Got my goodies, tnx!
Now I’ll see what a triple of 351Ds will look like…
Hi, I’d like to order
Thanks!
I got my S2+ Parts today, great packed & shrouded with wrapper… And Postman rings for it… 9 days to germany… Great Job…
Thank you kiriba-ru
I received my copper S2+ spacers in less than 2 weeks to the US! Packaging was excellent! Thanks!
I would like -
Copper pill triple Convoy S2+ (Convoy retaining ring)
Copper spacer for Carclo triple Convoy S2
Plaese PM me with details
Thank you
All triple pills are gone. I think single led copper pill looks more interesting since 17mm boost driver is available, so single pill is next to be produced. I havent seen great demand for triple pills last time, not sure I should make more of them. Please leave your comment if you dont agree.
Hello,
will P60 Surefire copper quad shelf find into the this host ?
P60 head size
inner head tube 22mm
max inner diameter 24,5mm
lenght from bottom head to glass 33mm
(from screws - there is no shelf, a spring is hold by battery tube)
Brass Pill + reflector size that fits to host
lenght pill + reflector (wo spring) 27,5mm
max reflector diameter 26mm
Body reflector diameter 21,75mm
Could you please show the top of the head?
Please see,
I dont see any reason why quad drop-in wont fit.
But I think this surface on top of the head is the only reasonable pad to transfer negative to the pill. If you can sand the ano down to the bare aluminium, it should work well.
If you have anymore of the copper S2+ triples or make more, I will buy three. Thanks.
I was actually hopping to buy some S2+ triple pills as well
I got my S2+ Parts today - FAST - Thank You
Parts received! Great quality copper pills!
Need a person who wants to make a belt grinder from an angle grinder. ASAP.
kiriba-ru, would it be possible to make a short 18350 tube for the Convoy C8? I can’t find one anywhere and I like short flashlight versions like the GT mini.
Had few requests but defenetly not enough for cnc batch.
Thank you, kiriba-ru! Looking forward to the day when Convoy will produce one.
