Imalent MS12
94 posts / 0 new
Gebe
Last seen: 20 hours 42 min ago
Another great “budget” light!
Flashaholics
Flashaholics's picture
Last seen: 2 hours 18 min ago
DENGOH wrote:
Flashaholics, thanks for testing it out again. Was this 84c at 10th minute or shorter time? I think it is reasonable fan started later than first test since it is colder to start from.
I started measuring from about 6 mins, 81c to 84c over 3-4 mins etc, heat doesn’t go up that fast once the stepdown occurs. I don’t know if the fan is keeping it stable at 15,000 or the sheer flashlight size.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - https://www.youtube.com/c/FLASHAHOLICS_GB
DENGOH
DENGOH's picture
If we look at Matt’s video review that he tested at just 15000lm, temperature was still increasing after 20min where it reached 70c, also output was dropping gradually to about 11000lumens in the test, I think it’s mostly due to output drop and sheer size of mass, the fan does not help much.
By the way, do you feel obvious hot air flow during your test?
cool i'll see you when you get there
Flashaholics
I felt zero air enter or leave the light.
DENGOH
DENGOH's picture
Shocked Looks like Imalent successfully design a mini convection oven, in wrong product though Facepalm .
KawiBoy1428
KawiBoy1428's picture
Last seen: 53 sec ago
That is why they went with the first Gen 70’s they take longer to COOK
KB1428 “Live Life WOT
Jerommel
Jerommel's picture
Last seen: 8 hours 56 min ago
So they build a light that blinds you with the spill reflecting on the ground, and then they forget to research how you implement a fan..
The bit of airflow outward gets immediately sucked back in by the inlets, apparently…
DENGOH
DENGOH's picture
Ya, i think this one can really cook, 80+ degree celcius external temperature can really cook something. Wonder what would be the internal temperature. Question
DENGOH
DENGOH's picture
I was thinking this morning could it be the fan spinning too fast compared to prototype. Don’t know why Imalent engineers can accept this kind of active cooling with minimal airflow?
Jerommel
Jerommel's picture
The faster it spins, the more air displacement.
Maybe they forgot an air intake altogether…
mortuus
mortuus's picture
Last seen: 53 min 32 sec ago
hm where does all those hundreds of watts heat go then? makes no sense…. If hot air just is trapped inside that light will not function well in the long run. That much heat must vent and go out and not stay trapped, its like a furnace in there..
Like i said there is a reason olight and now acebeam ditched the internal fans, i doubt imalent have made anything groundbreaking with that fan? it doesnt sound so atleast too me..
...where Frugal meets with Flashlight!
DENGOH
DENGOH's picture
Heat can be transferred from one place to another by three methods: conduction in solids, convection of fluids (liquids or gases), and radiation through anything that will allow radiation to pass.
So now it has conduction from mcpcb to light head, and radiation from light head to surrounding, but not much convection due to ineffective fan design.
DENGOH
DENGOH's picture
Basically all non-active cool flashlights don’t have much convection unless user blow an external fan on the flashlights. MS12 supposed to make use of convection to transfer heat away with air.
JasonWW
JasonWW's picture
Last seen: 10 hours 20 min ago
Right, all flashlights use convection (unless they are in a vacuum), but it’s relatively weak. Using a fan is called forced convection. It greatly speeds up or helps the heat transfer.
Even though other MS12 users show air entering one side and exiting the other, it’s not a straight forward flow. The fan style they are using just seems odd. I’ve never seen that style of fan used like this before. The only thing close was the FB1 below.
In fact, here are all the airflow patterns on the active cooled lights I know of.
The prototype Olight X9.
I’m guessing on this Microfire due to lack of data.
The protoype X70. It had 3 fans so it looked like it had 3 dividers using 120° of the diameter. So it had 3 inlets and 3 outlets.
The new version of the X70 has the external fan and “looks” like it has air blowing across the exterior.
I am still guessing on the MS12 design. Their fan style and layout is very odd. I’m guessing they are using a divider to get the air to go in one side and out the other, but it’s not working very well.
Click this to go to signature links.
Jerommel
Jerommel's picture
Used in laptops a lot.
It’s a centrifugal fan. Picks up air in the centre and blows it out the outer perimeter.
It basically spins the air that’s in there and flings it outward.
Very effective.
Vacuum cleaners work that way too.
JasonWW
JasonWW's picture
Very effective.
Unfortunately it doesn’t seem to work very well in the Imalent…
You misunderstood me. I’m familiar with all fan types, but centrifugal is not often seen inside flashlights. The FB1 uses a centrifugal, but it’s orientated differently.
mortuus
mortuus's picture
Yes the type of fan in the middle of the light makes no sense to me, it doesnt seem like its magical just sucks the cold air from one side and throws out all the hot air on the other side, if it was that easy other light makers would have figured that out long before imalent, it doesnt take a rocket scientist to figure that out.
Would be interesting see the inside of the head if there are air channels or something to get the flow out somehow…
Theodore41
Last seen: 3 days 15 hours ago
They have to call a aerodynamics expert to fix the problem. Smile
DENGOH
DENGOH's picture
Imalent should be held responsible if this flashlight burn someone accidentally. To be king of lumen it must also take care of user safety. I can’t imagine those who has less flashlight knowledge paying full price and get themselves a dangerous tool. If buyers think MS12 gets too hot in such a short time and request return for refund, would Imalent accept return? Sport car that can accelerate very fast will also brake to still very fast, it’s safety that is utmost important.
Flashaholics
I think Blippi at ASF got 71c for his heat test at the head, kinda in the middle of the 3 tests I did. I’d be interesting to see if that was from a full charge.
Bridgtec commented his fan was quiet which seems odd.
M4D M4X
M4D M4X's picture
Last seen: 46 min 44 sec ago
did he ever say something negative in his reviews?
I think the Fan design is not perfect
but before I post my conclusion I need to open the light to see if it's fixable or not.
the MS12 and R90C are 100% not toys and should handled with care!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Theodore41
What do you mean exactly?I ask because I’ll get a R90C.
I pass MS12 because I have the DX80 which is more than enough for me.
JasonWW
JasonWW's picture
Flashaholics wrote:
Blippi at ASF
Are you calling Matt/Vestureofblood Blippi? Where does this name come from?
Jerommel
Jerommel's picture
Not toys ?? Party
Well, not children’s toys, that’s true.
Flashaholics
but before I post my conclusion I need to open the light to see if it’s fixable or not.
He mentioned the MS12 needs a layer of polystyrene over it in the box to stop the lid denting.
mortuus
mortuus's picture
Jerommel wrote:
Not toys ?? Party Well, not children’s toys, that’s true.
toys for big boys then.
dave_7
dave_7's picture
Last seen: 1 year 4 months ago
I’m not convinced, that Imalent MS12 can be really worth more than 400$. I saw video with turbo mode and saw the other videos with Professional Police Flashlight and I can write – this one can be much better than Imalent DX80, but not for this price.
JasonWW
JasonWW's picture
Worth or value is all relative. If it’s not worth $400 to you that is fine. It is worth it to some people, but not others. This is just the way things are.
dave_7
dave_7's picture
Yes, I know that is not flashlight for daily use and you can always put there some Swarovski crystal and sell it for 1000$. I just only wonder, who buy flashlight like this one.
JasonWW
JasonWW's picture
Several people on BLF have bought them. I kind of see the appeal. It’s super bright and awesome.
It’s the little 18650 lights that people buy for $300 that make me scratch my head. Ughh
