This is an old model. Quite bad in quality.
[quote=Chatika vas Paus]
I do not know if it was already, but I'll paste if someone missed it. It looks a bit like the Nitecore TM36 / 38 clone. !{width:50%}https://ae01.alicdn.com/kf/HTB1ETITsrsrBKNjSZFpq6AXhFXam.jpg!:https://www.aliexpress.com/item/XHP70-2899LM-Cool-White-Light-Stepless-Dimming-LED-Flashlight-Black/32916170735.html?spm=a2g0s.8937460.0.0.10ee2e0eCWiCGM
[/quote]
My main interest is in the X1 Clone. If i can not get it, i will buy the original Jaxman X1 flood!
The Lux P70 looks interesting and it would be something for future projects. Side switch is sweet and the tube is not overloaded with designs. The head design is the same as the X1. One of the best looking lights (in my opinion). So its a no brainer if the price is right and i can find a place where i can get it.
Kaidomain has a new Nightwatch 26650 XHP70.2 flashlight. Compared to the other I posted above, this one is lighter at 260g and doesn’t have a side button and cost $44. This makes the one sold on Enogear a steal at a current discounted price of $35!
[quote=SKV89]
I found this light on Alibaba.com. Seems to have some serious heatsinking and 3 XHP50 inside. The only problem might be the driver with 3 modes and 3120 lumens. It should be a nice host even for 3 XHP70.
I just received it from Enogear and weighed it. It weighs a whopping 363.8g on my calibrated scale (Enogear site list it at 350g). Good thing is most of the mass is in the head, where it is most needed for heat dissipation. The head weighs 257.6g! Surprisingly, it doesn’t feel as heavy as I imagined but I guess it is because of the large size. It is bigger than the Nightwatch NA40SE, which weighs 212.0g and the Sofirn C8F 21700, which is known to have great thermal performance weighing 197.4g. I’m still contemplating whether to put a XHP70.2 or 4xE21A in it. I’m leaning more towards 4xE21A since this thing can probably handle 2,000 lumens indefinitely.
It does have mode memory except for Turbo where it starts at “off”. Turbo lumens at 1s is 2,710 lumens measured with the TA lumen tube. I have the NW version and the CCT is about 4500k-5000k. It’s hard to tell because it has some yellowish (above the BBL) tint compared with my 4500k and 5000k below the BBL tint lights that look alot purer white. I guess the CW version should make more lumens.
Nearly the mass of the BLF Q8 and driven with a XHP 70.2 to around specs. Probably would be able to sustain Turbo at 5 minutes even with the constant hot nights in my country (plus output in medium for a really long time).
Let me share something as well……. I have no idea how good is it. Button looks funky but i suppose you guys have no issue changing it out.
A bit on the expensive side though. usd 42….so i guess nope i’ll pass.
I really have a thing for heavier/solid hosts and lights with decent built. No need to be top-notch, just usable and trouble free is fine. Especially if they are cheap or have good value. I mean, that’s the whole and original point for having this Budgetlight forum. :sunglasses:
Actually it comes with an XHP70. I’m considering buying a XHP70.2 80CRI 4000k N2 bin. This N2 bin is super hard to fine. Infact prior to Kaidomain carrying it, it is unavailable anywhere else.
That’s not so heavy for a 4 cell. If you want the heaviest flashlight host, get the TR-J20. I remember reading people weighed it at 1.5 or 1.6kg without batteries. With those crazy amount of fins, it should be able to handle 10k+ lumens until the batteries run out. I only wish it ran on 4 cells instead of 3 so you can put in some XHP35 HI emitters.
I bought one too. It’s a nice 5A tint also, whereas the Arrow, Mouser, and elsewhere sell unbinned tints so you can end up with nasty yellow/green tint. The XHP70.2 4000k 80CRI M4 bin I got from Mouser is very far above the BBL and the tint is unbearable.
Oh those showerhead floodlights bring back memories! The quality is actually quite usable, believe it or not, and BLFers then did not have any issues with the quality.
I have a Trustfire X100 (7 x XM-L) which is 75mm diameter head, 3+1S tube design. It weighs 700g only though (3S tube) from my own weighing. The head of the TR-J20 looks more substantial though.
The problem is that these TF/UF/SFs do not install a proper ($:money_mouth_face: driver, all these lights were all not driven to its full potential. Of coz when 12pcs of XM-Ls are driven to its full potential, the whole package needs to be engineered properly for it to last, even if the head is spec-ed up to be a 2kg monster with crazy fins. The heat is still going to be phenomenal even with the TR-J20’s amount of fins. I do not think it’s going to be infinitely run even with a 2kg head, unless if the temperature is sub-zero and with a slight breeze, if not the electronics would burn.
Dunk it into a jar of water (till the base of the head, no need to fill her up to the top part) and it ought to be fine though, i have already tried with the BLF Q8.
Later i am going to bring out my X100 and my triple XM-Ls (Xtar S1/Fenix TK-70/DRY) to test on the variable voltage 30A PSU. Its been a while. I think the 26650 and 32650s are done for, 0 volts. Now where are my 18650->26650 conversion tubes.
Yep, the Trustfire TR-J20 “budgetlight host” is a beast, even though it’s very underdriven. I guesstimate it should be around 3000+ lumens, wrt to my 3S driven X100 and the current they both take.
