New product 16340 800mah P1608A, Flashlight batteries come
338 posts / 0 new
vapcell Dennis
vapcell Dennis's picture
Last seen: 3 days 19 hours ago
Vapcell Original 16340 800mah P1608A battery 3.7V button top USB Rechargeable li ion Batteries cells for flashlight power tools
click the picture check more detail:
Vapcell Original 16340 850mah 3A T8 charging 3.7V li ion battery rechargeable button top batteries for flashlight power tools
click the image to check more detail :
Free shipping Vapcell original INR18650 3000mah 15A K30 3.7V lithium battery Li ion rechargeable 18650 Batteries for flashlight
26th Mar .2020
New arrival products Vapcell original INR18650 2500mah 20A K25 3.7V Li-ion rechargeable high power 18650 battery for Power tools flashlight batteries
13th,Mar ,2020
The new Vapcell INR21700 5000mah 15A G50 Rewrapped samsung 50G,equal to Tesla 21700A,PK samsung 50E and LG M50. However, since Tesla 21700A can’t add button totp due to the top sag, Vapcell 21700 G50 can add button top, better for flashlights.
12th,Mar ,2020
Vapcell’s first Lifepo4 32700 6500mah 30a offers stable performance and long life with large capacity and high drian battery. Can add button top, better for flashlight.
10th,Jan ,2020
There are three new Vapcell products, 14500 and 18500. Which one do you prefer for flashlights?
Click the image link for more details.
1.Vapcell INR14500 1000mah 10A H10 —usd11.99/pair
Highest discharge current: 10 a
2.Vapcell INR14500 1050mah 3A L10—usd8.99/pair
3.Vapcell INR18500 2200mAh 4A L22—usd13.99/pair
05th,Dec ,2019
New product!!!
Do you have a flashlight 14650 batteries?
Try this amazing battery Vapcell 14650 1100mah 6a
High rate battery considering capacity and power,excellent product consistency and cycle life
With a high discharge voltage platform, the service time and power can be increased
5th,Nov ,2019
VapCell U2 is a 2A intelligent universal charger with charging current almost all cylindrical rechargeable batteries, eliminating the need for several chargers. The U2 automatically detects Li-ion, Ni-MH and ni-cd, and through manual selection it is also capable of charging LiFePO4 batteries, intelligent charging circuit selects the optimal charging mod (DC, CV and dV / dt) to a given battery and for each of the two microcomputed charging slots of the U2, monitors and charges the battery independently, in addition, Four LEDs clearly show the charging progress.
Apply to (battery diameter: 10-26mm, length: 34-75mm)
Li-ion / Lifepo4:
10340,10440 and 14500,16340 of 16650,17500 of 17650,17670
18350,18490 and 18500,18650 of 20700,21700 of 22650,26500 of 26650
Ni-MH / ni-cd:
AAAA AAA SC CD
https://es.aliexpress.com/item/33057905746.html
Oct 21th,2019
Hello friend,
We have Vapcell S4 Plus 4 slot chargers
1. 3A 3A 3A 3A each slot , 12A in total
2. Discharge/Capacity Test/ Repair function
3. Enough space for 21700 batteries
We are looking for professional testers,Pm me!
And Do you want to have a try for new technology charger?
Aliexpress usd37.99/ pcs,free shipping, click the link
https://es.aliexpress.com/item/4000249374391.html
sep 24th,2019
1.Function Description:
LED indicator
Power on, connect power wire to charger , when the battery is charging ,the led is red ,if battery is full charged . the led will be green .
