Lumintop BLF GT mini XPL HI 1200LM Stepless Dimming Portable EDC 18650 LED Flashlight
Use coupon code eb4fa7 to get $39.99 price (-$9.51)
Original Xiaomi Mijia LED Smart Bluetooth WiFi Control Bedside Light Sunrise Sunset Simulation
Use coupon code ledmijia to lower the price to $53.99.
This is second (upgraded) version of Xiaomi bedside lamp. It now uses RGBW LEDs - White ones are Osram LEDs with CRI up to 95.
Second version has gold colored base and now it can communicate also via Wifi (first version was Bluetooth only) and can be paired with MI Home and controlled via voice commands and automatic events (for example light color can indicate room temperature etc.)
Fitorch P25 4x XPG3 LEDs 3000LM 5 Modes IPX-8 Waterproof LED Flashlight 26350 Li-ion Battery
Coupon code with nice discount is available.
» Request via PM here«
Coupon code with massive discount is available.
This version have 5000K CCT LEDs and brightness remains at record 53 000 lumens.
XTAR VC2 Charger With LCD Screen Display For 18650 26650 Battery
It’s now in flash sale for $11.79 ($25.27 / –53%)
Offer ends in 1 day and 16 hours.
XTAR VC4 LCD Screen USB Battery Charger For 18650 26650 14500 Battery
It’s now in direct promo for $16.99 ($38.02 / –55%)
Offer ends on October 31st.
XTAR PB2 Rapid Smart Phone Power Bank & Hidden LCD Display 18650 Battery Charger 2Slots USB Cable
It’s now in direct promo for $10.90 ($16.39) with free gift (26650 battery case worth $1.45).
Offer expires on November 2nd.
This is a very compact li-ion charger/powerbank with two 18650 slots, magnetic cover and battery charge state display (description states LCD but looks more like standard blue 7-segment LED display).
Claimed conversion efficiency of up to 92%.
Fitorch MR26 XHP-35 LED 1800LM 6Modes 3-Way Tail Switch IPX8 Waterproof LED Flashlight 18650 Battery
I got mine in a couple weeks ago. It seems to be a not so great light, which is what I expected. The Bistro UI is quite interesting though. That was one reason I bought it.
I measured 810 lumen with widest beam and 270 lumen with narrowest beam. The driver seems to step down very slightly every 10 to 12 seconds which is very odd.
The Vappower 5200mah cell seems to be quite a low powered unit. Pretty much equivalent to the Keeppower 5200mah. About a 10A continous cell. Review here.
The Xanes are actually protected. They seem to trip at about 3.5A. I didn’t check capacity but believe they are 1600-1700mah as reported earlier.
I switched off the thermal calibration thingy and this step down disappear. I believe manufacturer didn’t do or did very bad thermal calibration for it.
I didn’t try to calibrate it though.
I’m still waiting on mine to arrive…
Haikelite Q30 7070LED 12000Lumens 5Modes Charging Indicator Light IPX8 Waterproof LED Flashlight
NITECORE MH25GTS XHP35 HD 1800LM 8Modes USB Rechargeable LED Flashlight + 3500mAh 18650 Battery
Coupon code with sizeable discount is available.
Nitecore MH12GTS XHP35 HD 1800LM 5 Brightness Levels 3Modes USB Rechargeable LED Flashlight 18650
NITECORE EC4GTS XHP35 HD 1800LM 8Modes Unibody Compact Long Thow Searching 18650 Flashlight
Coupon code with very nice discount is available.
Wuben E05 XPL 6Modes 900Lumens Magnetic Tail EDC LED Flashlight Reading Light with Diffuser 14500
Coupon code with very good discount is available.
Use coupon code BGRTW to get $12.99 price ($19.99 / –35%).
Neutral white and cool white options available, accepts 21700 cells.
Use coupon code AC18 to get $34.65 price (-$14.85)
Offer valid until November 24th.
