Have you seen this 3 x XHP70 soda can light before? (similar to Haikelite MT03)
45 posts / 0 new
2100
Hi guys!
After a break of about 5 years, i am getting back into the hobby again!
Found the BLF Q8 and ordered one. Got it at usd 37 shipped, can’t be beaten value with 5000+ lumens and capable of hitting 6000 with spring bypass, good batts? 50k cd, neutral white? Sign me up! I saw the Sofirn BLF Q8 with XP-L HI (100k cd) and it is a really tough call, in the end i still prefer the original one with neutral white.
Ok I came across this puppy. RMB 358 (usd 52). Not exactly the same design as the Haikelite MT03 but quite similar.
Not sure about the driver used. Hence would be unable to confirm the performance.
Any thoughts or anybody can share any info? I wonder if it is capable of around 9000 lumens.
https://item.taobao.com/item.htm?spm=a230r.1.14.244.7c2b3ee0vwN0yc&id=57…
I’ll translate the claimed specs
Dimensions:Head diameter 66mm Body tube 50mm Tail diameter 53mm Length135mm
Weight : 465g
55 deg C for the thermal regulation point
Edited by: 2100 on 09/29/2018 - 05:20
Sillen
Sillen's picture
I’ve got this on order. Ordered Sept 16, shipped Sept 26, still in China according to tracking so a few weeks away. Same light from a few different AE listings
https://www.aliexpress.com/item/Super-bright-flashlight-xhp70-Photograph...
https://www.aliexpress.com/item/xhp70-Photography-video-fill-light-flash...
Product parameters:
Emitter:7070
Aluminum Alloy body with HAIII Anodize black surface Finish
Battery: 4x High Drain >10A button top 18650
Switch: Side electrical switch with big Transparent rubber boot
Aluminium OP Reflector
Ultra Clear Double-sided AR coated Glass lens (99% Light transmision )
Double O rings; IPX8 Waterproof
With standard Tripod hole
Max Brightness:13000 LumensNW ;
Max Runtime: 58 days
Brightness Level: (Digital current regulation)
Low Low: 10 Lumens (28 days )
Low: 150 Lumens (35 hrs to 10% power)
Middle: 1000 Lumens ; (480 minutes to 10% power)
High: 2700 Lumens (250 minutes to 10% power)
Hidden moonlight: 0.6 Lumens ; 58 days
Turbo—13000lumens —-2.5 minutes (thermal control) step down to
6000 Lumens—-2 minutes (thermal control) step down again to 2400
Lumens (300 minutes to 10% power)
Overclocked descent55 degrees 2.4 A-2.6A
6000 Lumens55 degrees 1.4A-1.6A
Timed Temperature stepdown and thermal regulation
Size: 135mm length x65mm Head x53mm body
Weight:460 Gram
User Interface:Single Click-on ; Single Click-off
Hidden Moonlight (press and hold switch in off status; easy to access)
Low Low-Low-Mid -High-turbo (Long press to change
modes ; with last mode memory)
Quick access to Turbo (Double click after you turn
on the light) ; Turbo can be memorized.
Click+hold+flash signal to lockout the light;
loose the flashlight body to unlock.
Switch LED indicator:
100%~50% power: Blue LED on
50%~9% power: Blue LED flash twice every 2 seconds
Blow 9% power: The flashlight will flash fast and step-down to moonlight.
The indicator LED will be off on Moonlight mode to extend the run time.
Internal parts:
40mm Haike Copper DTP Emitter board
20 gauge thick copper+silver wires
5mm thick internal integrated emitter shelf
double silver-plating copper-alloy springs
Caution:
The Turbo mode gets hot very quick!!!!
So do use this light in right way!!! Turbo mode is never a daily-use mode.
Low-mid-High modes are bright enough for daily use
Keep the light away from Children!!!
Tally-ho
Tally-ho's picture
Last seen: 39 min 18 sec ago
Neal
Neal's picture
Last seen: 21 hours 21 min ago
I have asked before
the led not CREE
Chinese led
2100
Thanks for all the info, i know i can always count on BLFers. Smile
I think if it can achieve 8000 or 9000 lumens it is still a very decent light, chinese LEDs or XHP70. Just that the efficiency might be different, though with 4 × 18650 that would not be so apparent except in a few extreme usage cases.
Sillen, do update this thread after you have received the light, maybe you might even be able to do a ceiling bounce test + lux meter and see how it fares relative to your other known lights. Smile
I am also looking at the customised/DIY 夜巡者 Avaritia NA40 but it’s OOS.
https://item.taobao.com/item.htm?spm=2013.1.20141002.3.20e542f90Vg9WA&sc...
