Una por favor Pepinfaxera,solo una
Gracias
Just to clarify, those lights use RampingIOS or D4 ramping, so no candle mode.
They can be reflashed to use Anduril though, which will give them candle mode.
If someone is able to reflash them. :wink:
The FW3A will have it as ‘standard equipment’. :beer:
Accurate clarification, that is what I was trying to say. As far as the diffuser goes, same for the D4 and this light, you likely need to roll your own.
I have the D4 with Anduril, and it does make for a great candle, even without the diffuser.
Just about all of my 18650 cells are protected, and the couple that are unprotected aren't all that great.
I guess I could invest in some quality unprotected cells, though I do not particularly want to.
Member for 8+ years and almost 11,000 posts…and no decent high drain unprotected cells?
My mind is blown!
:smiley: …. That makes two of us…… I was thinking the same thing…. :wink:
Interested in one, thank you
Wow - I don’t have ANY protected cells, and don’t want them either.
I don’t want issues with who made the circuit, how it performs, whether it will fit, metal strip running down the side - yuk.
I have a few Panny B’s for capacity and the rest are nearly all 30Q’s button or flat top, aside from a few laptop pulls, and some 14500/10440 of mixed breed.
I have some protected cell from when I first started with LiIon & was afraid I’d blow myself up. :smiley: . But since then I have gone mostly to unprotected. :wink:
Hitherto I bought mostly protected cells, as I got more knowledge about Li-ion cells, I will buy mostly unprotected. Think about Tesla, thousands of unprotected cells under your ass, still no spontaneously fire incidents.
Those are still protected, just through a BMS or battery management system. Still, there is the rare fire usually due to the battery pack being punctured. Way way more safer than gasoline, though. Even a protected 18650 can burn up if the protection circuit is in the negative end and the positive metal strap along the side gets scratched and causes a short in the battery tube.
I still use protected cells in headlamps and the lights that I give away, even if the light has lvp built in.
I’m hoping Fireflies updates future batches of the ROT66 to Anduril. If so, then FW3A would be the 2nd.
For the ultimate candle effect, instead of a slip-on diffuser, you’ll want to set it on a small fan, with orange and/or yellow tissue paper taped to the top to “flicker” in the breeze like this sort of gadget:
Please add me to the list with 1 light. Thanks!
You’ve heard of the Fisker Karma Atleast tesla makes their packs water proof lol
Please add me to the list for one light. :slight_smile:
Thank you. :+1:
WOW… :open_mouth: !!! What a mess! Thanks for sharing C_k. :+1:
You could light a candle maybe…
:smiley: … Amen. :+1: :beer:
I am looking forward to this one too… wonder how much longer before we get some action?
