ENDED.
838 posts / 0 new
Hezekiel
Interested in this one!
808Hi
Last seen: 3 days 1 hour ago
Interested
maukka
maukka's picture
Last seen: 3 hours 35 min ago
My FT02 prototype has some weird UI. Uneven mode spacing (huge gap from moon to the next one and the higher modes are too close to each other). And it has no ramping either.
Click to turn on, always turns on moonlight. Click to advance modes, long click to turn off. After double clicking for turbo, it reverses the cycle from high to low, but you can’t reverse the direction without going to turbo first AFAIK.
Other than that, it feels very good in the hand. It’s nice and chunky and balanced better than the Emisar D1S. The switch is nice and tactile. Reflector shows machining marks and isn’t as smooth as the D1S.
Walls are nice and thick. Double springs in the tail.
Even though Banggood asked, I’m not going to publish any measurements from the proto as it will not represent the retail product (they said the output will be higher). A review of a light with different UI and output wouldn’t serve anyone. So all I can say is, don’t buy it until someone has tested the final light. But if the final light will have a good UI, it seems like a nice one.
maukka
maukka's picture
Bezel came off easily. Double o-rings in the head. There’s space for a 30mm MCPCB. Lens is 52×2mm.
Glov
Last seen: 2 hours 57 min ago
Interested
maukka
maukka's picture
Quick visual comparison indoors and this thing in its prototype form smokes the D1S in throw. Of course that’s partly due to the fact that the FT02 is cool white while the D1S is 4000K. But it sure blinds me more efficiently when shone on a close by white surface.
ipaulr
Last seen: 1 month 1 week ago
Interested!
Cool Fall Spy007, Tri-V;  McGizmo Haiku, Mahi, Makai;  Oveready B.O.S.S. 35/70 Ti;  Manker MK34, MK35, MK41, T01S, Timeback II;  FITorch P25;  Emisar D1 Mini Thrower, D1s, D4, D4s;  Noctigon M43 Meteor;  Lumintop ODL20C, GT Mini;  MecArmy PT16 Ti, Br;  Olight S1R II Cu, Ti (all seasons), X7R Marauder;  Niwalker MM18Jr;  Imalent DT35, DT70, R90C, RT35, DN70, MS12;  Fenix D45, D65;  Astrolux MF04, S42S;  Amutorch X9;  Acebeam X80-GT, T27;  Maeerxu M8;  Nitecore TUP, Concept 2, TM10K;  Tain Lasaber
freeme
freeme's picture
Last seen: 10 hours 46 min ago
Current performance is not far away from listed specs. I was told that driver is undergoing further upgrade. Will get BG to monitor closely on FT02 development.
Some improvements like what maukka and I would like to see:
  1. improved UI with ramping option.
  2. smoother reflector.
  3. larger inner diameter for its reflector for tighter hotspot.
  4. 21700 flat top support.
  5. make S/S bezel available for the light or at least an option for separate purchase.
maukka wrote:
Quick visual comparison indoors and this thing in its prototype form smokes the D1S in throw. Of course that's partly due to the fact that the FT02 is cool white while the D1S is 4000K. But it sure blinds me more efficiently when shone on a close by white surface.
maukka
maukka's picture
Flat tops work fine, at least a Samsung 30T in Vapcell wraps. What I’d like to see is a bit more space for a protected 21700. My Acebeam 21700 doesn’t have a protruding button anymore Smile
HONDARIDER
HONDARIDER's picture
Last seen: 1 week 1 day ago
  • improved UI with ramping option.
  • smoother reflector.
  • larger inner diameter for its reflector for tighter hotspot.
  • 21700 flat top support.
  • make S/S bezel available for the light or at least an option for separate purchase.
