I have the XinTD L2, and it's not in the dedicated thrower category, it's just a flashlight that can throw. As i have said the reflector it's with about 2mm larger and deeper than the C8 type of reflector. The C8 type reflector (dimensions) can be found on the Shadow TC6 or Fenix TK35.
Being direct driver they will have the edge in throw, that is most C8s and the 980L are direct drive.
Actually the current seems like 2.6A to the LED. That I have been told. My XinTD L2 throws better than my Shadow TC6 which has the C8 reflector, however this is something that is far from a night and day difference, so it's a minimal difference, not something that will leave an impression.
An XR-E would have a less bright corona and spill, which will yield a crisper target image, although with a narrower field of view. I don't hunt, but I do check wildlife at forest edge and for that I prefer any of my XR-E throwers to the XM-L TrustFire X9.
I was actually curious about this precise match up and here are crops of an XR-E vs. an XM-L light (top is LumaPower XR-E w/Turbo Force Kit and bottom is T40CS XM-L) out to 565ft. (172m) at the last column:
To be fair, I think there is something wrong w/the XR-E pill as I only got around 20K lux at 1m (vs. 40K+ for T40CS). Some guy on another thread got 50K+ for the XR-E in this setup.
Me too. Comparing my X-RE (Q5) vs XM-L (T6), there's just no competition, XR-E clearly beats XM-L in light "crispness". Which is essential for long throws. The narrower beam maintains your night vision better too.
XM-L spill out a LOT of light, but also spill them out all over the place. Long range wise, it makes the target a little more blurry than the XR-E.
The MPP 1 is going to out throw a lot of big hit lights, it's just not going to light up the target as well.
The XinTD L2 is slightly brighter than my M8 but the M8 out throws it noticeably.
Honestly; when you consider throw, demonstrated reliability, ruggedness and price, you could do a lot worse than an M8. A lot of people here own one and it is a respected flashlight. For the demand criteria listed, this is not the time to experiment with an unproven design.
Of course there are other proven designs that would do the job . . . .
This is exactly why I ask recommendations, you guys always seems to know what parameters can be questioned to get the most for the least amount of $$$.
I think MPP1 can be one option, even if it does not have XM-L.
Good throw, fair price, good quality and good selection of spareparts make it worth thinking of.
Does it make a difference in brightness when driven only with 1 x 18650?
What would the euntime be like when used with 2 x 18650?
The MPP 1 works up to 16 volts so, it will actually run up to 4 18650s. It is pretty well regulated with only a small brightness increase with more batteries. I'll have to go find my old MPP 1 review - can't remember how many amps it pulled but if it's like most Solarforce lights, it's probably a little under-driven. Run time therefore with say, three 18650s will be quite a long time. It does make for a long flashlight, however and of course, 'tain't the brightest thrower there is.
One thing I will say; some of my flashlights have serious wow factor when it comes to sheer lumens but nothing in my humble collection throws as far as the MPP 1. It has phenomenal reach.
At work now so just shortly:
had some talk with my friend. XR-E might do it but we will think about it.
One chance is, that I’m maybe ordering Xin-td to myself, he could test it to see, if it has enough guts.
Yes. It comes with two tailcaps. The tactical switch is high mode only, on/off and is the brightest setting. If you are in a hurry, Lighthound will ship it out immediately and you can expect delivery in 2, maybe 3 days. With discount, it is only about $5 more. SF Sales ships pretty quick too though, 6-10 days.
Really nice quality light. I love mine. Versatile too, can run on 1 battery or 2. 1 battery mode is slightly less bright, but hardly noticible. Foy's review on the light is excellent - biggest reason I bought it. Well, that and it is a damn good looking light.
Edit: You know, it's really nice to talk about flashlights for a change, ain't it?
