I actually broke my wrench when I tried to open the GT. Thing I have to give up the conversion to GT70 now... probably will just break the vice of my Grandfather if I try again to open this Monster :D
Actually came off with only a 5 minute fight. I had him on the ground, and I was pummeling his head with a large Craftsman strap wrench(the rubber straps are new and nice and tacky). I uttered a few vulgarities and put him in a half Nelson. He groaned for mercy, I cursed again, threw all my weight upon his neck, gave a loud yell, and ripped his head off. Not a mark on him, but he was broken, in just the 2 pieces I needed.
Do we actually need new battery carriers for the conversion ? PossiblyDue to some voltage change?
No.
Lumintop tried to reduce the resistance in the springs by tighten them. They made the aluminium base thicker and shortened the rods.
But protected batteries won’t fit any more.
(Protected are recommended for safty and legal reasons: Remember you have 8 chances to put a battery wrong into a cartier. If you use unprotected you should know what you are doing)
I broke my wrench as well! Lol. The fact that I bought it for 3$ from china didn’t help either. But mine broke just as I cracked the head open. So 3$ well spent I guess. Waiting for the conversion kit now.
Mine will never touch oil. I learned the hard way, I keep mine dry and sealed in a ziplock bag, lest they dry out and become brittle and slippery, and not very useful. My oil filter wrench has rotating iron fingers, that the harder you turn the harder they squeeze the filter.
4 bucks at walmart( hyper tough brand) works great
With the change in the carrier design would it be a bad idea to use one new design and one old design in a light at the same time? Not that I would ever want to but how worried do I need to be in case they ever got mixed up or if one broke and replaced with the other type?
Mixing and matching carriers is fine. The external dimensions, such as overall length and diameter, are exactly the same. It’s only the distance where the battery sits that has changed.
My order of these tips came in today. I’m quite disappointed. They have the same sloppy fit as my cheap tips. They also use a liner. I’ll see if the liner slides out tomorrow.
Can you guys that have snug fitting Hakko tips look to see if Hakko uses a liner in them?
So far these look like junk. No snug fit = no good heat transfer. I’ll be returning these.
I think I’ll take my iron down to a Frys Electronics store and look at their Hakko tips next week when I have a day off. They are not too expensive at $6-$7 each, but the drive is pretty far.
