turn the switch to the 10A position. 180° from this. And plug the red wire to the empty hole next to 10A position. Put the red probe to tube edge and the black to battery and then turn the flashlight into turbo and read the numbers.
BTW with long wires you will reading low numbers because at over 4-5A the wires act as a resistance in the circuit. So the best way to measure high power flashlights is a clamp meter.
I replaced the original MCPCB of my C8F 21700, with one I had purchased a few months ago from Sofirn on which I put 3x XP-L2 (UU640H) ,
Now I get almost 3300 lumens(@CRI90) , and almost 13A at the tailcap.
If you are interested in measuring amp loads I would recommend a meter like the UNI-T UT210E for about $25-$30. Measuring the amp draw is a good way for people to compare outputs.
Nowadays we have homemade lumen tubes and integrating spheres to measure actual lumens.
Another thing I love about my Sofirn C8F 21700 is that it can run the cheap Tuofeng 18650 2600 mAh and still be very bright. The brightness with the Tuofeng batteries still reminds me of the Olight SR90 in terms of lighting up a room brightness.
Sofirn is number one for me. :money_mouth_face: Solid budgetlight. Above and beyond. :+1:
I had a chance to compare the Sanyo UR18650NSX 2600mAh against the LG MJ1 3500 mAh. The runtime is definitely solidly longer with the LG. This means that if I want long runtime at a good brightness level in my Sofirn C8F 21700 torch, I should purchase the Samsung 50E 5000 mAh battery which is currently $9.95 from Battery Junction or $9.99 from IMR Batteries.
Ah, it’s good to see the 50E is now being sold at more places. Other good high capacity 21700 are LG M50 and Samsung 48G (the 50E is designed to replace the 48G).