Neal
Neal's picture
I have it
https://www.nealsgadgets.com/collections/other-flashlights/products/nigh...
Di_Joker
Di_Joker's picture
Last seen: 4 hours 51 min ago
intrigued by
Sorry for my poor english.
2100
Oh….it uses the 7070 emitter, it’s already in the description, though the listing title is wrong. Gotta go Taobao and search what the heck is that. Big Smile
If i can get it to around usd 40 for 11/11 then it’d be great.
Confirmed with the seller via aliwangwang chat, it’s 7070 alright.
Q3为便携型的小型高亮度手电 采用7070三灯设计.
配合本店动力型电池VTC6 30A放电超,频档可达到13000LM。
2100
It’s might be these….
https://item.taobao.com/item.htm?spm=a230r.1.14.1.db421f63TYGdhh&id=5226...
https://item.taobao.com/item.htm?spm=a230r.1.14.20.db421f63TYGdhh&id=540...
7×7mm die, 7070.
15 watter basically. 1700lm. 5100lm light. Compared to the BLF Q8, ain’t that bad esp if you want a floodier light, could be cheaper though. Big Smile (for me it’s usd 52 from Taobao)
If only these are 20W, then it’d be very decent as well.
2100
No go at current price.
I might as well pay double the price and get double the lumens, same form factor, with a Olight X7 branded + reliable flashlight with more resale value.
mrheosuper
Last seen: 2 weeks 5 days ago
where do you buy olight X7 for 100 bucks
Forgot my pen
Sillen
Sillen's picture
Feelin silly. Got sucked in by 3 x XHP70 in the title. Can hopefully swap some parts out if it doesn’t perform
BlueSwordM
BlueSwordM's picture
Last seen: 3 days 21 hours ago
Ah! Let’s not forget that they are tested at 1.25A at 12V.
Perhaps that is only the tested amperage, and not rated max. The XHP70 is rated at 2.4A at 12V.
So that means the XHP70 clone may be able to push 3000 lumens at its max rated power level. So 9000 lumens may not be far off.
However, the NW version of the MT03 only achieves about 8000lm under load.
2100
Ok it’s more like usd 113, not usd 100. (there is a rmb 100 coupon voucher, can see it when you add to cart)
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.169.702a74...
We then consolidate it with other stuff and ship it over, for normal goods it’s quite cheap even by China standards. Folks in HK, Taiwan, Malaysia etc do it this way from Taobao.
If we are lucky, we might see some Taobao sellers offering either a 10% or even 20% discount on 11/11 singles day, which is a very very big thing in China.
2100
It’s not tooooo bad, esp if you do not own the BLF Q8 or something. \\
Do a ceiling bounce test and see what it can do.
Unfortunately in this case, it’d be very difficult to dispute via Aliexpress’s ESCROW service to get a partial refund. You can try though, if you have the time and can prove with pictures that the LEDs used are not XHP 70.
2100
I believe it’s quite unlikely even though Cree’s spec lists it that way (the chinese usually don’t do it such a way), even the chinese specs show it as 6V 2500mA and 12V 1250mA, 1500-1900lm. 15W
It’s most probably not a 30W emitter, efficiency performance aside.
BlueSwordM
Well yeah.
It’s probably an XHP50 7070 sized emitter looking at the specs. Not bad, but not too good in terms of power density at all.
Sillen
Sillen's picture
Mail’s in! No batteries until this evening. Got my LX1010BS Portable Digital Lux Meter at the same time so will put this next to BLF & Sofirn Q8 and see how we go.
Edit: First impression, it’s brighter than Sofrn Q8. Will have to wait until it’s dark to do an amateur ceiling bounce. Sure gets hot quick!
Jtm94
Last seen: 1 month 4 weeks ago
The 3x XHP70 light that comes to mind is the Utorch UT03 that never ended up happening.
Can’t wait to see how it stacks up to the Q8!
Lexel
Lexel's picture
Last seen: 24 min 30 sec ago
Seems some chineese fake XHP70.2
2100
Bro! Please do that! Am sure many people would be interested. First impressions seems somewhat ok, though it’s not the 9000 lumens light it was meant to be (never mind the Taobao 13000lm thingy).
By the way, pls also do a ceiling bounce with the BLF Q8. I think i read somewhere that sometimes these ceiling bounce tests might favour the more throwy lights and the Sofirn has 2X the cd over the BLF Q8 which in turn probably has 2X the cd of this light.
And besides, it’s in NW (though not high CRI), so how bad can that be. Wink
PS. What batteries are you using? For sure these need at least Samsung 30Qs.
