i think booth should fit
but (imho) using 30Q BT in 90% of my lights does the job
use a DMM to check ccells when they go in/out a light
do not shorten by accident ;)
then you are fine
then you are fine
wellâŚiam now absolutly into usb rech.flashlightsâŚthese are not,so i think about rechargeable 18650sâŚits only solution.but,they are only protectedâŚand if i want max from the torch,protected will not goodâŚ
Hello my dear friends!
Who likes some new deals?
you can find them in M4D M4X deals or contact me!
Features:
1. Tactical EDC flashlight, compact and lightweight.
2. XHP50 2.0 LED, with optimized design high efficiency drive circuit. Max output up to 2000 lumens.
3. Multiple one touch access functions: one touch High, one touch medium, one touch low.
4. Thermal protection system, the flashlight will keep flashing if the temperature of the cylinder is too high, so please adjust it to low and middle mode or close temporarily. Ensures the flashlight retains optimal internal temperature, keeps LED and crucial component safe for the best balance of performance and safety.
5. Memory mode: turning on for more than 3 seconds to remember the current position.
6. Low voltage warning: when the battery voltage is lower than 3V, the flashlight will darken and flash. Please recharge in time to avoid over-discharge of the battery.
7. Use 1 piece of 26650/18650 rechargeable lithium-ion battery.
8. Aerospace Aluminum alloy body with CNC machining; Mil-spec hard anodizing (HAIII); lightweight and robust construction.
9. Two-sided film toughened glass lens.
Features:
Package included:
1 x Fitorch MR26 LED Flashlight
1 x 18650 battery
1 x USB Cable
Features:
Ultilizes a XP-L HI V3 LED.
Maximun output of up to 1000lumens
Boasts a peak beam intensity of 25700cd and a throw distance of up to 320meters
Integrated âPrecision Digital Optics Technologyâ provides extreme reflector performance
High efficiency constant current circuit board provides max runtime of 520 hours
A side switch desing offer access to 4 brightness levels and 3 specical modes,ideal for ourtdoor applications
Power indicator can also report battery voltage to the nearest 0.1v.
A built-in charging module charges li-ion batteries voltage to the nearest 0.1v
Includes a nitecore 18650 battery (NL1834 3400mAh)
Features intelligent memory effect (except for SOS and location beacon modes)
Reverse polarity protection prevents damage from incorrectly inserted batteries
Toughtened ultra-clear mineral glass with anti-reflective coating
Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
Waterproof in accordance to IPX-8(two meters submersible)
Inpact resistant to 1.5 meters
Tail stand capability.
Package included:
1 x Nitecore MH12GT XP-L HI V3 1000LM Tactical LED Flashlight
1 x Flashlight holster
1 x Clip
1 x Tactical ring
1 x Lanyard
1 x O-rings
1 x Spare switch cover
1 x USB port cover
1 x USB charging cable
1 x NL1834 3400mAh 18650 battery
Xmas is near and i got a great deal that makes it easy to give them away like candy ;)
Banggood asked me about my upcoming birthday and i wished for something to share with YOU!
so they hooked up a huge collection of items that are quite popular:
ASTROLUX & BLF â NITECORE â LUMINTOP â IMALENT â KLARUS
HAIKELITE â CONVOY â ROFIS â WUBEN â FITORCH â XTAR & MIBOXER
Code is active Nov 1-11 2018 â hope you catch some nice items!
(remember to double-check with the member discounts M4D M4X deals !)
According to this special webpage the Astrolux MF02 currently costs $ 79.99 (on sale?). Does that mean the price will be reduced to $ 55.99 as of Nov. 1, 2018 by using this universal code? That would be too good to be true. :heart_eyes:
11.11 might get interesting on BG.
Martin, you donât happen to have your birthday on 11/11, do you? (dreaminâ about 70-80% discounts) :innocent: :heart_eyes:
no ;)
not sure what day your birthday is Martin, but whatever day it is, wishing you a Happy Birthday! You are so appreciated.
Thanks!
to make it easier - its Nov. 3rd ;)
why not AmutorchâŚso beatiful flashlights:)
Olight S10R clearance (UK warehouse)
only 29.90 (5 pcs left!)
Ordered my first Olight
And happy Birthday!
Damn thatâs some old stock there⌠Olight released the third gen of the S10R this year
Birthday GAW!!
https://www.youtube.com/watch?v=rutILqjFldU (please watch on YT and click subscribe)
Link to the GIVEAWAY-post on facebook: https://goo.gl/sQqSeB
Link to the M4D M4X collection on banggood: https://goo.gl/5utMsU
2 out of 3 ainât bad. Blog, tick. Utube, tick. FB, no way! Understand why u do it but still a bit disappointed
Edit: Happy bâday!
Birthday GAW!!
This means we have to use the same mailadress on Facebook an youtube?
