I wonder if D1 would work just as wellā¦
Oh wow just 3 or 4 days ago nearly 1000 pieces were in stock.
Pop your multimeter in continuity mode and give it a try!
It appears the 5-pin variant (if it is actually a variant. The datasheet doesn't show any other footprint) will work with XP boards.
Now to hope they are of a decent bin. Will try to attempt to measure that tonight. Never have tried to before.
Thatās what I was thinking of doing next we will see how it goes
Thanks ImA4Wheelr
I noticed both footprints are the same.
I will buy 3 to testout
You may want to hold off on that order. I'm getting lousy measurements. Higher Vf's and lower calculated lumens then both djozz and koef3 reported. Please keep in mind that my lumen calculation could be way off as I haven't really spent much time working on my integrating tube and have never measured a bare emitter. I hobbled a set up just a bit ago. So there is all kinds of potential for errors. Conversion factor derived from maukka calibration lights.
Current | Vf | Lux | Lumens |
1 | 3.14 |
364 | 245 |
2 | 3.49 | 617 | 415 |
3 | 3.78 | 814 |
547 |
4 | 4.04 | 955 | 642 |
5 | 4.31 | 1040 | 699 |
EDIT: Improved the setup up. I was losing lumens around the heatsink. I resolved that a good bit, but am still losing some lumens. My new measurements are as follows:
1 | 3.14 |
445 | 305 |
2 | 3.49 | 763 | 523 |
3 | 3.78 | 1009 |
692 |
4 | 4.04 | 1186 | 813 |
5 | 4.31 | 1290 | 885 |
That Vf seems way too high for this LED at max brightness.
I definitely was a bit disappointed in the Vf results. The reading seems reasonable according to the bins listed in the datasheet. Used a DPS5015 to provide power and to measure Vf. Used about one foot of 18 gauge leads. Didn't see signs of thermal sag.
I will remeasure tonight with a meter directly on the emitter.
That explains it partly. Your meter will probably measure lower values.
You weren't kidding. I was expecting a small difference, but was surprised. I verified power supply readings at the power supply terminals, no problem. Then measured at the emitter pads. I read 3.02, 3.23, 3.42, 3.60 , and 3.80 volts at 1 through 5 amps, respectively. Good news from an emitter efficiency standpoint. Thank you for sharing your observation The_Driver.
Those values are realistic. The LED is probably brightest at 4-4.7A.?
Thats great! who can make a distance ring for black flat?
The GT mini also has same body setup like D1S. 5 black flats ordered last week and I will put one in aa GT mini, one in a Convoy L2 on led4power MCPCB. And maybe one in a modded Convoy S8 to see what throw I can get from a small tube light.
On C8 you can get up to 300kcd with 1000% perfect focus and a āgoodā Black Flat .
You misread it. S8 not C8
Small tube light like S2. Basically it already has an S2 smooth reflector and a dedomed XP-G2 now with 3,15A 9x7135 driver and AR coated lens. It makes 22500 cd in that config.
Oops , sorry Zozz
No problem. It is not a small tube light what came in peopleās mind first when talking about black flat mod
The HaikeLite MT07S - HI seems like a good candidate for this emitter for any that don't want to electrically insulate under the emitter base. Looks like you would just need to use plastic screws to keep the driver from grounding to the host. Maybe a piece of kapton tape under the 2 driver screw a points for extra measure.
Pluses:
- Smooth reflector.
- The light would already have a large XP emitter base.
- I'm assuming a buck driver? Just sense resister to 4 or so amps. Should have good run times
EDIT: Fixed some typos & added content
So I reflowed it perfectly on the board and it work nicely.
Wanting to use FET driver but is it too much current for this led?
Other review state the max it can handle is 5.4A
