Novatac flickers, low battery, full battery, primary battery
yes, about half of a CR123 Primary
they last a long time for me, as I dont use the maximum mode hardly at all. Most of my use is below 20 lumens and indoors.
Firmware versions are a new topic for me. I dont know what features they offer. Will be curious to learn more from you about that.
It’s mostly hidden features, like a supposed better efficiency…also some change in the programming, the way the menu work the way the low battery indicator works. Also bug corrections !
I don’t know much about that, you have some details,on the HDS website, I can only see the visible part of the iceberg : electronic lockout, low battery indicator, and starting firmware 2.10 (or 2.11 ?), the soft start when the light has been off for a while. The, you can enter the details of the default programming, tactical modes, etc…I think the last 2.18 offers the best compromise so far :slight_smile:
Ive read that Novatacs have “much ”shorter runtimes”:HDS Systems: Legacy products - Legacy products: EDC Executive, EDC LE, EDC Rotary, EDC Tactical, EDC Twisty, EDC Ultimate, EDC Basic, Arc4, Action Light on the low settings” than HDS EDC models
Novatacs vary widely in runtime between each other too… 4 samples with different runtimes (also not calibrated to the same levels)
pic is a link
meanwhile, I did a little exercise to determine at what lumen level my camera can no longer capture Novatac SPA Flicker… the answer is, above 7 lumens, no Photo flicker… noticeably different scan lines at 0.4 and 5 lumens…
and other fascinating trivia… check out this Driver and UI description, doesnt it sound like HDS/Novatac?
Programming: Each mode can be configured to a one of the 24 available (visually linear) levels of brightness. There are also some special functions which can be configured to any brightnes level, too: strobe, beacon
Battery monitoring: Whenever the battery falls below 3V under load, brightness is reduced (about half). The reduced load usually brings up the voltage a bit. When it drops below 3V again, brightness is halved again - and so on, down to a very low level. It will not switch off and leave you in complete darkness.
thats actually H17f w lucidrv2
I wonder if H17f driver eliminates the Flicker the camera sees on Novatacs?
pic is a link
Well, since the h17fw is using linear 7135 chips, it means the dimming is PWM (although it seems to switch to an only 7135 350mA for the moonlight modes). Maybe the PWM is fast enough so you can’t detect it ?
yes,
it would be intertesting to see a Novatac modded to Triple Nichia, w H17f driver. I believe CRX has built one like that for ven
The H17f driver seems to have some very similar features to the Novatac driver, including 24 power levels that each increase at the same rate that HDS ramping does. And like the Novatac, the H17f driver has a 3v low battery step down… I wonder if HDS drivers are built by Dr. Jones?:wink:
re the PWM, the H17f driver link says:
“16 kHz PWM frequency: Invisible and inaudible.”
the fastest I can detect with my eyes seems to be 2kHz
given that the stock Novatac driver flickers visibly, as well as on camera, my guess is it oscillates at less than 2kHz…, technically Novatac Flicker is not from PWM, its from Constant Current Ripple… same difference, it causes photo interference, and is visible to my trained eye.
Yes, Novatacs flicker in the lowest mode. My Wichita also does this. A guy on CPF who worked for Novatac acknowledged this problem in one of his posts.
I have a few h17f’s Jon, in fact one of my fav drivers all this time on. Not in a Novatac though, I enjoy the beam as is ,with a nichia transplant thanks to CRX. It’s a good general use all rounder for me.
You can detect with a camera, but more importantly not by eye(for me anyway).
excellent info ven, very helpful
@16kHz the PWM on the H17f is outside my vision range too
I can only detect visibly, up to 2kHz, as in my Olight S Mini on lowest mode
Im not as bad a flicker snob as I once was
I even tolerate the Novatac flicker now… in fact, I use it as a “recharge the battery” indicator, since the flicker becomes obvious to me, when the battery goes below 3.6v
I have also figured out which modes on the Novatac flicker Visibly, the most. I can avoid those levels… the 5 lumen, and lowest low, are the worst Visible flicker sources. I can see the dots on lowest mode if I wave the light to check, but, LightWaving is not a primary use for me… LOL… I have mellowed with age, and dont wave my lights as much as I used to… :wink:
Your CRX modded Novatacs have inspired me to pursue a single N219b mod, despite the NovaFlicker features.