2100
And if you are saying that it is getting hot quick, it might be gunning those pretty hard. Might even be able to squeeze out more with just simple spring bypasses.
edit – actually in some Taobao links, i am seeing some 7070 emitters rated at 6V 5A. So yes, 30W per emitter. There are some which are 15W, 18W though.
Some folks here might even be able to swap those chinese 7070s out with their spare XHP70s within 10 mins or so, don’t even need to change the drivers if they are driving the LEDs decently hard, meaning that with XHP70s the light would be putting out more light while running cooler. The possibilities…..
Then next week after the holidays i might try to get it for under rmb 300. Big Smile Maybe tomorrow even (most of them are already working esp on TB), counting on you Sillen!
Sillen
Sillen's picture
I like this little corner on the benchtop ‘cause it’s all white’ish. I put Samsung S7 between the bowl and the lux meter sensor. S7 using Lux Meter app.
Results are:
D4S XPL HI 680
ROT66 Nichia came with VCT6 from Neal (blinks 4V) 1070
BLF Q8 VCT6 from Oz (Blinks 3.8V) 1200
Sofirn Q8 VCT6 from Oz (Blinks 3.8V) 900
S41 Nichia 250
Rome Q30 Banggood supplied 30Q’s (Measured 4V) 1400
S70S 800
BLF A6 260
Winner
2100
Thank you Sillen. Very useful result for me also, as i’m also looking to get a ROT66 with the 219B emitters.
It looks to be around 6000-7000 lumens stock depending on how you look at it. Not too bad.
Lexel
Lexel's picture
2100 wrote:
Thank you Sillen. Very useful result for me also, as i’m also looking to get a ROT66 with the 219B emitters. It looks to be around 6000-7000 lumens stock depending on how you look at it. Not too bad.
Not too bad?
You can get this from a single XHP70.2
2100
Lexel wrote:
Not too bad?
Not at the price that i am shooting for at about rmb 300 (43usd or below). It would be a practical budgetlight league for sure. There is also a practical side of things as i do not like to use my expensive stuffs out there for “trashing”.
The efficiency with gunning a single XHP70.2 to 7k lumens is already gonna be….. Tired Gonna gain throw of course.
The UI is not too bad, of course it’s not like the BLF Q8. There is not too much duplication to the Q8 in real world apps also as this would be quite a fair bit floodier.
The other one that i am shooting for is Nightwatch NA40, about usd 39. 6000 lumens 3 x SST-40. Another budgetlight that i can really use outside + fit into the pant pockets even more easily, and uses 1 × 26650 so i don’t have to get another set of 4 × 18650($$$) for it.
BlueSwordM
Personally, I would just buy this light as a host.
eas
eas's picture
Thanks for the test. It would be good to see a comparison with the other multi-emitter lights where all have freshly charged cells.
Sillen
Sillen's picture
That’s charging 15 cells all at once. Was too lazy last night. Sad thing is I can charge that many at once even without breaking out the Lii402. What have I become!
Might try out the dedicated lux meter too. It was pretty close to the s7 sub 1000lux but over 1000 lux it started showing much higher readings
2100
3 x XHP 35 HI swap? Haikelite MT09R 3 x XHP 35 but with more throw? Haikelite MT07S 1 x XHP70.2 netural white but with more throw and possibly more lumens?
Economical enough too as long as the light’s base price is low enough. I am wondering if the focus is going to be ok, anybody has come across similar mods? (single or multi emitter)
Thermals need to be perfect though, maybe need a sand-down of the host-emitter surface and using all the known tricks. I think this light stock is gunning ~ 20W to each emitter, thus gonna be overdriving the XHP35 HI decently on the stock driver, which is of course what we want.
Anyway, for single XHP70.2 generally available lights, the Haikelite MT07S gets 4500 lumens in neutral white (usd 52 lowest price that i could get). The Acebeam K60 thrower (88mm head anyway) is 5000 lumens in CW.
Not apple-to-apple comparios, but just for ref.
2100
Talking about low base price, the sellers i have asked on Taobao would not go below rmb 318.
I wanted rmb 268, usd 39 Big Smile A lucky number in Cantonese. Shipping would be part of my consolidated forward order from the Dongguan Guangdong warehouse that i use, ie very cheap. Even without modding, i believe playing with a usd 39 6000-7000 lumen stock light is pretty decent. (might comfortably hit 7k with spring bypasses), comparing to things like the BLF Q8’s best price.
Sigh….maybe i shall wait till the end of the year and try again.
You can do it with just 4 cells and things like the Miboxer C4-12A. 3 amps each channel is possible on the lowest internal resistance cells like the VTC5A till the very last bit.
Pop the used cells into the charger, grab a coffee and within 5 minutes you ought to be able to start on the next light. Smile
