metal surface.
● Lipstick-shaped body is just the size of thumb, with a lanyard, making the light extremely easy to carry.
● Built-in retractable diffuser for 360 degree flood illumination, made from high transmittance material, it is capable of bringing out smooth and soft light.
● Flashes light once at a regular interval to mark the location while optimizing battery life.
● Powered by 1 × AA battery with maximum runtime of 23 hours.
● Water resistant with the rating of IPX6, which can protect from heavy splash and rain, impact resistant to 1.5 meter.
● Easy to use twist interface.
● Rotate the tail cap to switch on/off or adjust brightness levels.
Built for convenience and portability, the LA10 CRI is just over 3 inch long and weighs only 1.5 ounces without the battery so it can fit in a draw, pack or pocket easily. There are three colors for option on GearVita - black, blue and red: https://gearvita.com/nitecore-la10-cri-led-flashlight-85-lumens.html
Related products:
Olight is celebrating their 10th birthday with a present for its customers - the Olight ION flashlight, one of the most unique and stylish pocket-sized lights we've ever seen! This box-shaped light features a one-of-a-kind body design never before seen in a flashlight, crafted from durable gorilla glass with a sturdy titanium frame. No bigger than a Zippo lighter, this compact torch comes with a detachable key ring for easy fastening to your keychain, making it an ideal EDC light. The ION even comes with a special inscription on its back, celebrating the company's decade of excellence and thanking its highly valued customers!
The ION is equipped with 2 top-of-the-line CREE LEDs, which combine to produce anywhere from 1 to 320 Lumens of cool white light. In addition to its easy to use ON/OFF side switch, the sophisticated keylight is operated using a pair of pressure sensor switches on its body. Simply press the plus or minus symbols on the ION's gorilla glass body to cycle between its 6 unique outputs. This one-of-a-kind advanced interface has never been seen before in a flashlight, making this device all the more impressive.
Every aspect of the Olight ION is unique, its power source included. Rather than rely on separate batteries that need constant replacing, this handy keylight comes with a built-in Lithium Polymer battery pack, which can be recharged through the light's micro USB charging port. As you use the light, you can keep track of just how much charge is left thanks to its LED power indicator, located in between the light's pressure sensor switches. While the light is on, the indicator will glow either green, yellow, or red to signal how much juice the battery pack has left, so you'll never be surprised by a dead battery!
Main Parameters:
LED: 2 x CREE XP-G3 CW LED
Power Source: 1 x built-in 300mAh 3.7V lithium polymer battery pack
Max Output: 320 lumens
Max Beam Intensity: 750cd
Max Beam Distance: 55m
Waterproof: IPX0
Max: 320 lumens ( 27 minutes )
Mode 1: 160 lumens ( 1 hour )
Mode 2: 40 lumens ( 4 hours )
Mode 3: 10 lumens ( 16 hours )
Mode 4: 2.5 lumens ( 45 hours )
Min: 1 lumen ( 90 hours )
Product Features:
● This flashlight has a rectangular structure, one-of-a-kind gorilla glass body with titanium frame.
● Thanks to the dual LEDs and TIR optic lens, the ION has a soft, balanced beam profile with a wide defined hotspot and wide angle spill light, that is capable of a maximum output of 320 lumens and a beam range of up to 55 metres.
● There are pressure sensors in the “+” and “-” areas which allow the user to select either preset brightness levels or a gradual custom brightness setting.
● Built-in rechargeable LiPo battery can be charged through the micro USB port located on the side of the flashlight, it only takes 1.5 hours for a full charge.
● First flashlight in the world that controls the output through built-in pressure sensors under a glass control panel in a 1mm thin frame.
● Easy to operate, single press to select from four preset brightness levels, or press and hold for a custom output, ON/OFF slide power switch located on the side for quick power control.
● Remaining battery power indicator - green (>75%), yellow (15%~75%) or red (<15%), charging status indicator: red (charging), green (charging completed) both positioned on the "O" letter on the center of the panel.
● "10th Anniversary Edition" inscription on back, Zero in inscription doubles as a LED power indicator.
● A front and back tempered glass screen protector is included to protect the glass panels from damage whilst the metal ring on the tail can be connected to the included key chain for simple and convenient carry.
