Pill is super easy to remove and the driver is just held in with a retaining ring. No solder. Had to solder the new drivers in but getting the old ones out was a breeze.
Oh the driver works just fine. I probably shouldn’t have called it bad, just not my liking. The blinky modes in the mode set drives me batty. Medium and high are a bit too close in output for my liking. Other than that it works just fine. Nothing wrong with it out of the box. I just wanted to get rid of the blinky’s.
For the price its not bad for giveaway for friends who wants to own a ‘decent’ light. And maybe you can put one in the garage one in bathroom on in the kitchen etc
Agreeing with above. Convoy are NOW. well made. reliable and fairlty cheap.
I bought 3 coloured S2’s for $9 something last week for kids. Boring as, but will do a good job.
Every time you press the sw. Yeay. Light… Unlike some I’ve bought.
Same with their C8’s . and the L2/L6 are as good as anything else I’ve seen on market.
I tried a coupla U-Torches but passed them on. Didn’t suit. Shape and feel mainly.
I’ve sealed/potted half a doz of my drivers on the better ones.
Used “ceramic Epoxy” white. has no Metallic anything in there. completely inert.
Just leave open O/Night to go off.
Just mix. drip on, then leave stand on bench. Simple.
Time will tell.
Picture of the driver, no solder pads as on the 105C’s. Which I have a few to replace this existing driver. Sorry for the crappy photo. My phone won’t focus down that close but if you need values of any components I can give ya those. The spring side of the driver has XP45E printed on it.
My MonkeyECHO plugin shows me a nice historic graph about the price of the light until now. It started at $19.26 on July 21, then quickly dropped to $9.38 on July 30.
Then to $7.89 in mid August. Since then it is jumping between $6.99 and $9.38 every few days. Using a coupon it is $6.99.
I understand how this works. You buy when you are ready to spend the money. If not you may buy after the next price drop.
Like at Starbucks you pay as much as you like.
But I can’t help feeling I pay too much too often watching these games.
You got it. Terrible UI out of the box. The good part is. It’s a nice white tint and nice beam. A $2 driver fixes that up. Unless of course you want a new emitter too.
I picked up a bunch of them and just changed the driver out, 2 modes, no blinkies, the emitter and beam were fine for the purpose I am using them for. If you use the Gearbest app I think you can get them for $6.99.
Only because a friend gave me a handful of them. Easy swap, 5 minute job. I put a A6 driver in one. Only got to use it for a few minutes then my oldest son stole it from me. He hasn’t called and told me it quit working yet so I assume it’s still going strong.
That is not the easiest driver to use because the 7135 chips on the battery side prevent using the driver retaining ring. Did you solder the driver in place?
Yes, sorry, forgot to mention that. Yes I did solder in the driver. I don’t think I will ever have to swap it out again unless some sort of failure happens I reckon. Should be reasonably painless in removing them again if need be. These aren’t lights I am using as EDC or anything like that. These are just toolbox, tackle box, glove box, type lights that I am not worried about getting beat up or anything. They will serve their purpose for less than $10 and a $3 cell.
Yes, it’s a 3 minutes baking with butane torch for all 3 parts of flashlight.
Bake until a golden color appears. It’s +/- 1 minute for 1 part.
It is my first baking and it’s easy and fast to do.
1. Disassembly and removal of internal flashlight elements - 5 minutes
2. Each part was baked separately.
3. It is necessary to clean the grease.
4. Do not forget to remove the rubber rings.
5. Cooling down - 5 minutes.
6. Assembly - 5 minutes.
7. Do not forget to re-lubricate the flashlight.