Put me in for a 2nd unit. I will take one more for the team. This light could be awesome with the requested upgrades.
freeme
freeme's picture
With physical reverse polarity protection in place, there is no way for my stock LS 21700 to make contact with the positive connector. A quick workaround will be adding a solder bold to the cell, but not everyone have the necessary tools for such heck.
maukka wrote:
Flat tops work fine, at least a Samsung 30T in Vapcell wraps. What I'd like to see is a bit more space for a protected 21700. My Acebeam 21700 doesn't have a protruding button anymore :)
maukka
maukka's picture
Probably depends on how much the surrounding wrapping gives in.
Also, they machined the aluminum spacer the wrong way around in the 18650-21700 adapter. It has an indent instead of a button at the end.
The plastic tube is threaded and the piece can be removed which does help as long as the button in the battery is tall enough. But then the adapter just flops around freely unless there’s a battery pushing it down.
freeme
freeme's picture
From past MF02 experience, #3 is very hard and costly to achieve. It is a very busy period for 11.11 sales now, slow reply from BG is expected.
freeme
freeme's picture
It's not in the manual, but i believe you have to install at the other end.
maukka wrote:
Probably depends on how much the surrounding wrapping gives in. Also, they installed the aluminum spacer the wrong way around in the 18650-21700 adapter. It has an indent instead of a button at the end. !https://i.imgur.com/XaIOy2D.jpg![/quote]
maukka
maukka's picture
Well that makes a whole lotta more sense.
edit: the spacer is fine with regard to resistance. Adds only a couple mOhm to the IR of the battery.
freeme
freeme's picture
It is a very clever and cost effective method. No silly rattling sound when handled like those cheap 26650 to 18650 adapters.
maukka
maukka's picture
The spacer could be a tad shorter though. My unprotected button top 30Q barely fits. I don’t think protected 18650s would work.
Bill_tong
interested
gottobegeek
gottobegeek's picture
Last seen: 5 days 19 hours ago
I am interested, do we have a price range yet??
g
maukka
maukka's picture
They also need ease up on the aggressive stepdown. Whether cooled or not, on a 30T turbo steps down (from 1950 to 1080 lumens) after 1.5 minutes while the surface temperature doesn’t even reach 40°C. They clearly have a temperature sensor so why not use that?
After the light has initially stepped down, subsequent turbo activations result in about 5-20 sec of turbo depending on temperature (in room temp when not turning the light off to cool in between). If the surface temperature is above ~46°C, turbo is not available at all. This seems like a good safety measure, but the limit could possibly be raised a bit. On high, the light never heated up to an unholdable level.
On very low battery voltage, turbo works only for a second or two, but maximum level can be achieved with mostly depleted batteries.
SKV89
Last seen: 5 hours 10 min ago
With those improvements made, I will probably buy a few of them, some for my friends. For item 3, I thought there is a formula for reflector geometry to optimize the beam. I didn’t know they just arbitrarily shape the reflector.
Also timed step-down are for cheap low quality flashlights. Really hope Astrolux gets rid of it if it already has a temperature sensor.
Also hopefully it can supported Acebeam 21700 protected.
JasonWW
JasonWW's picture
Last seen: 4 hours 50 min ago
Of course there is. The shape of the reflector is very precise. I think Freeme is saying the reflector diameter could be a few mm larger.
maukka
maukka's picture
The FT02 can maintain regulated ~1000 lumens without stepping down for the whole runtime (~1 hour on a 3000mAh 30T) with an average efficacy of ~95 lumens/watt, which is about the same as the Zebralight SC600w HI at its 600 lumen level.
jazzyone1212
Interested
SKV89
WOW!
Freeme, please put me down on the interest list! Love
Shintaro
Shintaro's picture
Interested. Count me in.
wstrachan
Last seen: 3 weeks 6 days ago
Interested for awhile now. Let’s get it ordered.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
Geoduck
Last seen: 1 day 22 hours ago
Interested.
P33
Last seen: 11 hours 22 min ago
I can’t find if it’s gonna be micro USB or USB C. Can someone please let me know?
Agro
Agro's picture
Last seen: 3 sec ago
The pics look like micro to me, but I’m unsure…
