I just noticed Wubens visible range illustration in the first picture. I really like it.
Normally if I see an ANSI range I divide by 2 and 3 and that gives me a real usable range.
It seems Wuben did the same for the first mark: 130m/3
This is an honest question: if the OP does not post a link for a sale, even if “it” is a flashlight manufacturer and even if the thread is about a new flashlight they wanna promoted, that is considered - under the rules of the forum - a commercial post?
I don’t want to derail the thread, I’m just asking for a clarifying answer about this subject! :+1:
The Forum Rules seem clear enough to me. Wuben have also posted a request for reviewers in the Giveaway part of the Forum. Again, this is inappropriate - it isn’t a “giveaway”, it’s seeking to promote their products through a review.
From the Commercial Seller note:
IF YOU ARE A COMMERCIAL SELLER:
Please make only a few threads in the Commercial Sellers’ Spot category.
If in the future you want to let us know about new products and offers, please make update posts in the same few threads. For example, you could create one thread called “CompanyXYZ.com New Flashlight Products” and another called “CompanyXYZ.com Current Offers and Coupons”.
Perhaps this flashlight could be offered without the fancy battery to bring the price down a little. I agree with Moderator007 that the current price is not a good deal.
I’m clarified now Woody, and you’re right I guess I didn’t remember this part:
Normally I associate sellers with “links” although the promotion of products doesn’t imply having that link! Thanks for and sorry for the “basic” question
No worries - I generally look at BLF via Recent Posts without commercial threads, so am maybe oversensitive. :innocent: Rest assured, if a manufacturer has a new light to promote, it won’t be long before it appears in the non-commercial posts.
Pete, The run times are best with 14500. I did tests with 14500 VS Alkaleaks VS Enoloops. Alkaleaks should only be used in emergency. Total waste. Especially leaking in good flashlight like this one.
My question was about the difference in runtime between alkalines and NiMH. Wuben shows that runtime on alkalines is twice as long as on NiMH. I find that strange.
NiMH kinda drops like a rock once depleted. Alkaleaks slowly fizzle to almost nothing, and probably still let it light up even if down to that 1% ANSI spec or whatever it is.
Eg, my bobofett light (Microstore’s R22) will keep wringing out an AA alkaleak to zero. It won’t start up unless it “rests” a bit to build up some starting voltage, but will dip down to well below anything remotely considered even firefly mode before finally giving it up.
My SP10s, though, will abruptly start blinking a few times and then quit for good within seconds of acting weird.
For 2×AA lights, my SF13 will do the same, act weird and then abruptly quit, whereas my LuxPro will at least try to keep the light going a while longer.
Those are just using alkaleaks with their sloooooowly but gradually ever-shrinking voltage. NiMH, as I mentioned, will hold a pretty steady voltage until it just falls off a cliff and dies suddenly. And it’s already starting out at 1.2V, not ~1.6V.
That’s one (and probably the only) advantage alkaleaks have over rechargeables.
