Turbo is not a specific number of lumens; it is direct drive. Brightness is determined by where the LED’s forward voltage curve meets the battery’s discharge curve. And, at only 2.9V, it won’t be very bright no matter what kind of battery is used. That is an empty battery pushing less voltage than the emitter wants.
According to Texas_Ace’s testing, it would max out at less than 230 lumens per emitter at 2.9V, even if the battery was capable of pushing a thousand Amps.
This is the answer i’m looking for, thanks a bunch.
Don’t know why i keep saying turbo, it’s a habbit i guess. But yeah, i was wondering the emitting capable of the LED at low U and high I
BLF Q8 with NarsilM v1.0 (or v1.2) doesn’t have thermal calibration feature.
Let’s say the stock BLF Q8 (or other NarsilM flashlight for that matter) is very wrong (eg. ambient is 25 deg C, but “thermal check” reads 45 deg C)
Say I flash it to Anduril, then I calibrate the temperature there (25 deg C more or less is 25 deg C)
When I flash the Q8 back to NarsilM (say v1.2), will the thermal sensor (which was previously calibrated when it had Anduril) be back to the earlier wrong reading, or will it become correct (the value configured in Anduril), or just some other random thermal value?
HKJ and Mooch both put constant loads on the batteries starting at 4.2v and ending at 2.8v and discharge it at multiple rates. To get a continuous rating the cell has to stay within a “safe” temperature range. I think this is below 80°C.
It can be a bit off. It just means the light might thermally stepdown too early or too late. Usually the factory setting is pretty close. You can customize the step down temp to whatever you want or switch to a timed stepdown.
When setting the thermal step down temperature yourself, the light will turn on to turbo and then you just hold the light until you think it’s hot enough and then click the button. So you don’t actually have to know an exact temperature number to set it. Whatever temperature number it read when you set the limit is when it will step down in the future.
The temperature sensor is built into the MCU chip and you can’t really get super accurate reading from this style of sensor compared to an externally mounted sensor. It still works fine, though. You don’t even have to have a thermal step down if you don’t want it. You can turn it off and then control the temperature manually like most lights.
I believe the way Anduril calibrates it’s sensor is to just adjust using a correction factor meaning it adds or subtracts a certain amount from its reading. So if the light is actually 25°C and it’s thermometer says 45°C (the tolerance would not be that high, maybe plus or minus 10°C is more accurate) then you would tell it to subtract 20° from all its temp readings. Now it’s “accurate”.
If you flash to NarsilM, that correction factor disappears along with all the Anduril code. So it should be back to reading 45°C.
As it was said earlier, the MCU does not really need to know the accurate temperature. It just needs to know the relative temperature so that it can activate the thermal step down.
I’m not sure why ToyKeeper added a temperature calibration circuit, since it’s technically not needed. Maybe there’s something specific to Anduril that needs to know the actual temperature?
Because you click however many degrees above 30C you want it to step down at. 60C = click 30 times. So now you have a calibrated temp and a more precise step down setting.
Is this in reference to me asking why Toykeeper added the temperature calibration?
Why do you need precision? My hands tell me when it is hot enough. The thermal step-downs main purpose is just to prevent you from burning your hands. Eh, no big deal.
Why not? Why do people like Android phones over Apple and vice versa? With a value I can (easily) tweak it a little higher or lower as I wish. They both get the job done.
I like the simplicity of hold-until-hot, but in this case I went for something a little more complicated in order to get better results.
Running a light in turbo until it feels hot enough… is kind of obnoxious and imprecise and not feasible at a factory… especially on bigger lights where it takes a long time to heat up.
The calibration function makes it much easier to get consistent behavior on each light. In theory, the company making or selling it could calibrate each unit in about 30 to 45 seconds, and avoid a lot of issues with products overheating.
If it’s not factory-calibrated though, it’s still reasonably simple for a user to do it, and faster than the hold-until-hot method. Go to thermal config mode, click enough times to tell it the current temperature, then wait a few seconds for it to fall out and go back to its previous state.
Anyway, hopefully the factory or vendor will do it so the user doesn’t have to.
I don’t know, but I hope so. I recommend it, repeatedly, to everyone who sells lights with Anduril (or RampingIOS V3, which also supports calibration). It improves things for users, and should reduce return rates for vendors, by preventing common issues.
Actually it off ALOT. When i temp checked it read 42 Celcius but room temp was 20+! And ofcourse the light was not being used. I use the time stepdown setting wich reduce turbo after 7 mins. However i like to play with the temp check, it just that i like to use it that’s all, to me it’s not a big deal anyway but having it off too much make me itchy.
I have 3 lights with NarsilM. At 23°C room temp I got, 19°, 21° and 22°. You certainly have a large deviation. Are the lights internals at room temp? Any time you use the light it gets warm internally and you have to wait maybe an hour or more for it to fully cool down even though the exterior may already be cool.
It’s very easy to set your own temp stepdown if you want to switch from timed. I did a video on just this procedure.
Like i said, the light was not being used. So i’m pretty sure the internal temp is equal to the room temperature. I know how to switch to thermal stepdown, but i don’t want to use it. Just want to check the temperature that’s all, weird hobby right?
It sounds like you have been lucky. I have seen identical lights report temperatures 20 C apart. The firmware’s default value is intentionally toward the safe end of that scale, since it’s typically better for some lights to step down early than for some lights to step down too late.
Anyway, with a range of perhaps 25 C variation from one light to another, it’s useful to have a calibration function. Aside from improving safety and consistency, it also makes the temperature check function sort of useful as a thermometer.
So guys and gals, Sofirn has told me that they’ll soon start shipping the extended battery tubes for the Q8, along with carriers which will hopefully have, as they said before, upgraded springs.
