We have a few stock ROT66 with minor machining flaws or scratches available, those lights perform perfectly in function. If anyone have interested, please send me private message or email to ff-light@hotmail.com
I noticed on Facebook the other day the ROT66 is now “officially” shipping with Anduril, and the Fireflies site reflects that. Since the firmware status has been up in the air for a little while, can we can a definite confirmation all models (including XP-L) now have Anduril?
I was happy to see there is now a “no glue” ordering option. Does that apply to the driver as well?
Has anyone with an order number earlier than #243 received Anduril or a no-glue light? (I ordered a 219b, and asked for those options in the comments before they became standard)
Edit: I got a response; mine will have anduril but be glued. So if anyone wants to know whether theirs will be whatever, compare the order number.
Just try something that is different from NarsilM. If click click hold goes to a blinky mode, it’s Anduril. If 6 fast clicks go to muggle mode, it’s Anduril. Try 3 fast clicks to go to battery check, then 2 fast clicks should be “sunset”. If so it’s Anduril. If it blinks 1.2 or 1.3, then it’s NarsilM. Try cycling through the blinky modes. NarsilM us strobe, alternating strobe, bike light, 2 second beacon then 8 second beacon.
Thanks for the info. So these two versions of Anduril are both configured as 3-channel (7135x1, 7135x6 or 13, FET), right? Then may I know the exact level of 7135x1 100% on the two versions? I suppose that level should be also PWM-free and can be pretty useful in some situations…
It will be even better if you are able to upload the ROT66 specific header files to your firmware trunk so I can figure it out myself
When going to the (stepped) ramp ceiling from off directly (two clicks), the light may regulate itself to an even brighter level (because target_level is set to MAX_LEVEL?), especially when the ceiling is set to a lower level and enough cooling is applied. However if you go to the ramp ceiling in the other ways (memorize that level and then recall or simply ramp to that level), then it won’t demonstrate this weird behavior.
Not sure if this is intended, just willing to let you know.
Hadn’t noticed this during testing, since the ceiling was generally high enough that it would regulate down instead of up. The fix is a tiny patch though, and doesn’t change the code size at all.
Wow, 7000 lumens, that’s high relative to the XP-L. How long can it last in Turbo before kickdown, is the lumens drop/sag quite a lot? eg at 30 sec, 60 secs.
