M4D M4X deals - Astrolux WP1 and WP2 LEP
You are looking at the older version with the Haikelite driver. It was rated at 12k lumen.
I think they called it the MT03 II because they upgraded the leds from 70 to 70.2.
would like Narsil on the Fitorch!
Is it possible to get a green mt03 TA?
They did a limited number of MT09R in different colors, but I don’t think they ever did that with the MT03.
for the output and UI, etc., at this price it’s a no brainer, seriously. I have the light, I paid $70 for it from Terry, the USA distributor, then sent it to TA for mods. It’s my best light!
I don’t think your answering his question.
Hello my dear frinds!
banggood listed the
Imalent MS12W
12 x XHP70 53000Lumens 8Modes
the code can be asked or found in my list:
M4D M4X deals
Hey my friends!
if you are in any way interested in the Fitorch P25 :
RECHECK the deal!! ;)
(not sure if it's a permanent price drop.. )
Fitorch has fixed the link to the manual for the P25. Not real impressed with the user interface. Looks the same as their other lights. You have to be careful not to change modes too fast or you get the obnoxious strobe.
Nice looking light, but I’ll have to pass.
Battery Loading: Insert the included 26350 battery
as illustrated.
Power Off/On: quick press and release the side
switch to power the light on. Press and hold the side
switch to power the light off.
Lock Out and Unlock:
Lock Out: Unscrew the tail cap a ¼ turn to prevent
the light from accidently turning on.
Unlock: Re-tighten the tail cap to regain functionality
of the light.
Side Switch Lock Out and Unlock:
Lock: when power off, long press the size switch
until the LED flickers.
Unlock: Quick press the side switch in 3 times, Ultra
Low mode will activate after power detection
finished.
Changing Illumination Modes: With the light turned
on, quick press the side switch. The light will cycle
through the illumination modes in the following order:
High – Medium – Low – Ultra Low – Low – Medium –
High
Activating Strobe and SOS Modes
With the light on or off, quick press the side switch
twice to activate Strobe mode, repeat to activate
SOS mode
AX2 and AX3 Amutorches are suitable protected or nonprotected 18650s? i see noone has them yet….no reviews…they looks so nice
i think booth should fit
but (imho) using 30Q BT in 90% of my lights does the job
use a DMM to check ccells when they go in/out a light
do not shorten by accident ;)
then you are fine
well…iam now absolutly into usb rech.flashlights…these are not,so i think about rechargeable 18650s…its only solution.but,they are only protected…and if i want max from the torch,protected will not good…
Hello my dear friends!
Who likes some new deals?
you can find them in M4D M4X deals or contact me!
Eagle Eye X7 US$ 23.99
XHP50 2.0 2200LM
3 Modes Tactical 26650 18650
Features:
1. Tactical EDC flashlight, compact and lightweight.
2. XHP50 2.0 LED, with optimized design high efficiency drive circuit. Max output up to 2000 lumens.
3. Multiple one touch access functions: one touch High, one touch medium, one touch low.
4. Thermal protection system, the flashlight will keep flashing if the temperature of the cylinder is too high, so please adjust it to low and middle mode or close temporarily. Ensures the flashlight retains optimal internal temperature, keeps LED and crucial component safe for the best balance of performance and safety.
5. Memory mode: turning on for more than 3 seconds to remember the current position.
6. Low voltage warning: when the battery voltage is lower than 3V, the flashlight will darken and flash. Please recharge in time to avoid over-discharge of the battery.
7. Use 1 piece of 26650/18650 rechargeable lithium-ion battery.
8. Aerospace Aluminum alloy body with CNC machining; Mil-spec hard anodizing (HAIII); lightweight and robust construction.
