well so is mine, its not perfect centered the so called smiley its a bit off but not as off as his no but still….
I asked Neal if maybe a replacement head is an option to send, since that is easy just unscrew and it would probably work but if they dont want do that i have wasted 40$ on a light i will not use since its defective and warranty for a light thats 1 month old should cover normal use…
Just reviewing the GT mini for youtube, first thing I’ve noticed is my GT has strobes from default. Nice light tbh, the aluminium is very very soft though.
3V Cylinder Head Bare 2.190/1.650” Valve 225 Cc Intake - 60 Cc Chamber - Ford Cleveland/Modified
Brand Name: CYLINDER HEAD INNOVATIONS
Part Number: SBF3V225B-60
Description:
The all new 3V 225cc cylinder heads replace the older 218cc heads and are suited for use on competition and serious street engines of 400+ cubic inches in size and making up to and in excess of 650+hp. The new 225cc feature the same minimum cross section (2.4�) as the 218cc intake ports are designed to deliver maximum power and torque, for those people not concerned by RPM limitations, but rather wanting to make the most possible torque and horsepower for their competition to wild street power plants.
That’s not a Ford head 100% for sure. Atleast not from a modern 3-valve 4.6L/5.4L. For one the valve arrangement is wrong (Ford heads have the single exhaust valve centered), plus if we were to say just for s&g’s thay maybe those were aftermarket Ford heads with non-factory valve geometry we’d still be able to prove that wrong as the intake ports are no where near correct. Not only would the ports not line up but the two decks (head to intake manifold) wouldn’t meet up at all on those things.
I’ll bet money those arnt Ford 3v heads. Hell it could even be an i4 head off who knows what.
I google searched by the stamped in coding, and it came back as a Ford head. A custom racing Ford head.
Neither your money loss nor Teacher’s best intent helps me much though, and it was his offering of 3 choices to help me that got all this started. Best intentions and all that…
