I’m sorry but I still do not understand, I have to modify my Blf Q8 before I buy the tube? if not, there will be a lot more lm? and how will it be with the length of the turbo mode? Thanks.
@SebaZ74, you will only have the buy the BLF Q8 version of the tube to make it work.
If you have not bypassed the springs, you will be getting more lumens since the resistance will be 1/2, and the current to the LEDs will increase, and there will be more brightness.
High turbo brightness runtime will be increased by about 1,5-2x depending on what 18650s you use.
You take off the stock battery tube and put it in the closet. Then buy two new tubes and two carriers. Then you can use 8 batteries in it.
Correct BSM?
A single blast of turbo should last about the same amount of time as it does now, or maybe a bit less, before the thermal protection reduces output. It might be a bit brighter, but not much.
Total run time basically doubles when you double the number of batteries.
2. Yes, same turbo runtime, but if you can keep the light cool, you will get at least 50% more runtime.
3. Not exactly with a FET light. Since you basically halve the resistance of your battery setup, that means the light will be capable of pulling more power, and therefore, less max power runtime on unregulated mode.
Bonus points: With an extension tube, you can now get the same power output as with 4x20A cells with 8x10A cells, meaning you can use higher capacity cells like the NCR18650GA and Samsung 35E/36G to get 10-15% more capacity on average, which is non-negligible.
If you keep the light cool you can more than double turbo run time, even using 4 batteries. It’s hard to keep it cool, though.
You don’t really halve the resistance of the batteries by using 2 carriers. Texas_Ace saw this when using two carriers in the GT. You add a little resistance back into the circuit from the contacts between the carriers as well as having more battery springs.
So you get less resistance overall, but it’s not exactly cut in half.
We still need to see how good the contacts are between the carriers.
I am interested in getting two tubes with their corresponding carriers, also wondering if the thread pitch might happen to match the Fenix TK75 extension tubes? (shot in the dark, that one)
FWIW, Richard makes a 4S carrier that fits the Fenix TK75/TK61 lights. Just saying.
What was I planning to do with these XHP-50.2’s I got in the mail the other day? They were for the Q8, I am pretty sure, but I forget just what the plan was? Did I say anything about this here? (truly sucks, having a fish net memory)
[something in the back of my mind pushed me to order a 4S carrier from Richard, this applies here, yes?]
So… 4S conversion, using (at least) two tubes for more power, XHP50.2 emitters, in a Sofirn Q8? Are you going to use a Lexel driver? Or a L4P driver? Other?
