Thanks for that. I didn’t know about them.
I expect to pay more for a UK based seller.
Need to go see if HKJ has reviewed that battery.
Never bought any Japanese brand cells on Ali.
But i think the Liitokala store is definitely legit.
It is good to about 20A even though the wrapping says 35A continuous. Otherwise not a bad battery.
Link to HKJ Review of Efest 4500mAH 26650 (Purple) —> Test of Efest IMR26650 4200mAh (Purple) 2017
It is. checking . . .
Link to the real Liitokala store: —> https://liitokala.aliexpress.com/store/133859
UK Shipping is enabled. … Going to try and order two batteries. We will see if this works.
Liitokala say the battery is rated to 15A continuous. That is lower than I’d like. Going to buy a couple anyway. I’m sure I will find a use for them.
HKJ tested them as ok to 20A but that might be an older version. The ones on the AliExpress store look different.
The automated system accepted the order from Liitokala.aliexpress. 4x 26650 for less than $15.00. I’ll update this thread when they ship or reject the order.
There is Torchy the battery boy, and Nkon.eu for local shipping. Hopefully the 26650’s on Aliexpress should be genuine as they are only a few different types of cells. The Liitokala stores have had a run of fake 30Q’s etc of late.
UK wise I always use Norb, he has Ecolux shop on eBay or actual website/shop. Top bloke, highly recommend.
I think that was the fake Liitokala store.
nkon?
Nkon are in my OP. They don’t have much in 26650.
Looks promising. Lots to choose from in 26650 —-> https://www.ecoluxshopdirect.co.uk/by-size/26650-battery
I can second Ecolux - now that I think about it, I originally had that recommendation from Ven on CPF Thank you, Ven I’ve had chargers and cells from them, always had good service. Just bought a couple of 26650s last week, in fact, after having the same problem with Banggood.
I’ve had cells from NKON as well - also good service, although their selection is smaller, as you say.
Finally, I’ve had a fair few cells from www.flashaholics.co.uk - good service from them too, but the selection is more limited and their prices have gone up quite a bit since I bought mine last year and the year before.
I use ecolux, torchy and these below, all good
18650 Batteries
Looking for an external vape battery for your e-cig vape mod? Shop our range of 18650 batteries plus other sizes.
The LiitoKala 26650-50A/Lii-50A is quite singular. Made by chinese OEM Power Long Battery, there's no other 26650 cell in the market which can be effectively used to fake it without being easily noticed. Features a distinctive 4-lobe flat top and it is wider than any other cell in the market besides own Power Long Battery cells (∅≈26.7mm).
Both the Shockli IMR26650 5500mAh and the KeepPower IMR26650 6000mAh UH2660 are rewraps of the PLB INR26650-55A. Those chinese rewrapping fellows must think prefixing a battery with IMR is good, but this has nothing to do with the actual chemistry of the cells and I believe it is misleading. The OEM names their cells INR, and their actual chemistry is hybrid Nickel-Cobalt-Manganese.
Cheers ^:)
Ok, after suggesting 18650.co.uk I contacted them asking for a discount code for BLF members. They agreed if we could help them out by suggesting brands/sizes for them to stock, and in return they would give us a 10% site wide discount code for us to use. Please, if you have any suggestions post them HERE so I can send them a list.
I received a pair of LiitoKala 26650 batteries the other day from their AliExpress store. Ordered a few times from them, shipping can take a while but so far not had an issue with the batteries I’ve received.
Did a quick test on the 26650’s I received yesterday and I’m happy
Ecolux UK
Speak to Norbert.
Where these cells any good then? low internal resistance?
Thanks
18650.uk ,I get mine from there & they are definitely genuine.
Fogstar, I haven’t used these yet but I’m pretty sure they are good.
