Where did you buy it? If you just received it then I would complain to the store. It is defective and you should be compensated at least a few bucks in order to purchase a replacement driver (or firmware flashing equipment).
I would have done same with mine if I noticed the problem immediately after receiving.
Same here, you won’t get any complaints from me I also like the speed of the mode group selection – the less time I have to spend configuring my stuff, the better.
I just received an orange s2+ with Biscotti. I just set it to mode group 2 and it has no memory so this one is working fine. 2 out of 3 working OK for me. I got a partial refund from Simon for the one with the driver issue.
I like it faster too, but widely-sold stuff generally needs to accommodate the lowest common denominator. Some people have difficulty with it blinking too fast, so I intentionally made it slower than I would for just me.
Simon offer to send me new driver. I prefer discount for nexr order because after the orange one I ordered cyan and desert tan with same driver and violet with old one. Orange S2+ came first, others are on their way. Let me see what will happend when they arrived.
OK so looks like it wasn’t just me who was affected by this issue. I never did chase up Simon about this but if I get another one that has this issue I will as I don’t like memory mode. (I only buy Convoy from Simon directly)
I’ve resorted to setting the faulty driver to mode 12 (100% only) and left it at that. Reflashing the driver is beyond the time and effort I’m willing to put into it.
The saga continues apparently. I just received the brand spankin new S2+ with the SST20 and it’s got the super fast strobe and mode select going on. I got a C8+ as well, and it works at the correct speed. I’m not going to try enabling memory mode on the new S2+, because knowing my luck, It’ll get stuck there.
I contacted simon, expressing my annoyance that lights with a known issue are still being shipped. I’ll update if he replies.
I kind of wanted a OP reflector version of the S2+ as well, but I don’t really want to risk getting another weird one. I’ve been kicking around the idea of buying all the parts from MTN and building one with one of their guppydrv drivers instead.
Yes my S2+ with SST20 which arrived a week ago seems to have the faster flashing firmware aswell.
These days I try not to change modes too often, and am very cautious about accidentally pressing switch through the second “buzz” for fear of memory ‘jamming’ another driver.
I will still buy from Convoy and support Simon but the drivers are definitely the weak link in these lights.
I don’t really care about the speed. My issue is that, according to ToyKeeper, the speed may be an indicator that the memory bug exists.
I worry I may click on the second flash rather than the first when changing groups and trigger memory mode by mistake, which seems even more likely given the speed at which the flashes occur on the “overclocked” driver.
The reckless part of me wants to just enable memory mode and see if it has the bug or not, so I’d know for sure. The slightly more rational part says don’t do it, because then if it is broken I’d have to hassle with trying to get a refund or replacement through aliexpress/simon.
