Performance and runtime of white flat in fet dd setup is better than same configuration with old xpg2s42b. You will have more than 20 minutes of super thrower performance in your single 18650 setup, and this new emitter is not black flat is white flat so it is better than his black brother and can withstand some serious abuse and current at which old xpg2s42b would explode… I am abusing that emitter for one full month and it still did not die. Still same performance…
So will fet dd config die? I don’t think so… Wouldn’t be nice to have it regulated? Yes why not? Should you affraid of 5.5A current draw on White Flat? Absolutely not. It can safely survive even more than 7A for extended periods of time well at least my re flowed version…
Now one example. Scientist guys please read consideration of just regular diy redneck guy like myself… Talking about single cell 18650 flashlights and defending old FET DD technology :laughing:
Regulated driver set at 5.5 A current draw vs FET DD driver at mentioned 5.5A (at 4.2V) > 3.3A(at 3.4V).
FET dd has 5.5A performance for about minute than it drops to 5.4A, after minute to 5.3A, after minute to 5.2A etc… In other way it does not stay in regulation. But! Since White Flat is like viagra it has very constant lux performance from 5.5A to 3.5A. We will not feel any significant visual performance drop and flashlight will generate heat proportionally to amperage draw from cell. In other way flashlight will actually become cooler as performance falls. FET driver does not generates heat right?
Regulated linear with constant performance set at 5.5 A. No argue that it will give maximum and more constant performance. But! Whole rig generates far more heat than FET DD setup. Regulated linear driver generates a lot of heat as far as I know right? That means once when flashlight host reach maximum heat absorption potential it will really start to cook the led itself… And not only LED all components on linear driver will suffer.
FET DD driver actually cools itself while Regulated linear cooks itself!
So FET DD lets us to feel maximum performance of led emitter, generates heat proportionally to amperage draw from cell so it is quite safe in usage even more safe imho than regulated linear driver in same peak amperage (5.5A for example).
So for single cell 18650 thrower lights I will just say long live FET DD :+1:
the problem is that most of us are going to change the xpg2 on our flashlights which was with DD drive,i prefer to just change the led keep the drivers and just find better batteries for that setup.
No idea, I never run my LEDs in DD.
You’ll never get peak performance with DD, it either runs at too much current or not enough current.
Ideally the LED operates at the peak of the curve, which is basically impossible to do with DD because battery voltage drops so quickly.
And if you run it where the battery voltage is fairly stable, ~3.7v, then the initial spike of 4.2v just makes the LED heat up excessively and decreases performance, assuming you don’t instantly kill the LED.
Well I guess I’m not clear here then Luminarium. First ya advise to stay away from high current cells like the 30Q and then here ya say it can take more abuse (current) than the old XPG2.
IDK, sounds to me like the White Flat can take a 30Q afterall with FET DD and there’ll be zero to none problems. :laughing:
Yeah, there’s one little tiny thing you’ve missed. He said it CAN take the “abuse” of using a DD driver with max amps. But, it will perform BETTER at a lower current, so that’s the recommended set-up.
Ok then if I read things right it performs worse with higher current butt it also depends on how long it’s run at that current. Or no? For shorter burst throw activity do ya really need to use lower current batts? And if not can this be mitigated with anything else to improve thermal paths when reflowing?
To me at least dealing with this lower current batt jazz and this led is a PITA. It’s just another frickin’ thing I’d have to keep track of besides all the other shizen I gotta keep track of with ala in just safely charging batts itself. :laughing:
Oh and if it performs worse with high current batts butt STILL outperforms an abused XPG2 then one is still ahead, right? According to Luminarium it’s not gonna harm the KW hardly at all. So what if I get a bit less performance. Butt that’s just for me. Others want it all all the time, baby.
PS. If I understand Luminarium correctly it can go 20 minutes in Super Thrower mode. Does he mean with lower current batts, apparently so. Butt OTOH can it Super Throw for 5 mins with a 30Q, that I’m not sure of. Hell I rarely go longer than 2 mins on Super Throw mode with anything I own. I got neighbors ya know. :laughing:
Throw is comparable with C8. Here is the picture with Convoy C8 with CREE XP-L HI V2 5D at 2.7A, SP32A with OSRAM KW CSLNM1.TG at 3A and stock Acebeam EC35 at 3.3A. Around 2.5 metres to a wall:
What if the led can survive whatever amount of overcurrent? When you do that you're pumping more power into the led it can fruitfully handle.
Wrong. The only reason a regulated linear setup generates more heat than plain direct drive is the price of regulation. The LD25 driver, for example, uses an AON7520 MOSFET and achieves regulation by sensing current through a 10mΩ resistor and using this feedback to precisely tune the VGS MOSFET gate voltage for it to let go no more than the preset driving current, thus no :THUMBS-UP: PWM. The net dissipated power difference versus the same driver without regulation is the additional power spent in the sensing current path, Psense = I² × Rsense. At 5A that is 0.25W, this new LD-25 is particularly efficient in this regard. And of course bear in mind the regulator has to take and bear with any additional voltage delta times current power, thus the increased heat in the driver. This increased heat in the driver nets reduced heat everywhere else in the current path: springs, switch, cell, emitter, etc.
A MOSFET misdriver is just a PWM micro-controlled switch. As I said above, you pay a regulation price in linears. However, this price is not always a hurdle. You complain about heat generation, but do you understand where and how is the heat generated? Any time you “adjust” a plain MOSFET setup via unbypassed springs, using higher internal resistance cells, etc. what you're doing is redistributing where the heat is generated. Which of course can be good.
A linear driver has to burn all excess power to avoid it reaching the emitter, which of course will make them hotter than unregulated misdrivers which of course do nothing.
Sure as FLICK a misdriver isn't going to be very hot, how could it be? It is doingnothing besides quickly switching on and off when required. However, this does not mean the heat isn't going to be generated elsewhere. It's the emitter who is going to take the penalty among other parts like the switch, my dear. Pumping 7A in the white flat isn't going to insta-kill it, but it sure increases emitter stress unnecessarily and nets you lower performance.
Ya know this guy noferek9 prolly makes the most practical real world sense outta all of us here. :laughing:
“the problem is that most of us are going to change the xpg2 on our flashlights which was with DD drive,i prefer to just change the led keep the drivers and just find better batteries for that setup.”
Cuz I can tell ya right now I’m not gonna rip out a bunch of XPG2’s either much less their (gasp….heresy!) DD drivers.
“Sure as FLICK a misdriver isn’t going to be very hot, how could it be? It is doing nothing besides quickly switching on and off when required. However, this does not mean the heat isn’t going to be generated elsewhere, you know? It’s the emitter who is going to take the penalty among other parts like the switch, my dear. Pumping 7A in the white flat isn’t going to insta-kill it, but it sure increases emitter stress unnecessarily and nets you lower performance.”
Man, I almost can’t wait to read Luminarium’s reply to this one.
Sure as FLICK I can wait. In fact I don't really care. No one's paying me for this and I believe it is unlikely he's going to get off his high donkey. He may already be aware of the provided information, except he may not have tried a proper linear driver like the ones from led4power or an LD-25. Or he just doesn't care.
