What did you BREAK today?
Hello To all, My reason to join you guys here...
I just broke my week old new OPUS BT-C100 today by insering a charged 18650 reversed.
Sadly I found out that it definitely is not fool proof. The latest fool being me.
It does not have reverse voltage protection....
It still comes on when powered but does not charge as the Q19 is badly fried.
Seems fixable by replacing Q19 but the markings on the Q19 is not ledgable in its fried state so I need you guysā€™ help to find the part number.
The location of the poor little guy is shown in the link below...
https://www.dropbox.com/s/eeh5uth4uuqllod/You_Doodle_Pro_2018-08-08T21_32_52Z.JPG?dl=0
AND donā€™t remove the board from the frame frame of the charger for any reason, you would not want to tak a chance and ruin your disolay connector
Cheers and
Thanks
I was removing a MJD41C power transistor (DPAK) from a CCA so I could test it out-of-circuit. The CCA was conformal coated. I had to remove the conformal coating before I could unsolder the part. Next I had to gently lift the emitter and base leads. Next I heat up the collector tab and the transistor slides off the board. I removed the conformal coating, then I went to gently lift the base lead. I lifted the base lead along with half the transistor attached to it. I killed the transistor so I couldnā€™t test it. So much for that. This was sort of sad because the transistor was doing some interesting things that I didnā€™t understand. I really wanted to take a look at the transistor on the curve tracer. This may have been a missed opportunity to learn something new.
OOpsā€¦
Itā€™s not something I broke, but I just got the news that a close friend of mine that I havenā€™t seen in 25 some odd years since he moved to Florida in 1988 has passed away. I did see him around in 1993 when I had to fly down there on a service call, but ever since then, it was only phone calls once or twice a week. Iā€™m really feeling bad right now. I met him in 1971 and we became instant audiophile friends. Life is short my friends. Enjoy it while you can. One other thing, we worked in the same stereo store as technicans around 1980. He was the best tech Iā€™ve ever known. RIP Dave, Iā€™ll never forget you pal. :frowning:
I was potting my DQG Tiny.
I didnā€™t remove the driver from the host because itā€™s glued and Iā€™ve seen people breaking their drivers during this.
Some glue leaked to the switch area. I cleaned it up, but I couldnā€™t do it fully because I lacked access.
The light worked after cleanup, but a day later when the glue remains hardened - the switch doesnā€™t work.
I used silicone based glue because I thought I could screw something up and wanted something removable. Good choice. Later Iā€™ll try to remove the driver and clean it up betterā€¦but Iā€™m going for vacation in a couple of hours and this light wonā€™t go with me. :frowning:
Clean your LEDs before pushing the TURBO button :-p
Sliced SST20 in my D1S
I dropped my brand new Olight S1R II on the floor. Chipped the back. Had it two days :frowning:
Oh well its ruined so that means I will just have to buy more flashlights :slight_smile:
Ruined because of some chipping?
You are probably trying to justify your future purchases :slight_smile:
It wasnā€™t today, but I finally got time a few weeks ago to take apart the Rii E21 I won in CKā€™s giveaway. The whole reason I entered the GAW was because I had had the gear to flash firmware for months, but never gotten around to using it. Since this was supposed to be an easy host for that, I signed up, and I won.
The pill was only finger tightened in, but I couldnā€™t get it to budge with my fingers, so put my cheap HF snap-ring pliers on it (mistake #1), and the first time I turned it, they slipped off and busted the XML LED.
I already had a couple of XPL-HIs on 16mm boards on order from Simon because I wanted to put one in one of these just for kicks.
Before I got around to it, I broke my clavicle last Wednesday laying down my bicycle on rain-slicked asphalt. So probably no soldering for 6 weeks now.
That might be the case, and I find that if I spend enough time on BLF, it certainly is the case.
Broke a torch and a bone? Man, talk about unlucky. I sympathize :frowning:
Hope the bike isnā€™t broken at least :smiley:
Thanks. Just based on a quick visual inspection it looks ok. But I definitely need a new helmet. The jacket, shorts, and shirt I was wearing were all ruined.
Yeah, I already figured those would be a total loss. At least it was them and not your skin and skull; the armor did its job.
Iā€™m so relieved that Iā€™m not the only one who broke things :smiley:
I killed the MELD-X RGBW driver that came in a light I bought from pinkpanda3310. I transplanted it into a new host with a RGBW XM-L and it worked, but unless the head was unscrewed slightly it just lit up all the dies dimly. Left it on my bedside table and the next morning my son got it and inserted the cell the wrong way, although Iā€™m not sure he got the tailcap back on.
Now the driver just lights up all the dies dimly even when bench testing and Iā€™m not sure whether it was a short or reverse polarity that killed it.
Lessons learned:
  • Never leave a cell in a light with a fault
  • Keep Li-ion lights out of reach of small children
  • Good RGBW drivers are hard to find
Turned a working Samsung TV into a non-working with a preventive replace capacitors job.
my utorch ut10 suddenly died
i think it is the switch - like most of my other lights
it got stuck in a blinking pattern
would not turn off
removed battery
after that it would not do anything
seems like switch
unrepairable as far as i can tell
things are glued in-the electronics[ā€˜driverā€™]
plus surface mount switch would be a pain to find the part and then solder it without burning or melting other parts
- i wasnā€™t doing anything but trying to use it, though i have had it 2 years or so, and i prob use it 40 times a day, so 29,000 switch cycles.
wle
I broke the atrocious stock driver in my Wuben E01 when I drilled a hole through it so I could lever it out. It had terrible visible PWM and a double-tap for strobe which meant you couldnā€™t change modes quickly so I donā€™t feel guilty at all.
Unfortunately I also ripped a component and PCB trace off the cheap single-mode driver I was filing down to fit. Now Iā€™m left with a non-functional E01, but to be honest I think thatā€™s still a win - the stock driver really is that bad.
If anyone knows a source of tiny multi-mode boost drivers please let me know. I know MTN sells Lumintop Tool drivers, but postage from the US makes it too expensive.
I havenā€™t broken anything in a while. When I do, Itā€™s usually bonesā€¦lol.
I may have overdriven the white flat in my Jaxman Z1...
I broke my rose gold S1R Baton II. Did an emitter swap en didnā€™t remove the cell when I solder the MCPCB back into the light. I shorted something. FFS
