Well, led4power already has 4040 MCPCB’s that might fit better.
EDIT: Oh, imagine using his 4040/5050 MCPCB for the Q8 with four of these. :sunglasses:
Nice
May beat KW CSLPM1.TG. Which handles 6A in pulses (up to 0.1s) and 5A continuously. Has Vf of over 3.5V. But the top bin does c.a. 1800-2000 lm at 6A. The minimum flux of the lowest bin at 6A is near 1300 lm. Thermal resistance real 2.6, electrical - don’t bother to calculate.
And has a non-square die.
ADDED: For a 2 mm² Lambertian emitter, 1400 lm is 222 cd/mm².
That sounds amazing, 200cd/mm2 stock should be like 300+ once we overdrive it on DTP MCPCBs
Can’t wait, this will be a serious upgrade over the black flat, unlike the CSLNM1.TG which is only a slight improvement.
However, it will be many months or several years before we can actually get some of these LEDs.
The CSLNM1 isn’t even available yet in multiples less than 1000
Regardless, laser phosphor is still a better option for ultimate throw.
This LED will be good for normal LED flashlights.
Where to find 4x4 center ring for black flat or luxeon V ?
Led4power not have
Make your own by reaming a 3.5x3.5mm centering ring.
When faced with the need to use a 5050 reflector centering ring over a 3535 emitter, I've succeeded by carefully glueing the centering ring over the emitter board. This glue (for example) works well and any excess is easily cleaned with alcohol.
Cheers :-)
Thanks for idea but other center rings are too high for this emitters. Is not easy shave to focus
Sanding down the centering ring is an option. A bit of trial and error may be involved, of course.
Cheers :-)
When in the business of changing leds in flashlights it is unavoidable to master the art of re-shaping centering rings
Looks like they listened to us! A bigger package improves the performance .
This will probably go in my big thrower. I had been planning to use the LED Enderman mentioned, but this one will be even better.
Looks like they listened to us! A bigger package improves the performance.
And they introduced a neutral thermal pad! Now some praying for the Lumileds 4040 lay-out.
The_Driver:Looks like they listened to us! A bigger package improves the performance.
The other new Osram LEDs that Enderman mentioned already have that. That’s no surprise in this regard.
Can’t wait, this will be a serious upgrade over the lack flat, unlike the CSLNM1.TG which is only a slight improvement.However, it will be many months or several years before we can actually get some of these LEDs.
The CSLNM1 isn’t even available yet in multiples less than 1000Regardless, laser phosphor is still a better option for ultimate throw.
Multiples of 1000 you say? If it’s worth it, BLF can pull off that quantity easily in a group buy. It is rare to see that many bare emitters bought in a GB, but if this new one is as good as it might be, I don’t think 1000 or even 2000 pcs is a problem to reach.
Enderman:That sounds amazing, 200cd/mm2 stock should be like 300+ once we overdrive it on DTP MCPCBs
This LED will be good for normal LED flashlights.Multiples of 1000 you say? If it’s worth it, BLF can pull off that quantity easily in a group buy. It is rare to see that many bare emitters bought in a GB, but if this new one is as good as it might be, I don’t think 1000 or even 2000 pcs is a problem to reach.
They do this because the LEDs are not available yet. We just need to wait.
DavidEF: Enderman:That sounds amazing, 200cd/mm2 stock should be like 300+ once we overdrive it on DTP MCPCBs
OK. I must have misunderstood. I thought Enderman was saying that the CSLNM1 are available, but only in qty 1000 or greater.
Can’t wait, this will be a serious upgrade over the lack flat, unlike the CSLNM1.TG…
LoL!
Is this a 3v led? Being designed for the automotive industry that wouldn’t be my first guess. Why is “boost” in the name?
The_Driver: DavidEF: Enderman:That sounds amazing, 200cd/mm2 stock should be like 300+ once we overdrive it on DTP MCPCBs
Yeah the CSLNM1 is available in 1000+ but there’s no point in doing a group buy for that one when this HX is almost certainly better in every way.
More lumens AND more intensity
Enderman:…
Can’t wait, this will be a serious upgrade over the lack flat, unlike the CSLNM1.TG…LoL!
Lol fixed
It is, same as all their other automotive LEDs like the black flat and the others they make.
This LED will be THE LED for throwers. It’s alsmost perfect (integrated copper pcb would be perfect). No more 12V XHP-35 HI LEDs!
Here is the datasheet.
The brightness curve is very steep. It might even go up to 15-20A.
But unfortunately we will probably need new pcbs for it.
