You would think someone that reviews flashlights would at least give a reason for such a statement but alas I am not surprised. Wont be viewing this one either because of the way you present yourself on the forum.
Anduril does by default, at least the latest builds Toykeeper has described, have the ramp ceiling set to a lower level - for the ROT66 builds, I think she said the maximum regulated level, so it will be lower for the 219B version than the others.
I suppose whether that’s desired is personal preference, but fortunately, it’s configurable.
The flickering on minimum mode is most likely a combination of how specific 7135’s and specific emitter copies work together. They have a minimum where they don’t function consistently, which has been known about on BLF for years. Some samples are bound to just have a slightly higher minimum threshold and need the floor set higher.
I haven’t disliked or even clicked it so if you see several I guess that is a heads up that I may not be the only one with this view. I could care less where you are from and would stand up for you in that regard. Some of the best contributors on this forum are from Europe and I absolutely support them. You just come across as very arrogant. I could even look past that (see Tom Tom) if your posts were occasionally well written, educated and informed but they tend not to be so here we are.
I’m glad ROT66 chose the 3A tint. I’ve seen some B & C tint 5000k that has yellow. I would consider 4000k - 5000k NW as long as it is on or below the BBL (A and D tints). If you look at 4000k 219B 9080, E21A, or Cree 5A and 5D tint, there’s no yellow and at night time, when your eyes are adjusted to WW 3000k ceiling fixtures, these tint looks pure white and actually a bit on the cold side.
Newlumen, thanks for those beamshots. Those 6500k CW looks like NW in those pics, very nice. The SST-20 and XP-L HI looks the same. Even the tint on the 4000k Samsung looks almost the same as the other two.
Ideal if you’re a one torch guy, I have 80…
It’s getting a chore to set temp control, bypass the ceiling mode which shouldn’t be default, disable the flashy modes, set the desired moonlight level. It’s getting to the point you accidentally press X number of times trying to do something and you have to re-read a 50,000 word User Manual to undo a cock-up.
Thanks JasonWW it worked. Thanks to everyone else for the helpful info. It ramps up much higher now. When I did 1 click for moon mode, it is a little brighter on the lowest setting and the flickering stopped. What's interesting is that turbo is still not as bright as my first rot66 xpl hi, maybe about 25% less bright. I'll put it down to the emitters themselves and call it a day.
I have about 60 but this is my first Anduril. I think it's a bonus to have so much room to customize the settings as much as one would want to. Not everyone has the same needs for a flashlight.
