OK, some details found on low temp pressureless sintering so far: Namics XH9889-2 offers 300 W/mK. With curing at 200 degrees. That looks like the top choice available.
But another interesting options is Nihon Hanada MAX 112. Cures at just 150 °C, that’s certainly safe. 182 W/mK ain’t bad.
But something tells me that this indium wire might be cheaper.
I was just thinking - why not just use SnAg solder paste (or wire)? Sn96.5Ag3.5 supposedly has a thermal conductivity of 78W/mK and a low melting temp of 220°C. It's important to differenciate between SnAg and SnAgCu solder. The latter has a lower thermal conductivity of around 60.
Some solder wire products I found:
Felder ISO-Core VA Sn96,5Ag3,5 (Sn96Ag4 according to DIN EN ISO 9453) (221°C)
Furutech S-070 SN96,0Ag4,0 High Performance Solder (220°C)
One thing to note when using solder wire with LEDs: one needs to put flux onto the contacts of the LED because the flux in the solder wire is probably gone when you put the LED onto the tinned pcb contacts.
I just noticed that I have discussed this topic before a few years ago (here).
Nope, I found nothing better for this kind of stuff.
There may be some improvements for lights that have bottlenecks down the path (f.e. DQG Tiny 18650), but I can’t add anything to improve on what’s said here.
It’s probably a bit related. Just got an IC Graphite thermal pad kindly shipped to me by zak.wilson. Here’s a quick test comparing it to the MX-4 thermal paste. No TIM for reference. It seems to suck heat off the MCPCB just as well as normal paste. It’s reusable too, and no cleaning required so perfect for LED testing.
Thanks for the test! That is indeed very interesting for lights which are modded vers often.
Could you repeat the test, but measure the brightness of the LED?
OK, so I got some Indium off AE (advertised as 99.99% pure….) and tried soldering it. While it’s very very soft, about as soft as pure lead, joint strength was surprisingly good. Two strips of FR4 PCB soldered together in an area of ~1cm² wouldn’t come apart until the FR4 itself was severely deformed. Wetting, as expected, was very good (I used some standard rosin flux).
I found one possible downside to pure indium though:
This could be an issue with ceramic packages, though I doubt it applies to any but the most expensive sources.
(This paper also somewhat relieved my concerns about creep failure though I’d take extra precaution not to stress the emitter via the centering ring, just to be sure.)
I just remembered an additional material upgrade. Normal dtp pcbs are made out of copper or aluminium. There is another possible material onto which the LED can be directly soldered which transfers heat even better than copper: silver. Basti in the German TLF forum made such a pcb a few years ago. He made it just for the looks though.
The thermal conductivity of silver is 7% higher than that of the best possible (most pure) copper. Most common copper alloys are not 99.99% pure though, making the difference for pronounced.
I asked him if he would make one for me for my big thrower when I was planning the build, but he is not an active flashahlic anymore.
This is a variant of Panasonic’s PGS, and most importantly, soft PGS.
The two disadvantages of using PGS are higher contact thermal impedance compared to thermal paste if applied without enough pressure, and electrical conductivity.
Soft-PGS is better in this regard than pure PGS, since while it features much higher thermal resistance(20W-28W/k vs 300-1800W/k), PC users have tested that thermal performance is much better with soft PGS because of much lower contact thermal resistance as specified above.
It’s also because soft PGS has much better thermal transfer in the Z-Axis compared to the X/Y-Axis, meaning thermal transfer of high power density products is much better than regular PGS.
Link:
TLDR: Soft-PGS is better in almost all cases with high power density electronics, such as CPUs/GPUs and VHP LEDs such as XHP70.2s overdriven, CFT-90s up to 100W power levels without starting to fall behind thermal paste because of heat spots without very high pressure mounting. The best combination for massive thermal transfer capabilities are liquid metal below the soft PGS, and the soft PGS under the MCPCB itself.
Most flashlights allow providing some decent MCPCB to pill/shelf pressure. Does this mean a piece of 0.2mm soft-PGS under the emitter board is nice enough? Is it electrically conductive?
Yes, it is electrically conductive. Just be great for almost all LED builds, except that CFT-90 LED. That thing has huge power density, and needs liquid metal.
Another thing which I suspect won’t work but I’ll throw it anyway. I wonder if improvements to radiation either directly from the LED package or from the MCPCB could bring measurable performance increase?
-The one with 28 W/m·K is the EYGS series which comes in 0.2mm thickness and is electrically conductive.
-The one with high thermal conductivity in the z-axis (vs. x/y) is the EYGT series. This is graphite in a silicone matrix , it looks like this is NOT conductive (4*10^5 Ω·cm), but comes only in >0.5mm thick sheets and has a conductivity of 5 to 10 W/m·K (strangely, it goes up with thickness?). Has some sort of separator but the datasheet is not clear what its properties are or whether it needs to be removed before use.
This doesn’t make much sense to me. The LED and pcb radiate into the air inside the flashligth head. Air is a very bad conductor of heat. After this the heat would still need to go through the metal of the head or through the glass lens (glass is somewhat good at conducting heat). You would need to replace the air inside the head with something else that doesn’t transmit light any worse, but has a noticeably better thermal conductivity.
Would air absorb significant part of the radiation? I assumed no, but maybe incorrectly.
Otherwise goes towards the optics or towards the head sides or both, depending on what radiates it and what’s the optic.
Head can absorb it, conduct it towards the edges and remove.
