About the special edition thing, I’ve been really tempted to change the thread title. I’ve always thought The Miller’s title was a little awkward. Special elegant triple powerful flashlight. Should probably change that at some point.
Funny you should ask, I was just thinking about that.
IMHO the answer is yes.
HDS, Novatac, Liteflux and maybe others have tackled this issue, some more successfully than others.
Again, IMHO HDS has done it best.
I don’t know if there are patent issues regarding that particular design but I’m hoping this version works.
The current carried to the switch is tiny so a much smaller conductor could be used.
A notch down the inside of the battery tube could house the insulated conductor.
It’s a matter of making it robust enough to handle battery changes and curious owners.
If the way HDS does it is patented then a new method to carry the signal would need to be devised.
It may require an “out of the box” solution like you’ve suggested and a departure from the standard screw-on tailcap.
It seems like getting that additional signal from the back to the front is one of the delays.
Perhaps a light with the driver in the rear?
Or maybe power control in the rear and a secondary board in the front to allow for heat sensing?
Or maybe the FW3A will deliver the goods and this is all moot.
That’s what I’m hoping.
I’m no rocket scientist though so take what I say with a grain of salt. Or two!
