:money_mouth_face: Ha Ha….
Or US Stock Market in last 2 days……
Is 2.5A correct? Surely you would need higher amps to get 2100 lumen?
On a single xml2 2.5A will only get you 750 lumen, maybe.
Edit: I will find out and let you know.
@JasonWW, they are literally copy pasting the BLF GT manual everywhere with that 2.5A turbo of a buck driver, not a FET driver.
That’s what I was thinking. I asked TA if he knew what a more realistic amp draw would be, since he seems to be the only person who has actually used one.
Lexel tested an S42 with a 30Q it drew 10A!
Wasn’t that 9,95A number with the stock driver?
Efficiency on the light was abysmal because of the springs having high resistance for a quad 219C setup, resulting in non-negligible power losses and the spring getting hot(that was on my spring BTW, my experience), along with the FET’s specs being subpar for the purpose.
Yes, stock driver. It was one channel FET. It drew 10A, but output seemed a bit low.
The TA based driver is only in the S43 and is a 2 channel FET + 1 design.
Hopefully TA will answer back about it’s amp draw. He told me previously that the output is still around low 2000’s range. It can definitely be improved with spring bypasses.
Besides the Mateminco version being available in copper, it looks like it also gets a different 18650 battery tube with the finger grooves in it.
Lexels S42 review.
Okay, Texas_Ace says about 10A is what can be expected with your typical high drain cell like a 30Q.
If you bypass the springs you might see 15A.
Hey!
available again for members: (M4D M4X DEALS)
and you maybe see those posted elsewhere - always compare my prices ;) ...
Item | Code | Coupon price | better member deal? |
Folomov Portable USB Charging | 59f946 | $10.59 | NO |
West Lake Tactical 20mm Rail | 0f3a80 | $24.95 | NO |
Astrolux MF02 XHP35 HI | 8aadd0 | $79.95 | NO |
BW-ET1 | 51517a | $9,60 | NO |
Astrolux S43 | 9f1297 | $29 | YES |
NITECORE TM10K | 6ab60b | $200 | YES!! |
GT mini | eb4fa7 | $39,99 | YES |
ADEASKA SQ4 | ADASQ4 | $33,69 | YES |
Xiaomi MiJia 1080 | cebd24 | $66.66 | NO |
MINI TS80 | 15b0a6 | $66.66 | NO |
My Amutorch X9 3*SST40 came in today - Thanks Martin and Neal
Hello my dear friends!
FOLLOW THIS LINK TO NEALSGADGETS.COM
-> ask me for the code to save $$$ before oprdering!
check my youtiube channel for some videos... https://www.youtube.com/user/sepp4646/
Holy cow how did you convince them? Are they going to release a NW version of the R90C too?
today i received deals for two very interesting flashlights:
Members can find the deals here: M4D M4X deals
non members can contact me
(the links get you to the shop for more pictures and information)
Features:
Package included:
1 x Fitorch P25 LED Flashlight
1 x 26350 battery
1 x USB Cable
1 x Lanyard
1 x O-Ring
1 x Holster
Specification:
Product name: | HaikeLite MT03 TA Devourer XHP70.2 P2 21000LM CW/NW LED Flashlight |
Brand: | HaikeLite |
Model: | MT03 (New Driver) |
Emitter Type: | XHP70.2 |
Emitter BIN: | Cool white,Neutral white |
Material: | Aluminum Alloy body with HAIII Anodize black surface Finish |
Battery Configurations: | 4x High Drain >10A button top 18650 |
Switch Type: | Side electrical switch with big Transparent rubber boot |
Switch Location: | body side of the flashlight |
Max Output: | 21000 Lumens |
Lens: | Ultra Clear Double-sided AR coated Glass lens (99% Light transmision ) |
Reflector: | Aluminium OP Reflector |
Waterproof: | IPX8 Waterproof |
Color: | Black,White(limited edition) |
Weight: | 620 Gram |
Size: | 130mm length x 72mm Head x 50mm body |
Nice. The price on your site for haikelite MT03 TA is a bit off
yeah - I will correct asap
atm I try to get the baby to make a nap ;)
What does this mean - (new driver by TA)?
I’m interested in Fitorch P25, but I can’t find any info on the user interface; the link to the manual at the Fitorch website is not working.
For the MT03?
Texas_Ace designed a new driver for the MT03 and MT09R. It is a FET driver and uses NarsilM v1.3.
Originally both of these lights used a Haikelite designed driver and UI, but it was under powered and lacked proper features.
i ask fitorch for the manual
I discovered that Banggood also offers the "MT03 II" with a new switch and driver. So which one is the new/better one?
China wholesale Sitemap, dropshIP wholesale from China, Professional Chinese wholesaler for general merchandise on wholesale price.
Edit: The TA-version seems to be a different one. The MT03 II can only do 12.000lm.
They made a new batch of MT03’s? Or is this still the old batch they are selling off? Last I heard they only have a few left and would be stopping production on them once they sold out.
