I have not done detailed comparison but the "black top" TA8133 i got does the same weird things djozz's one does like displaying 0lm when T-10 says 70ish lm, 100lm when t-10 is like 160lm, that plus the difference seem to depend on the lamp type and color wich is a sign that the filter doesn't follow the right curve.
One meter doing weird things might be an error but two meters with the same kind of behaviour sounds like the start of a trend
From a designer point of view its feels like Tasi changed the sensor type without changing the calibration parameters (plus the new sensor+new filter doesn't fit the expected response curve as well as the previous couple did)
Its interesting to see how it is working on Aliexpress.
I think it is save to say that most of the sellers do not have their own stock. They use dropshipping.
How do i come to this conclusion. I asked the sellers only which one they have (I send a picture with a red and a balck one). And i got the same picture from 6 sellers. It showed the black one.
So they asked the warehouse and all got the same picture from there.
So i think i have to search for something else. To bad. The meter was relative precise and that for a very good price.
No, sorry. The good TA8132 was actually financed by Enderman and I promised him to have it if it was any good, I will send it along to him with the bigger Tasi meter. The “good” TA8133 I would like to keep for reference.
No problem! I did not belive that a seller would answere this late. And i was not expecting to get the right picture
Its their last one. And they told me the new ones are the ones with black top :cry:
So i put it in my cart bought it and . . . . payment failed! Thats right. I love AE! Customer Support competent and capable as it gets, told me to wait 24H and then try again.
:person_facepalming: :person_facepalming:
I asked a relative if he could try his Card. The payment went through. Now i hope to get the right Meter. The picture is ok. But i better say nothing untill i hold it in my hands.
At least the seller is having no chance in case of a dispute. With the picture he can not say sorry i did understand you wrong . . .
But i am curious if my next payment will work or if i have to ask someone else everytime i want to order something from AE.
Today a really well wrapped package arrived. When i first saw the cardboard box i was not very happy but the right meter was inside.
Two eneloops are in the charger so i can test the meter.
Next step is to get a styrofoam ball to build a simple integrating sphere (Integrating sphere #4 (the fast and cheap one)).
I know a local shop is selling them but i will have to check the wall thickness. I want to use a 20 or 30cm sphere to be able to measure light up to 70-75mm.
Summary on how things went for my TA8133 bought from BZG Electronics Co,.Ltd on AE :
Received the new "black top" one and after testing it showed the same weird behaviour than the one djozz had tested like displaying 0 up to about 80-90lux then started to increase but was still very bad (bad calibration) + behaviour was not exactly the same depending on light source (poor filter)
Had to send several set of pictures to seller who pretended that it was supposed to work "only with tungsten light" (i bet they don't really understand the specification)
Was offered to receive a new one with the same "black top" picture that TheOnlyDocc received
When i refused i was asked to send a video because my pictures where "not showing the default"
Opened a dispute with AE because i was bored of arguing with seller and that was the only way to send a video
Then the seller insisted that Tasi recognised there was a problem with a batch of luxmeter but that the new ones would be fine
I answered that i was ok to receive one if they were really sure than it will be good, explaining my thought about lake of calibration AND poor filter/sensor matching.
Got no answer from the seller until AE decided for a full refund
It's a pity that Tasi changed the way a good product was made but even if they say that things should be ok again now i would not suggest to buy one until someone has a way to verify calibration and frequency response and are ready to waste time arguing with sellers ;-)
I would love to do that! I asked my uncle but he no longer workes in Uithoorn half the month. Maybe it is possible to compare results when i get the sphere ready. A known led running on a fixed current.
Which sphere size should i aim for if i want be able to measure lights up to a headsize of 70-75mm? Or would it be better (better readings) to get a small 15cm sphere for small lights and a ~30cm for bigger ones?
The styrofoam balls are not that expensive.
If you have the room for it, a bigger sphere has some advantages:
*My 50cm sphere (46cm inner diameter) has a range from 0.001 lumen to 10,000 lumen without using grey filters before the luxmeter. A smaller sphere would get you either a lower range or you need grey filters before the sensor (or connect a small satellite sphere to put the sensor in, but that adds to the build difficulty).
*the larger inner surface of a big sphere makes that the entrance hole takes up a smaller percentage of the inner surface area, so anything happening in the entrance hole that influences the reflectivity of the sphere (like putting flashlights there) causes less error in the reading, and the integration is better too if the hole is relatively smaller.
When you have your sphere ready I can send you a flashlight that I measured both throw and output of, that should give you some calibration to start with.
Thanks djozz! Sounds really great!
Hope to get into town in the next few days. I do not think that they have 50cm spheres in stock but 30 or 40cm is possible. 40cm would be a good size (would fit on the wardrobe in the bedroom for storage).
I can confirm I received a “bad” black top TA8133 inside the packaging for a good one from this seller. It seemed to be working reasonably well during informal tests, but my calibrated BLF-348 read extremely low. I did some further testing and discovered under about 60 lux (from my known “good” HS1010A) the reading is fixed at about 19.6 lux. Seriously :person_facepalming: Above 85 lux it becomes reasonably linear with the HS1010A, but continues to rise. It can also be exceedingly slow to settle on a measurement.
I’m pretty curious how my HS1010A stacks up to a nice lux meter. It’s cheap, but I haven’t really had any issues with it except maybe an affinity for cool white.
The reading will be at least lineair with the light output, this downgraded Tasi is the first luxmeter that I have seen that has a linearity problem :person_facepalming:
