I kept the stock driver :
1/ It has to be reliable and not burn pockets, so no high power FET based driver
2/ I wanted to keep the rechargeable function
3/ Itās powerful enough for my use
Oh so you just wanted more flood and better tint. :+1:
Couple of tritium switch mods
And a couple of lighted switches.
Nice mods CRX! I have a weak spot for that Ultrafire zoomie, ultra-cheap for what you get, well made and they have put a lot of thought in the design, only draw-back, for the size it should house a 18350 cell.
Is that RVS light an old-school light from dx back in the days? Fandyfire perhaps?
Yeah the Ultrafire zoomie is nice, compact chubby
I modded that one for an Efest 1200mAh 16500 cell so thatās much better too but I had to hack together the lighted switch from scratch.
Thatās an Aurora SH-034 stainless steel with the blue lighted tail, cheap mans sinner Think I bought it from Manafont maybe about seven years ago or so, one of my first lights, very well made. Iām in the process of tarting it up for sale.
Yep, Aurora it was
Some of those old lights are still in stock at dx btw, but not this Aurora.
CRX, why didnāt you show it from the start?
Amazing.
Well itās a bit of a mess really, but it works
So we finally get to see the ugly side of a CRX mod, he isnāt perfect!
he isnāt perfect!
Certainly not
To me itās beautiful.
The outside is about beauty, the inside is about function. Both are outstanding (but who am I to judge).
Iām just giving him a hard time because of how refined all of his finished products look. However, if you look at hot rod car types or some other hobbies I assure you the inside is not always all about āfunctionā to some
I stuck a Samsung LH351D in a Zebralight SC64c.
This is a mod I was hoping I could to do as soon as I saw the SC64c was announced, but it took a long time and another BLF member taking the initiative to finally get it done. The stock XP-L2 EasyWhite is ugly enough I returned my original SC64c after determining a mod would be too risky. Recently, BLF member moridin posted about modding multiple SC600-series lights with fairly basic techniques, as well as an easy method of removing the bezel, which inspired me to finally give the SC64c mod a shā¦
Iām jealeaus!
I bet THAT was fun Bob! Nice work!
Today my Uv LED arrived (and a few really nice leds are on its way to me) so i wanted to work out a way to solder the LEDs to the MCPCB (My selfmade hotplate with modded PC Powersupply was damaged because of a broken waterpipe that flooded my workbench a few month back). But i had a few spare heating elements, my old Aluminium Block (i grinded it out of a Amplifier Cooler) and i could revive the temp controller. Using a car battery for the ~10Amps draw and my vise to hold it in place. The right side is cold enough to touch when the left side is above 200Ā°C. Worked like a charm Temp set to 198Ā°C (overshoot to only 203Ā°C with hysterese set to 5Ā°C) . Now i should get a new Powersupply and some kind of case to make it nice.
Thatās awesome Docc! Really good work on improvisation, youāre all set to go into the re-flow business now!
Grinded down the zwb2 filter and removed most of the rough machining marks (where the MCPCB is placed).
Today i reflow the UV led and then i have to wait for the driver.
