Well, my thought was that you might want as much reflection as possible, even if (or especially if) it is diffuse. But I understand your limits on machine noise and dust/debris. It should work well enough with the reflective paint I think. I’m looking forward to seeing your build.
” Flashy Mike ”
Nice entry idea :+1:
You may want to consider Chrome MonoKote http://www.monokote.com/metallic.html
You can heat shrink it tight on the cone for reflection. I used this Monokote when making RC Planes with my son yrs ago. Use a light heat gun to shrink it tight after super gluing it down around the edges.
I have the same printer, indeed a nice and small device. What improvements did you do? Lately I installed a E3D V6 clone on mine together with a firmware upgrade to the latest marlin, have not printed a lot after the change but the few prints I did came out great.
Also did some smaller upgrades like belt tensioners, filament guide and a tilted lcd mount.
Do have to say that I kinda expected a little bit better print quality out of the box after seeing many reviews. But I do like this small machine!
Up to now only the simple ones, like filement guide, silent fans for board and hotend. Designed and printed a small plate for the bottom of the hot end to stop the fan blowing partly onto the printed object (when using ABS). Designed and printed a simple filament roll holder since the filement string had too much tension when pulled from the holder on top of the Z-Axis.
Haven’t changed the power supply’s fan yet, since it was a too tight fit with the ordered silent 20mm fan (stock one is 15mm). Still looking for a fitting silent 60x60x15 fan with suffizient flow.
Got the green ABS for the lantern yesterday, currently searching for the best slicer settings.
Unfortunately I haven’t done much for this build in the last days but I got more familiar with 3D design and printing. I created my first designs with Tinkercad which is great for beginners but lacks features for advanced designers. So I downloaded Fusion360 which is more capable. As in other products of this company I had my problems with the user interface but was able to create my first design after an evening (and after lots of grumbling and google search).
To learn more about the capabilities of my printer - and in order to know what I can do in my camping lantern design - I designed and printed a couple of screws and bolts in different sizes. Turned out surprisingly well, the smallest one in this picture is M3!
First prototype of the mechanism for the rectractable reflector. The thinner component will be screwed at the top end into the reflector. Prototype is shorter than planned for the final build in order to save filament and time during testing. Perhaps I’ll add one more segment if necessary. Currently printed with PLA, probably will be made of green ABS for final build.
Which of the pics can you see? There is a green rendering, and 2 fotos with orange parts, one of the fotos with 2 separate components. I’m using google fotos for this pics and there might be a problem with links.
A better approach for the retractable reflector, I guess. This one can lock at any height and only needs about a quarter turn for locking.
The outmost tube represents the casing, so only the inner 2 tubes make the extendible part (for about 9 cm currently). The white dot in the center of the printed inner tube are the remaining threads of a printed M3 screw, made of PLA, which I broke during tests. Not unexpectedly, though.
Made progress with design. The upper half of the casing, the retractable reflector and the bottom plate are almost finished and printable, the lower half of the casing still requires some work in the inside for the electronics compartment. Here are some new renders, size of this light is 10.2 cm in diameter with a height of 5.6 cm (closed). I consider this light a pretty compact camping lantern.
I’ll probably use three SST-20 3000K LEDs. They should produce a nice warm illumination, so I discarded the idea of additional red LEDs. The LEDs sit in spare Convoy S2+ reflectors which I have lying around.
The switch is a reverse clicky to avoid current drain, since this light might not be used most of the year.
Driver will probably use 8 or 9 AMC 7135. The copper or aluminium plate in the middle of the lantern protrudes 3 mm, this allows a surface area of about 9 square centimeters exposed to the air. Hope this is sufficient cooling for 3 amps with this LEDs. If not I still can use less 7135.
I’m still thinking about the charging modul. I would like to use USB-C but I haven’t found a reliable source.
And I need a rubber cap for the cutout of this charging module, haven’t found any source yet. I don’t even know the proper english term for this component.