9. Two-sided film toughened glass lens.
Package Included:
1 x Eagle Eye X7 LED Flashlight
1 x Lanyard
2 x Waterproof O-Ring
1 x Rear Glue Cap
1 x Battery Conversion Tube
Fitorch MR26 US$ 4?.99
XHP-35 LED 1800LM
6Modes 3-Way Tail Switch
IPX8 Waterproof LED Flashlight
18650 Battery
Features:
- Maximum output of 1800 Lumen and 302-meter beam distance.
- 4 colored light filter discs to change the tint of the light (Red, Green, Blue & Orange).
- 3-Way tail switch to activate the Strobe and Turbo modes in one easy step.
- Side switch controls 5 illumination levels (Turbo, High, Medium, Low, & Ultralow) and Strobe.
- Micro USB port for recharging.
- Built in power level indication LED in green, amber and red color.
- High-strength aerospace aluminum body.
- Mil-Spec hard anodized for extreme durability
- Coated tempered glass lens resists impact while providing high light transmittance levels.
- Metal filmed reflector to create a high intensity beam.
- Waterproof in accordance to IPX8
- Inpact resistant to 2meters.
Package included:
1 x Fitorch MR26 LED Flashlight
1 x 18650 battery
1 x USB Cable
1 x Lanyard
1 x O-Ring
1 x Holster
4 x Colored Light Filter
Nitecore MH12GT US$ ??.67
Xp-l Hi V3 1000LM
Multitask Tactical Rechargeable LED Flashlight 320M
Features:
Ultilizes a XP-L HI V3 LED.
Maximun output of up to 1000lumens
Boasts a peak beam intensity of 25700cd and a throw distance of up to 320meters
Integrated “Precision Digital Optics Technology” provides extreme reflector performance
High efficiency constant current circuit board provides max runtime of 520 hours
A side switch desing offer access to 4 brightness levels and 3 specical modes,ideal for ourtdoor applications
Power indicator can also report battery voltage to the nearest 0.1v.
A built-in charging module charges li-ion batteries voltage to the nearest 0.1v
Includes a nitecore 18650 battery (NL1834 3400mAh)
Features intelligent memory effect (except for SOS and location beacon modes)
Reverse polarity protection prevents damage from incorrectly inserted batteries
Toughtened ultra-clear mineral glass with anti-reflective coating
Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
Waterproof in accordance to IPX-8(two meters submersible)
Inpact resistant to 1.5 meters
Tail stand capability.
Package included:
1 x Nitecore MH12GT XP-L HI V3 1000LM Tactical LED Flashlight
1 x Flashlight holster
1 x Clip
1 x Tactical ring
1 x Lanyard
1 x O-rings
1 x Spare switch cover
1 x USB port cover
1 x USB charging cable
1 x NL1834 3400mAh 18650 battery
Xmas is near and i got a great deal that makes it easy to give them away like candy ;)
FOLOMOV 18650S
900 Lumens 15 Modes
IPX-8 Waterproof
3.9 Inch Length
Nicha 219D Led
Compact Tactical Flashlight
USB rechargeable 18650 cell INCLUDED!
Deal is available for M4D M4X members (click here)
Banggood asked me about my upcoming birthday and i wished for something to share with YOU!
so they hooked up a huge collection of items that are quite popular:
get 30% OFF with my code: M4BG for this brands:
ASTROLUX & BLFNITECORELUMINTOPIMALENTKLARUS
HAIKELITECONVOYROFISWUBENFITORCHXTAR & MIBOXER
Code is active Nov 1-11 2018 – hope you catch some nice items!
(remember to double-check with the member discounts M4D M4X deals !)
According to this special webpage the Astrolux MF02 currently costs $ 79.99 (on sale?). Does that mean the price will be reduced to $ 55.99 as of Nov. 1, 2018 by using this universal code? That would be too good to be true. :heart_eyes:
not sure - those "sales" have a different logic (i´d try my code anyway ;) )
11.11 might get interesting on BG. :slight_smile:
Martin, you don’t happen to have your birthday on 11/11, do you? :smiley: (dreamin’ about 70-80% discounts) :innocent: :heart_eyes:
no ;)