I find the Novatac a really fun little programmable… It has one of the throwiest beams in my selection.
My Novatac SPA 120T also likes to flicker on the 5 lumen level when the 16340 goes below 3.6v…
There is deep history regarding various types of HDS and Novatac flicker, here’s Henry talking about it, back in 2008
Some Flicker is Visible to some people, while others wont notice. Separate from Visible, there is also Flicker that can be photographed but is not Visible to the naked eye. I tolerate visible flicker in some lights, because I want to enjoy some of their other features. I feel that way about my Novatac, I like the UI, and I tolerate the flicker.
For reference here is a current model, 2018 HDS Flicker reference
[QUOTE=maukka]I noticed some flicker on the lower levels 1-6 on my light. If someone’s interested in the output behavior measured OTF, here’s what it looks like. Measured levels 4 through 24. Sensor sensitivity / scope resolution not high enough for the lowest levels which also explains the low bit depth on the low levels.” The snob index”:Approximating flicker visibility of 5+ usually indicates that you can notice the flicker if you know how to search for it. 20+ is getting to the distracting territory. The flicker on the HDS will probably never be visible in normal use.
https://imgur.com/a/vWucy5e [/QUOTE]
here is one of the HDS flicker measurements maukka posted in the above link
Here is an Olight S Mini, also from a post by maukka, to whom Im very grateful.
both of those Flicker rates can be visible to some people, but most wont notice.
More like two thirds. Since the voltage is different you can’t directly compare rated mAh, you have to compare watt-hours.
1500mAh CR123 =4.5Wh
700mAh 16350 = 2.59Wh
880mAh 16340 = 2.96Wh
Let’s average the best capacity and best output 16340s and we get ~790mAh.
The Wh of a 16340 with 790mAh rated capacity would be 2.92Wh which is 64.888% of 4.5Wh or ~2/3 the capacity.
I find in my use of 16340 / CR123 lights (not much) I greatly prefer the ability to charge the batteries and the increased output over that ~33% extra capacity. Infact I don’t notice the reduced capacity IRL at all.
The Novatacs are one of my all time favorite lights. Had a few modded ones, modded a few myself. Did the bar trick for 18650.
I lost one and it bothered me so much I sold all but 2. Gave one to stepson and other is still in blister pack.
The H17F driver is a clicky switch driver, I couldn’t find room for a switch.
NOW this new driver that is coming out in the FW3A might be a option.
Make sure your positive spring doesn’t have the end of the spring exposed, I screwed a few into the holes on some cells.
If you do the bar trick, be carefull, I believe its how I killed a couple switches.
If anyone reading this bought I Novatac triple from me and wants to sell it back, Please PM me.
thanks, I like that
I dont find 16340 short lived, I came from AAA
I still use the same levels, under 50 lumens, they just last longer w 16340
thanks for the driver info… Im actually a bit loyal to the Novatac UI atm
Ive been researching triple options, I just learned that
  1. datiLED will mod a Nova to a triple, PM him
    he uses a lathe to custom build a heatsink… quality all the way
2. you can buy a Novatac SPA on Ebay, there are several
here is how one guy rolls his own triple, that has inspired my research
here is the preloaded 219c 5000k board he used for a cheap and dirty mod, no lathe work…
https://intl-outdoor.com/noctigon-3xp-mcpcb-nichia-nvsw219ct-r9050-d240-p-910.html
I would suggest a medium frost optic instead of narrow clear…
Its a great UI.
H17f can be set up to come close. Minus press-hold.
I dont like PWM either, or certainly when i can see it Jon. I can not or will not have a light i can see flicker! Simple as that, luckily most(pretty much all i have thinking about it)that have PWM , i can not see it. To me thats what matters, if i can not see it, no distraction……………not a problem for me. Malkoff(iirc the 3 mode) have PWM, again can not see it.
The 47’s mini have it on high , which i find kind of odd, now and then i can kind of pick something up. But i rarely use max anyway, so no big deal.
As with chadvone, the little novatacs are one of my all time fav lights. I just like the older designs, the feel/look and beam.
