(BLF) Sofirn Q8 V1.5: The XPL HI monster, DIY parts + Extended 8x18650 tubes GB Interest List
Yes, it will return to its original wrong reading.
I think I can answer this.
I believe the way Anduril calibrates it’s sensor is to just adjust using a correction factor meaning it adds or subtracts a certain amount from its reading. So if the light is actually 25°C and it’s thermometer says 45°C (the tolerance would not be that high, maybe plus or minus 10°C is more accurate) then you would tell it to subtract 20° from all its temp readings. Now it’s “accurate”.
If you flash to NarsilM, that correction factor disappears along with all the Anduril code. So it should be back to reading 45°C.
As it was said earlier, the MCU does not really need to know the accurate temperature. It just needs to know the relative temperature so that it can activate the thermal step down.
I’m not sure why ToyKeeper added a temperature calibration circuit, since it’s technically not needed. Maybe there’s something specific to Anduril that needs to know the actual temperature?
Because you click however many degrees above 30C you want it to step down at. 60C = click 30 times. So now you have a calibrated temp and a more precise step down setting.
Is this in reference to me asking why Toykeeper added the temperature calibration?
Why do you need precision? My hands tell me when it is hot enough. The thermal step-downs main purpose is just to prevent you from burning your hands. Eh, no big deal.
Why not? Why do people like Android phones over Apple and vice versa? With a value I can (easily) tweak it a little higher or lower as I wish. They both get the job done.
I like the simplicity of hold-until-hot, but in this case I went for something a little more complicated in order to get better results.
Running a light in turbo until it feels hot enough… is kind of obnoxious and imprecise and not feasible at a factory… especially on bigger lights where it takes a long time to heat up.
The calibration function makes it much easier to get consistent behavior on each light. In theory, the company making or selling it could calibrate each unit in about 30 to 45 seconds, and avoid a lot of issues with products overheating.
If it’s not factory-calibrated though, it’s still reasonably simple for a user to do it, and faster than the hold-until-hot method. Go to thermal config mode, click enough times to tell it the current temperature, then wait a few seconds for it to fall out and go back to its previous state.
Anyway, hopefully the factory or vendor will do it so the user doesn’t have to.
Ah, fast factory calibration. That makes sense. Do you think Lumintop will try to calibrate all the FW3A lights?
I don’t know, but I hope so. I recommend it, repeatedly, to everyone who sells lights with Anduril (or RampingIOS V3, which also supports calibration). It improves things for users, and should reduce return rates for vendors, by preventing common issues.
Actually it off ALOT. When i temp checked it read 42 Celcius but room temp was 20+! And ofcourse the light was not being used. I use the time stepdown setting wich reduce turbo after 7 mins. However i like to play with the temp check, it just that i like to use it that’s all, to me it’s not a big deal anyway but having it off too much make me itchy.
I have 3 lights with NarsilM. At 23°C room temp I got, 19°, 21° and 22°. You certainly have a large deviation. Are the lights internals at room temp? Any time you use the light it gets warm internally and you have to wait maybe an hour or more for it to fully cool down even though the exterior may already be cool.
It’s very easy to set your own temp stepdown if you want to switch from timed. I did a video on just this procedure.
I agree. However after depletion of caps stock I would consider doing something stylish.
Like i said, the light was not being used. So i’m pretty sure the internal temp is equal to the room temperature. I know how to switch to thermal stepdown, but i don’t want to use it. Just want to check the temperature that’s all, weird hobby right? :stuck_out_tongue:
It sounds like you have been lucky. I have seen identical lights report temperatures 20 C apart. The firmware’s default value is intentionally toward the safe end of that scale, since it’s typically better for some lights to step down early than for some lights to step down too late.
Anyway, with a range of perhaps 25 C variation from one light to another, it’s useful to have a calibration function. Aside from improving safety and consistency, it also makes the temperature check function sort of useful as a thermometer.
So guys and gals, Sofirn has told me that they’ll soon start shipping the extended battery tubes for the Q8, along with carriers which will hopefully have, as they said before, upgraded springs.
Got this link from Barry yesterday, lego-fun with battery tubes :party:
yup, 70cm torch for walking the dog
any word on battery tubes?
Battery tubes is ready to manufacture for BLF Q8, but a group buy interest list will help.
Oh OK then.
Perfect. I’ll perhaps be in line to buy one.
So…
:innocent:
