It is the 46mm SRK 32x 7135 driver from MTN Electronics. There is no FET but only 7135 transistors. Maybe I will try it with Attiny85. I should find out quickly if it works or not when turning on the flashlight.
Oh, I have one of those. I ran Ferrero_Rocher/Ramping_UI_table on it.
It was okay, but the ramp resolution at the bottom was very coarse, and it had no extra features except battcheck. Giving it an attiny85 would give it more features, but would not improve the ramp resolution. Also, you’ll probably have to compile a custom version of the code to make it work, because I don’t think there are existing recipes for any single-channel drivers.
It may also be desirable to remove the voltage divider resistors, to reduce standby current, after getting everything else working. The tiny85 code can get that info from a different pin, so the divider isn’t needed any more.
Maybe the Ferrero_Rocher/Ramping_UI_table would do for me. I rarely use the special modes and the ramping sounds good. So I can just reprogram the soldered Attiny13 and do not need to change it. Also it would be too much for my limited coding experience to compile custom codes. Many thanks for all your useful advice and flashlight firmware!
Hi TK and all BLF friends.
I would like to use crescendo in my TA drivers, but I’m having some trouble.
If I include the thermal regulation in the compile, the resulting hex file became too large for the attiny 25, even setting optimize to size in the toolchain menu.
If I deactivate all the special modes like bike, strobe, beacon etc, or reduce the ramp size, than I can use thermal regulation, because the hex file size became smaller, but that is not a real solution.
Is it possible to use crescendo with the special modes and thermal regulation for the attiny 25?
I get 2008 bytes for the FET+1 build, and 2016 bytes for the 3-channel build, without changing anything else. It can be up to 2048 bytes before running out of room. I’d suggest trying the compiler settings in bin/build-25.sh to get it to compile to the expected size.
Nope, I can’t really do that. I’ve never used AVR Studio. About all I can say is that you’ll have to find the places in the GUI where all those compiler options are hidden… but I don’t know where to look.
Instead of AVR Studio, I use the tools and commands listed in the bin/build*.sh scripts.
AVR Studio uses the same tools to compile things, but it adds a bunch of extra layers around that to wrap it in a GUI. I don’t have any computers which are compatible with AVR Studio though, and don’t much care for GUI development environments, so I take a more direct route.
It’s all pretty easy to do under Linux, or in a Debian-like OS. This includes Windows 10, using its ability to run Ubuntu in a sandbox. Just a few commands to install the relevant packages, and then things mostly just work.
Most of the time, I just hit Up, then Enter. Or Up, Up, Enter. And things get compiled, or flashed, or whatever else it was I was doing.
TK, that’s way out my capabilities.
If I manage to make AVR Studio to compile crescendo with the thermal management included I’ll post here.
Thanks again.
Hi g_damian.
Thanks for the link.
I have been using AVRStudio with success for some time.
My difficulty is specifically compiling crescendo with the thermal control activated and with the especial modes at the same time.
For some unknown reason the resulting .hex file is too large for the attiny 25.
I will try to investigate the cause of this problem.
Any help is appreciated.
Would the Gnu General Public Licence work? You have far more experience with GPL than I do.
For Eagle the source code would be the .sch and .brd files. The author would put a copyright and GPL notice in a text box in the schematic and layout.
Gerber files and images would be “object code”
The free version of Eagle will work for drivers. That should satisfy the “Corresponding Source” clause in section 1.
The PCB layout and source files can be copyrighted, but that might not cover the information in a schematic. If I understand correctly, the schematic might go under patent law, not copyright law. So the GPL and other similar licenses might not even be relevant.
Basically, I don’t have the background to answer this question… and a quick web search suggests that the answer is probably not simple.
A circuit can not be copyrighted but sometimes can be patented. Like any patentable invention, a patentable circuit needs to be new and non-obvious.
A copyright would apply to the drawing and the .sch file. Someone could redraw the circuit without violating the copyright. That goes against the sprit of GPL.
A patent for using pulse width modulation to regulate an LED flashlight was granted in August 2000.