Bout time you got a HDS rotary Jon, too add to the family :stuck_out_tongue:
219b 4000k/219c 5000k/219b 4000k
[quote=jon_slider]
Well, I was using cheaper method back then, using Kaidomain’s triple Nichias.
Here’s my second attempt (left picture) using Noctigon and Carclo from Intl Outdoor.
https://www.instagram.com/p/BnTf5FGgcgh/?taken-by=lumenzilla
yes, and a triple Tana Haiku, and a Sundrop
so many lights, so little money… LOL
thanks for sharing info, I fixed your Kaidomain link, I see it was a 4000k N219c
while the one from International Outdoor is a 5000k 219c
Your triple mods are an inspiration to me.
Do you have any preferences between the 4000k and 5000k LEDs you tried?
Can you please also share your thoughts, and a link, for which Carclo lens you like?
You read my mind! :stuck_out_tongue:
lol
I wish Novatac had a battery charge level indicator
Here is another type of Flicker,
the Novatac Low 16340 Battery Warning, its actually a flashing mode, on the lowest setting.
With 1634O detected, installing a cr123 also causes the light to step down to a flashing low mode.
That is the 16340 low battery warning being triggered by a 3v Primary cell.
Novatac battery detection is memorized.
Battery Detection is not automatic.
Here are the battery detect instructions for Novatac.
Battery Detect Reset is needed to switch between Primary batteries and 16340.
NovaTac 85P/120P Flashlight User’s Guide
Copyright 2013 by Henry Schneiker All rights reserved
August 8, 2013
Soft-Reset – fix an unresponsive state or part of a higher level reset. If your light is working normally, turn your light on and unscrew the battery case until the light goes out, count to three and then screw the battery case back together. If your light is in an unresponsive state, remove the batteries for 2 minutes and then reinstall them. Identified by 1 second of dim light. Does not change your settings.
Battery-Detect-Reset – required to detect battery configuration changes. Perform a soft-reset but while the dim light is on, press and hold the button for 5 seconds until your light dims. Release the button when your light dims. Identified by 5 seconds of bright light followed by dim light. Does not change your settings.
How I do it
  1. turn on light, with full battery of your choice, 16340 or Primary
  2. unscrew tail cap a couple of turns, til light turns off
  3. Hold the button and screw tail tight (hold button because its easier than trying to catch a 1 second dim light signal), keep holding for 5 seconds of bright light, let go when the light goes dim.
done!
Novatac Gold Storm Flicker report
Today My Storm decided to inform me, prematurely, that it would be good to recharge the battery:
Thereby becoming a candidate for a driver swap, possibly to H17f… or signal spring eliminator:
HDS decided to turn the Flicker into a feature, not a bug, lol
update
upon further investigation, suspecting a problem with the signal spring shorting to ground, I slapped the light around a few times, and she got turned ON! I just cannot abide a masochist, so I grabbed a Q-Tip and some Alcohol, and proceeded to rectify the situation.
Problem solved.
Note dirty contacts, and flicker, are a documented point of failure in HDS designs that use a signal spring such as the B42 and U60 that preceded the Novatac:
B42 manual https://www.hdssystems.com/Products/Legacy/EdcBasic/EdcBasicUsersGuide.pdf
“Note: you may notice a slight flicker on the Minimum brightness setting. This is normal. “
U60 manual: https://www.hdssystems.com/Products/Legacy/EdcUltimate/EdcUltimateUsersGuide.pdf
“Note: you may notice a slight flicker on the very low brightness levels. This is normal.”
elsewhere in the manual, in reference to low batteries it says:
“The same behavior can also occur if the battery contacts become dirty. Gently wiping the battery contacts with a clean dry cloth is normally sufficient to remove dirt. If in doubt, please replace your batteries.”
So I decided to clean the contacts, and after that I could no longer turn the light ON by slapping it.
Note to self, too much lubricant can ground the switch signal wire erratically…
fwiw, I have also had twisties become flickery and unreliable after too much lubrication, and the solution was the same, clean the contacts…
this is not an HDS/Novatac specific issue… Too Much Lube is Bad!
Just checked my Novatac 120E. It has horrible flicker,buzz, noise, etc etc.
Doesn’t matter what cell or what battery configured.
Might make a good host for a mode someday.