This is not only a celebration of Olight's 10 years of innovation but an entirely new type of flashlight for the illumination industry. The limited-edition titanium Olight ION on GearVita is the perfect gift with it’s custom brightness level settings and premium look and feel: https://gearvita.com/olight-ion-rechargeable-led-flashlight-320-lumens.html
Related products:
The Acebeam T36 is a dual switch tactical LED flashlight equipped with a Cree XHP35 HI LED, features 5 brightness levels plus a strobe mode and powered by single rechargeable 21700 Li-ion 5100mAh battery. The Acebeam T36 delivers an output range of 2 lumens to 2000 lumens with a beam distance of up to 303 meters. Equipped with a built-in USB-C charger makes charging convenient and up to 3 times faster than normal USB charging. The innovative side switch allows quick and easy selections to all available lighting modes. The aggressive strike bezel and dual switch operation make the Acebeam T36 an ideal flashlight for self-defense and every day carry.
Main Parameters:
LED: 1*Cree XHP35 HI LED
LED Lifespan: 50,000 hours
Power Source: 1 x 21700 or 1 x 18650 battery
Max Output: 2000 lumens
Peak Beam Distance: 303 meters
Peak Beam Intensity: 23,000cd
Max Runtime: 28days
IPX Rating: IPX-8
Brightness Levels and Runtime (Using 1 x 21700 battery):
Ultra Low: 2 lumens ( 28 days )
Low: 200 lumens ( 12 hours )
Medium: 500 lumens ( 5 hours )
High: 1350 ~ 650 lumens ( 10 minutes + 3 hours )
Turbo: 2000 ~ 800 lumens ( 1.5 minutes + 2.5 hours )
Strobe: 1350 lumens ( 3.8 hours )
Product Features:
● Aircraft grade aluminium body structure to withstand harsh environments.
● Premium Type III Hard Anodised anti-abrasive finish prevents scratches.
● Ultra-clear tempered glass lens with anti-reflective coating can be used in the toughest of conditions.
● Tactical strobe mode disorients an attacker without excessive force, therefore keeping a user at a safe distance away from an assailant.
● Smooth reflector creates a far-throwing, tight beam.
● Tactical knurling for firm grip, even when wearing gloves.
● Acebeam T36 flashlight adopts dual switch design to accommodate different scenarios and user preferences.
● Intelligent highly efficient circuit board design for max. performance and long time time.
● Tactical ring maintains a comfortable grip, also prevents rolling on a table.
● Built-in charging indicator notifies a user when a battery is fully charged.
● Battery adapter allows for the use of an 18650 if desired.
● Rubber cap for fully waterproof and dustproof, submersible to 5 meters.
● Specially designed for military, law enforcement, self-defence, hunting, search & rescue and outdoor activities.
Its long-lasting power, rechargeable battery, dual switch design and other features make this flashlight impressive. If you are also impressd by it, GearVita provides its purchase link for you: https://gearvita.com/acebeam-t36-rechargeable-flashlight-2000-lumens.html
Related products:
https://gearvita.com/klarus-xt1a-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/olight-m2r-warrior-led-flashlight-1500-lumens.html
Klarus Mi1C is a unique great mini-mighty bright EDC flashlight for everyday carry. Mini size at only 54.5mm in length, and using XP-L HI V3 LED and one high performance Klarus 16340 battery with micro-USB charging port, this rechargeable tiny light delivers 600lumens, with maximum runtime up to 9 days at moonlight mode. The Mi1C has tail-stand capability and a magnetic tail cap that can be affixed to a metal surface allowing hands-free illumination! This comes in handy whenever you're looking for something you have lost or whenever you’re working on something in the dark, it is a very useful tool especially if your car has had a break down and needs to be fixed at night. For other flashlights, if you prefer to keep your light on the low brightness level, you need turn it off in that level then turn the flashlight back on, and then turn on to that low brightness level. However, for Klarus Mi1C flashlight, one-touch access to the low mode, yes, you can! Easy and conveniently! A lock function is designed to the side switch, lock out the switch to avoid accidental activation in storage and prevent accidental damage to eyes from unexpected activation by children.
Main Parameters:
Emitters: CREE XP-L HI V3 LED
LED Lifespan: 50000 hours
Luminous Flux: 600 lumens
Beam Distance: 40m
Battery: 1 x 16340 or 1 x CR123A
Working Voltage: 2V - 4.2V
Output: 4 lighting levels + 2 flashing modes
Reflector: Convex lens
Waterproof: IPX8 (underwater 2 meters)
● With a 16340 Battery
High (600 lumens) - 1 hour and 12 minutes runtime
Medium (45 lumens) - 5 hours and 37 minutes runtime
Low (10 lumens) - 32 hours runtime
Moonlight (1 lumen) - 6 days runtime
Strobe (600 lumens) - 2 hours and 24 minutes runtime
SOS (45 lumens) - 15 hours and 45 minutes runtime
● With a CR123 Battery
High (305 lumens) - 2 hours and 21 minutes runtime
Medium (45 lumens) - 11 hours and 48 minutes runtime
Low (10 lumens) - 55 hours runtime
Moonlight (1 lumen) - 9 days runtime
Strobe (600 lumens) - 4 hours and 42 minutes runtime
SOS (45 lumens) - 33 hours runtime
Product Features:
● Mini-might brightness, thumb-sized.
● CREE XP-L HI V3 LED, maximum output up to 600 lumens.
● Extreme long running time, up to 9 days in moon mode.
● Professional optical lens design, even-lit flood and soft beam.
● Magnetic tail can affix the flashlight to any metal surface, free your hands when you are working.
● Fade-in and fade-out function when the Turbo mode is the initial mode for on and off to promote eye safety and improve the user experience.
● Newest intelligent temperature protection system(ITS) monitors internal temperature and adjusts output to regulate heat dissipation, protects LED and internal components for a perfect balance of output and safety.
● Intelligent battery capacity indicator to view remaining battery capacity at any time.
● Unique lock-out mode prevents accidental activation, avoiding battery drains during storage or traveling and prevents unintended directly shining into eyes.
● Reverse-polarity protection prevents damage due to incorrect battery orientation.
● One-touch low and with mode memory function.
● Aerospace aluminum alloy construction, CNC precision machining, Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
● Compatible with CR123A and 16340 Li-ion battery, Klarus high performance 16340 battery with a Micro- USB port is included ( installed at flashlight ), no need to bring a charger, easy to use, safe and reliable.
Compact, lightweight, easy to use, and insanely bright - the Klarus Mi1C has quickly become the favorite everyday carry flashlight of GearVita users and for good reason. This exquisite flashlight is tiny, about two inches in length, perfect for putting in your pocket or keeping in a bag. But don't let its small size fool you, this little EDC light is durable, powerful, and everything you need in a pocket flashlight: https://gearvita.com/klarus-mi1c-mini-led-flashlight-600-lumens.html
Related products:
https://gearvita.com/fenix-ld15r-right-angle-flashlight-500-lumen.html
Tank007 E01 flashlight is based on the base of the F5 LED with a power of 20 lumens, has a smooth reflector, as well as 1 mode of operation. As for batteries, it is only powered by one rechargeable AAA battery. Thanks to the small compact body, this flashlight is portable and easy to carry here and there as you wish. Such a flashlight will be a necessary gift for everyone, a great helper in daily use and a key fob on the keys.
Main Parameters:
LED Lifespan: 8000 hours
Max Brightness: 20 lumens
Throw Beam: 10m
Output Levels: One mode
Power Source: One AAA battery
Input Voltage: 0.8V - 3.0V
Burn Time: 10 hours
Waterproof: IPX-6
Product Features:
● Tank007 E01 is an ultra-portable mini flashlight only powered by one AAA battery.
● Head rotation switch, one-hand operation.
● E01 has one mode, and the max brightness is 20lm which can meet basic requirement of lighting.
● With the keychain, it is convenient for carrying.
Tank007 E01 is a basic flashlight that everyone must have. It doesn't take up space, portable and cheap, making it the most perfect companion for us. GearVita offers this charming flashlight for you with the price of $12.99: https://gearvita.com/tank007-e01-mini-led-flashlight.html
Related products:
https://gearvita.com/tank007-e18-camping-flashlight-180-lumens.html
https://gearvita.com/tank007-e10-outdoor-mini-flashlight-120-lumens.html
Convoy C8+ flashlight is the successor of Convoy C8, utilises a XPL-HI LED with 2800 mA output from single 18650 battery and has many improvements on host/body design. The newer version has full of fins on the head for better heat dissipation, aggressive knurlings for better grip, and new U-shape design on its tail cap for easier clicky operation.
Main Parameters:
Light Source: Cree XPL HI beads
Max Output: 1100 lumens
Range: 150 meters
Power Source: 1 x 18650
Peak Beam Power: 11W
Waterproof Rate: IPX-8
Product Features:
● Utilize XPL HI LED that with 1100 lumens high performance.
● Powered by 1pcs 18650 lithium battery (protected or unprotected), easily buy and recharge.
● Constructed from aerospace grade aluminum alloy with HAIII military grade hard-anodized finish.
● Deep diamond knurling design body ensures the light is easy-gripped.
● Specially made high reflectivity smoothreflector.
● Expert level design with 12 groups of 55 modes dimming for your daily use and research needs.
● U shape tail with self-protection defense tactical function.
● Reverse polarity protection prevents damage from incorrectly inserted batteries.
● Eight lighting modes, 0.1 percent brightness, 1 percent brightness, 10 percent brightness, 35 percent brightness, 100 percent brightness, strobe, biking and battery-check, so many brightness options are convenient for us.
