GB Clone Offically "SOLD OUT" 10/21/18 XPL HI 1300LM Focusing AKA Cometa 2016
anyone know if that 26650 cell is a quality cell? Waiting for the 1st arrival in the USA :slight_smile:
Finally got my two cometa, they were nightmare until i disable the moon mode and other modes. Now they are pure 1300lm turbo mode. The buttons are very sensitive, a light tap can change level accidentally, now not so much such problem.
Very high quality light indeed. After checking don’t see any risks so i used them as stock at the moment.
Problem1: one of the oring is over sized, can’t tighten battery tailcap fully, it is 3B version having this problem.
Problem2: not sure why sometimes one of them can’t be switched on. I have to tighten the ring in the tailcap, more reliable now but still can happen.
The reason of problem2 seems to be the button stick to tapped position, cause the light on switch still on and flashlight output off. Light tap would unstick it from tapped position and flashlight output on successfully.
I also disable Medium press now, no more blinking mode accidentally.
How do you disable “other” modes? Is Turbo the only mode now?
While flashlight is on, tap until no more light from front led, and it will enter configuration mode. Yes Turbo is the only mode now, nice! Details is in link below:
http://toykeeper.net/torches/x6v2/manker/bistro.txt
Thanks for the link. Didn’t know ToyKeeper has her own site now.
No problem. I also discuss thermal protection now because not knowing how factory calibrate it and lazy to recalibrate it. Just play it carefully.
what a crap my order from weeks ago got cancelled today
Unable to enter Configuration no matter with many short clicks. Is there a trick? What’s the indicator that you are in Configuration?
With mine I just half press the button when turned on just enough for led to go off (not click the switch ) around 17 part presses , then it flashes once followed by a rapid flash, this is option 1 (muggle mode on/off) if click off now it will swap the option 1 setting.
If you don’t do anything else you then get 2 flashes followed by rapid which is option 2 (mode memory on/off) click after fast flash to swap state.
The mode group is 4 flashes then fast flashes then half press again not click it will flash once again if you click off now it will change state to a single output of maximum with no lower modes.
I have mine set to turn on at full power every time with 3 extra lower modes.
Sorry, I missed your suggestion, but I believe you’re right; as the XHP35 drivers suggested were too big, I have ordered 2 of these, similar but with different firmware same as the cometa BLF X6 X5/ Taschenlampen-Treiber Astrolux S2 S3 SS SC Sale - Banggood Deutschland-arrival notice-arrival notice
Lexel, you’re welcome to my spare (once the driver arrives to fix it) if you wish; assuming postage doesn’t exceed the value of the torch, if you send me your address i’ll send it over.
Arrival in the USA! Received my Cometa this afternoon. Everything is looking great. Popped a cell in and everything checks out. I believe I read that the mcpcb moves around? Is it supposed to? Mine does. Any harm in that? Battery was inside the light and charging as I type.
A picture of my Cometa from the GB and my recent order. Dueling Cometas! No difference of course. An unbelievable purchase at this price point, all would agree. Wish I had a reason to have purchased MORE!
The trick is look at the output from front led, there will be no light from it when it is ready to enter configuration mode. Because of moon mode, it might make it harder to detect this correctly, so you can try to do it in a darker room.
1.Switch on the light by clicking all the way in, make sure front led has light
2.Short tap on switch, the front led light will blink and change to whatever levels because of the short tap, keep short tap for 10+ times, front led will stop having any light, when that happen, stop tapping. (I think it’s about 3 seconds to complete 10+ short taps. Don’t do this too fast nor too slow.)
3.Front led will start blink+buzz to indicate it is in configuration mode. Blink 1 time + Buzz means it is in config 1, Blink 2 times + Buzz means iti s in config2, etc.
4.Short tap when it Buzz to enter the specific config.
I tested the included cell with my opus charger , it gave a capacity of 5206mAh which is bang on what it claims on the cell (5200mAh).
Well, i received the free 2x 18650.
They even have a protection circuit on the bottom.
Hope to get the Cometa soon.
…would be nice to get rid of the engraving though…
How to make “cpf italia” and “2016” black?
I think i will have to wait a long time for my light :cry: .
Ordered on 23.09. Got the shipped message on the 27.09. Today i checked because still no tracking update and the new shipping date was the 30.09.
I think they say its shipped so you can not cancel the order anymore. But when the package really is leaving the building is something totally different. Had hopes that the package left china before the hollidays, but it seems it is still there and will be another package thats added to the backlog.
But my early Christmas Gift arrived yesterday (Thanks to DB Custom). I put a XM-L and a 219C for size comparison besides the SBT-70 that is now waiting for the MCPCB and the Cometa.
Sharpie? :slight_smile:
My two Cometa’s arrived, I checked one and it works. Nice Vappower batteries too. These hosts are going to be fun, never had a Cometa or Jaxman Z1 before :slight_smile:
Superdeal!
I got mine yesterday with vappower cell. It has driver insulator correction and a floppy head. But for this price no complain.
