Fireflies ROT66 Flashlight
I use liionwholesale. Great prices.
Recently I bought two big orders from 18650batterystore.com. They have good sale items all the time.
@raven+SKV89, that’s not the problem klrman is facing.
It’s two things:
1. The US dollar is stronger than the Canadian dollar.
2. But most importantly, lithium ion shipping is stupidly expensive in Canada.
I agree. I hope fireflies find a way to send you those 3 samsung 30q.
Yeah that is going to be really hard, especially to Canada.
Over here in Singapore, we’d use “sensitive air” option from 3rd party forwarders to ship Li-ion from Taobao. First kilo is SGD 11, subsequent 0.5kg SGD 4. Of course to make the most out of the consolidated shipment, you can send other orders as well, eg other flashlights from other sellers, and then consolidate the shipment before forwarding it to the destination country.
Don’t even think of smuggling in by trying to camoflauge the order (customer raises an order and pays for innoculous item A, ask seller to change the price, seller ships 12 x 18650s :slight_smile: ) or mis-declaring it on the performa invoice. Both the goods warehouse and air freight carriers scan their goods very tightly nowadays. Esp after recent few years some buggers used this route to smuggle drugs.
Normal goods (eg underwear, clothes, toys, kites, faucets) current prices are SGD 6 for the first kg, subsequent 0.5kg 2.
For the super sensitive goods, gotta go by “sensitive sea”, eg neodymium magnets. Cheaper though, but you gotta wait for 2 weeks. And some things like processed foods are limited to 5kg, but that’s due to local regulations and limits, not the carriers or overseas (china) customs.
I believe Shunfeng Express can do it too, but the cost is gonna be eye-popping. Still, probably a tad lower than DHL. :smiley:
Buy a new light + 6 batts, and ask for a discount? :smiley:
If I were a FF boss, I will give a customer 50% off the light and free 3 18650.
Nah. Just offer to pay shipping for 3x18650s for the customer. That is probably going to be expensive for them to ship directly, so that is a good punishment already.
Had to try it out so I broke a four pack of 30Qs into three but for some reason I can't get the battery cage with the cells inserted back into the battery tube? Is there some kind of trick to this? No matter how I try, the batteries slightly protrude width wise and there is no play to slide the cage back into the tube.
I just tried my 30Qs from Banggood and Illumn. There is no way this is going in the rot66 battery tube, it's that tight. I tried to force it a little and now the top side of on of the 30Qs has cut through the wrapping. This would probably explain why they were shipped without batteries on mine.
It was upside down inside mine when it arrived.
Hmm….this “issue” has also been reported in one of the Taobao user reviews i have read. Anyone?
ROT66初版差強人意,以CP值來說算是不錯的。*電池倉裝上電池和筒身太密合* ,按鍵燈斜了150度,九顆燈珠有一顆亮度明顯暗於其他顆….期待下一版會更好。
>>The battery compartment when loaded with batteries is too tight with the flashlight tube barrel
The way I see it, someone at FF sent this light to me knowing the battery tube tolerance is faulty. Too much of a coincidence that they forget the batteries and that the batteries won't even fit. I can't figure out if it is the cage or the actual tube that is the problem, but I'm thinking maybe the cage is not allowing the batteries to come close enough together to fit in the tube.
Try sliding the batteries in without the cage.
On the plus side, maybe FF can send a replacement battery tube with batteries inside. They just need to toss some aluminum caps on both ends and it will be sealed really well for shipping.
Sorry, I missed that. No problem, slides in smoothly without the cage. I thought about loosening the cage screws, but then that really isn't a good idea either.
There are 5 screws total… maybe you can adjust by loosing it little bit… . give it a try…
I thought about that, but having some screws loose doesn't seem like it would be good to do.
Ok, maybe not a bad idea after all. I put the cage under a strong light and I can see some of the cage tubes warping inwards, which would be enough to not all the batteries to sit tight with each other. Going to unscrew and rotate them to see if I can get a tighter fit.
It is hard to explain… hold the right side of the carrier and hold the left side of the carrier at the same time… both sides must able to move or twist…
I observed 2 black pole should be tight and one black pole should loose freely…
You can adjust it using your hand… can you try that method?
Okay, then that means the cage is not letting the batteries touch each other. The battery tube seems to be okay. It’s something with the carrier.
Try shining a light to see if you can get the batteries all touching side by side. I think you are on the right track.
It works!!!!!!!!! Thanks, that did the trick. Having one pole looser made all the difference, thanks Newlumen
Wow is it ever bright. This little light is blinding with the xpl hi.