● Memory function mode, when the flashlight is turned on for more than 3 seconds, the power mode may become erratic. Turn it off, and turn it off, still the original mode. If less than 3 seconds, turn it off and then turn it on, then go to the next mode.
● Low voltage protection function, when the voltage of the battery is 2.9-3.1V, the flashlight flashes 2 times / sec with low brightness. This is a low voltage warning.
● Waterproof in accordance with IPX-8 (2 meters submersible).
● Tail stand capability.
Come to buy it on GearVita with a favorable price of $19.99: https://gearvita.com/convoy-c8-led-flashlight-cree-xpl-hi-1100-lumens.html
Related products:
convoy s10
convoy s2+
The Fenix E18R is an ultra-compact EDC flashlight with outstanding performance. Powered by one 16340 Li-ion battery, it emits a max of 750 lumens, but a CR123A lithium battery can be used as well. This exquisite flashlight is finely made of durable high-strength and oxidation-resistance aluminum, and the ultra-thin optical lens processed with the same coating as automobile lights. Compared with common optical lens with a thickness of 7mm, the optimal optical lens of E18R features 3mm, which extremely shortens the length of the light. Featuring four output levels plus strobe, battery level indicator accessed by the stainless steel side switch.
Product Features:
● Cree XP-L HI LED with a lifespan of 50,000 hours.
● Max output of 750 lumens and beam distance of 136m.
● Operates on a rechargeable 16340 battery or non-rechargeable CR123 battery
● Powered by one ARB-L16-700P power Li-ion battery, or CR123A Lithium battery in emergency.
● Magnetic charging in the neck, specialized magnetic charging cable and one included ARB-L16-700P power Li-ion battery.
● Featuring lockout function and multiple ways to avoid accidental activation.
● Battery level indication.
● Automobile type optical lens coating process.
● Side switch for one-switch control.
● Magnetic tail.
● Reverse polarity protection to protect from improper battery insertion.
● Intelligent overheat protection.
● Low-voltage warning reminds when battery charging is needed.
● Digitally regulated output maintains constant brightness.
● Made of durable high-strength and oxidation-resistance aluminum.
● Premium type HAIII hard-anodized anti-abrasive finish.
● IP68 rated, totally protected against dust and foreign objects and submersible to 6.5 feet for 30 minutes.
Output Modes:
Turbo: 750 lumens - 45 min (446 feet / 136 meters)
High: 150 lumens - 2 hrs 35 min (190 feet / 58 meters)
Medium: 30 lumens - 13 hrs 50 min (82 feet / 25 meters)
Low: 5 lumens - 70 hrs (46 feet / 14 meters)
Strobe: 750 lumens
At only 2.36'' long, this light can be easily stored in pocket, wallet and backpack, is a must-have for your daily life, outdoor activities and repair work. Visit it on GearVita, you will want to add the E18R to your EDC line-up: https://gearvita.com/fenix-e18r-led-flashlight-750-lumens.html
Related products:
Fenix E16
Fenix LD15R
The Utorch SF01 is an extremely powerful and high performing handheld searchlight. It utilizes a Cree XR-ER2 LED with a maximum output of 350lm, offering 3 lighting modes and a strobe mode. Powered by a CR123, AA or AAA batteries, the upper switch offers one-handed operation and allows you to select from three gears for your options. The precision reflecting system ensures powerful lighting in illumination and distance, premium aluminum alloy body provides a long service life for you. It's small but bright, simple but functional, well-built and incredibly lite weight, perfect for your outdoor adventures, camping trips and anywhere else you need a sufficient amount of light.
Main Parameters:
Emitter: Cree XR-ER2 LED
Battery: CR123, AA or AAA
Lumen: 350lm
Shell Material: alumimum alloy
Working Voltage: 3V
Current: 1A
Working Time: 3h
Lighting Distance: 50m
Product Features:
● Cree XR-E R2 LED in use, emits 350lm cold white light, bright to reach 50m away.
● 3W low power consumption for reliable illumination.
● Powered by a CR123 non-rechargeable battery, is capable for 3 hours long.
● With robust aluminum alloy shell, SF01 is splashproof and unlikely to break.
● 3 lighting modes to cope with most circumstances easily.
● You will love the soft touch of the button, push it differently to change the lighting effect.
● As long as a cigarette, only takes up a little space.
● It has a clip for being attached firmly to belt, bracelet or pocket.
This is a quite cheap flashlight and can fulfill its purpose, you can buy it from GearVita at $8.99: https://gearvita.com/utorch-sf01-led-flashlight-350-lumens.html
Related products:
convoy s2+
wuben e502
is GearVita and Gearbest are both under same owner?
