/* Simple sample firmware for otc less design (single cell).
Half press less than about 300 ms: next mode
between 300 and 900 ms: previous mode
longer: blink out voltage reading
(0 to 255) in 3 decimals
Suggested capacity of buffer cap (C2): >= 47 uF.
Vbatt is connected to PB3 (Pin2).
Voltage divider still connected to Pin7.
Timing specified for Attiny25 at 10 Mhz.
Don't fuse BOD.
Created and built with Atmel Studio.
Fuses for Attiny25: lfuse: 0xD2, hfuse: 0xDF.
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#define PIN_7135 PB0
#define PIN_FET PB1
#define PIN_POWER_DETECT PB3
#define INT_POWER_DETECT PCINT3
#define VLT_PIN PB2
#define VLT_CHANNEL 0x01
#define VLT_DIDR ADC1D
#define ADC_VREF ((1 << REFS1) | (1 << REFS2)) // 2.56V
#define ADC_PRESCL 0x06
#define PWM_PHASE 0xA1
#define PWM_7135 OCR0A
#define PWM_FET OCR0B
#define MODE_COUNT 6
#define PWM_LEVELS_7135 30, 80, 255, 255, 255, 0
#define PWM_LEVELS_FET 0, 0, 0, 30, 80, 255
// forward declarations
uint8_t adc_init_and_read();
void blink_once();
void blink_once_long();
void blink_value(uint8_t value);
void delay_250_micro_sec(uint8_t n);
void delay_50_milli_sec(uint8_t n);
void delay_1_sec();
void led_off();
void led_on();
volatile uint8_t s_clicked = 0;
const uint8_t pwm_levels_7135[] = { PWM_LEVELS_7135 };
const uint8_t pwm_levels_fet[] = { PWM_LEVELS_FET };
uint8_t mode_index = 0;
int main(void)
uint8_t blink_voltage = 0;
uint8_t voltage;
// set LED ports as output
DDRB = (1 << PIN_7135) | (1 << PIN_FET);
// initialize PWM
TCCR0A = PWM_PHASE;
TCCR0B = 0x01;
// enable pin change interrupts
PCMSK = (1 << INT_POWER_DETECT);
GIMSK |= (1 << PCIE);
sei();
// start with first mode
PWM_7135 = pwm_levels_7135[mode_index];
PWM_FET = pwm_levels_fet[mode_index];
while ( 1 )
if ( s_clicked )
if ( s_clicked <= 10 ) // < about 300 ms
blink_voltage = 0;
mode_index++;
if ( mode_index >= MODE_COUNT )
mode_index = 0;
else if ( s_clicked <= 30 ) // < about 900 ms
blink_voltage = 0;
mode_index--;
if ( mode_index == 255 )
mode_index = MODE_COUNT - 1;
else // > about 900 ms
mode_index = 0;
blink_voltage = 1;
s_clicked = 0;
voltage = adc_init_and_read();
if ( blink_voltage )
blink_value(voltage);
delay_1_sec();
ISR(PCINT0_vect)
// disable output
PORTB = 0;
// turn off PWM generation (might not be necessary)
TCCR0A = 0;
TCCR0B = 0;
// ADC off
ADCSRA &= ~(1 << ADEN);
// disable pin change interrupt
GIMSK &= ~(1 << PCIE);
PCMSK = 0;
s_clicked = 0;
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
do
s_clicked++;
wdt_reset();
WDTCR = (1<<WDIE) | WDTO_30MS;
sei();
sleep_mode();
cli();
} while ( (PINB & (1 << PIN_POWER_DETECT)) == 0 );
wdt_disable();
// debounce
delay_250_micro_sec(10);
// activate pwm generation
TCCR0A = PWM_PHASE;
TCCR0B = 0x01;
while ( n-- )
int k = 180;
while ( k-- )
if ( s_clicked )
return;
do
delay_250_micro_sec(200);
if ( s_clicked )
return;
} while ( --n );
void delay_1_sec()
delay_50_milli_sec(20);
void led_on()
void led_off()
PWM_7135 = 0;
PWM_FET = 0;
void blink_once()
led_on();
delay_50_milli_sec(5);
led_off();
led_on();
delay_1_sec();
led_off();
delay_1_sec();
void blink_once_short()
led_on();
delay_50_milli_sec(1);
led_off();
// 100er
if ( value < 100 )
blink_once_short();
while ( value >= 100 )
value -= 100;
blink_once();
delay_1_sec();
// 10er
if ( value < 10 )
blink_once_short();
while ( value >= 10 )
value -= 10;
blink_once();
delay_1_sec();
// 1er
if ( value == 0 )
blink_once_short();
while ( value > 0 )
value--;
blink_once();
delay_1_sec();
uint8_t adc_read()
uint8_t value;
while (ADCSRA & (1 << ADSC))
if ( s_clicked )
return 0;
value = ADCH;
ADCSRA |= (1 << ADSC);
return value;
DIDR0 |= (1 << VLT_DIDR);
ADMUX = ADC_VREF | (1 << ADLAR) | VLT_CHANNEL;
ADCSRA = (1 << ADEN) | (1 << ADSC) | ADC_PRESCL;
adc_read(); // first run not reliable (see spec)
return adc_read();
// empty interrupt function required otherwise mcu will reset
ISR(WDT_vect)
