The Nitecore SC4 charger is a reliable smart charger with manually selectable charging currents, LCD screen and an optomized charging process for IMR batteries. Capable of switching between 3A and 6A output, this charger can be customized to match the ideal charging rate for your unique battery and needs. Equipped with 4 Individual Charging Bays, the SC4 is ready for heavy duty charging action. Compatible with just about any standard sized Li-ion, IMR or LiFeP04 battery as well as NiMH batteries, the SC4 is the the only charger you'll ever need.
With intelligent charging features, using the Nitecore SC4 is as easy as inserting your batteries into the charger - the SC4 does the rest. Both the charging current and voltage can also be adjusted for specialized batteries. A brightly lit LCD screen displays charging status and battery health while built-in overcharging, overheating and short circuit protections keep you and your batteries safe. In the event of a problem, the screen will read "EE EE" to alert users and cease charging.
Main Parameters:
Input:
AC 100-240V 50/60Hz
1A (MAX) 40W
DC 12V 3A
Output Voltage:
Battery: 4.35V ± 1% / 4.2V ± 1% / 3.7V ± 1% / 1.48V ± 1%:
USB: 5V ± 5% 2.1A MAX
Output Current: 3A*2 MAX 1.5A*4
Compatible with:
Li-ion/IMR/LiFePO4:
10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500,
14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490,
18500, 18650, 22500, 22650, 25500, 26500, 26650
Ni-MH(NiCd):
AA, AAA, AAAA, C, D
Product Features:
● Four slots can charge one to four batteries simultaneously.
● The charging current is up to 6A in total and maximum charging current up to 3A in a single slot.
● Using LCD screen with MVA technology to display real-time information on charging status.
● Display the current charge status with a perfect 160-degree visual angle.
● Can charge the external devices via the integrated USB port.
● Multifunctional charger, can diagnose and identify bad batteries, protect against overcharging, improper installation, short-circuit.
● Intelligent charging mode detects battery type and capacity, then select the appropriate charging current based on the battery type.
● The SC4 is capable of activating depleted Li-ion batteries with a protective circuit.
● Coordinate with PID system to automatically control the temperature within a safety limit.
● Energy saving when there is no operation in 3 minutes, the screen will dim to save energy automatically.
● Constructed from high-quality flame retardant and fire resistant PC materials and featuring intelligent temperature monitoring.
Equipped with a USB output as well, the SC4 can be used to charge external devices such as laptops and cell phones. With the price of the $34.88 after applying the coupon code "NTSC4", it is definitely worthy to buy from GearVita. Get it and say goodbye to long charging times: https://gearvita.com/nitecore-sc4-superb-charger.html
Related product:
https://gearvita.com/nitecore-i8-8-charging-slots-smart-universal-quick-charger.html