2. Parameters and Features:
Apply to (battery diameter:10-26mm,length:34-68mm)
3.6v/3.7v Li-ion:
10340(RCR123)/10440/14500/16340/16650/17500/17650/17670/18350/18490/18500/18650/22650/ 26500/ 26650/20650/22500/25500
2)Features:
 Micro USB power
 Automatically Stop Charging
 Over charge , and discharge protection
 Reverse -polarity protection
 Each slot Charge independently
 Portable, Easy to carry
Only usd9.99/pcs in AliExpress,Free shipping
https://www.aliexpress.com/item/4000200010509.html?spm=2114.12010615.8148356.1.496311bb8XhYRC
08-21/2019
Vapcell 18350 1100mah 9A battery test by HKJ and mooch, it is the best 18350 battery in market
Some batteries are slightly rusty due to wet weather.
But it does not affect performance.
There are hundreds of them in stock. Please seize the opportunity to buy them.
If more quantity is needed, the price will be more favorable.
https://www.aliexpress.com/item/4000108417629.html
07-13/2019
Vapcell INR18650 2500mah 25A ,rewrapped samsung 25S ,high discharge current,high Initial Voltage,better than vtc5A
Model INR18650
Size 18.3*64.9mm
Nominal voltage 3.70V
End-of-charge voltage 4.20V
End-of-discharge Voltage 2.50v
Typical Capacity 2500mAh (0.2C discharge)
Min capacity 2400mAh (0.2C discharge)
Weight Max:65g
Internal resistance Max:14mΩ
Standard Charge 1500mA,CCCV 100mA cut-off
Charging Time 2.5hours(standard charge)
Quick Charge Current 4000mA
Max Continuous Discharge Current 25A
Operating Temperature Charging, 0°C ~ 45°C
Discharging, -20°C~75°C
Storage Temperature -5°C~35°C
Storage Humidity ≤75%RH
Appearance Without scratch,distorion,contamination,and leakage
Standard environmental condition Temperature: 23±5°C
Humidity: 45-75%RH
Atmospheric Pressure :86-106KPA
Packing was great, condition of the cells are perfect, these are Samsung 25S rewraps and Mooch tested the 25S to be the hardest hitting ~2500mAh cell for the longest time to date. I highly recommend this cell.
For products worth trying, click here to view the product details.
https://www.aliexpress.com/item/33001758738.html
07/08/2019
Good day!
Vapcell 14500 650mah 7a upgrade to button top version, which is a high drain 14500 battery tailored for flashlights, enough to beat Sony’s high consumption of 14500 680 mah
Vapcell 16340 800mah 7a, with sufficient power, is very suitable for flashlights. It is better than DLG and Olight(16340 550mah 5-6a)
Vapcell 21700 4500mah 20a is really cost effective,button top batteries for flashlights
Vapcell 18650 2000mah 28a defeated VTC4, VTC4A, 20R, HD2, HD4, RX. For high drain flashlights.
The point is that Vapcell Aliexpress stores offer a 10% discount for these batteries.
14/05/2019
Vapcell continues to develop high-quality batteries for you
Vapcell 14500 650mah 7A button top battery
7A CDR, 13A max discharge current for you
Originally flat-top version, now upgrade to button top version
More suitable flashlight, no welding, excellent performance,beat sony high drain 14500 680mah
If you want high power 14500 batteries, this is your best choice
If you want high capacity 14500 batteries, take vapcell 14500 1000mah 3A
New releases the first vapcell 10440 battery
Vapcell INR10440 320mah 3A battery
This is a high power 10440 battery with a max continuous discharge current of 3A
Suitable for flashlight, laser pen, toys, etc.
Affordable price, please contact us
New battery release
Vapcell 18650 3400mah 10A M34 battery
Tesla Panasonic NCR18650BG rewarpped
The power is equal to GA, 35E, MJ1 ,VC7,M36. beat samsung 36G.
Electric vehicle use, excellent cycle life, more than 1000 times, and excellent consistency
We can weld button top and PCB, as well as battery pack for you .
Suitable for box mod, flashlight, power bank, etc.
25/04/2019
What kind of flashlight do you use? We’ve got many models of flashlight batteries for you.
As long as you purchase the vapcell battery via this aliexpress link, you will receive a free zipper case.
The case will be valid for five days after Posting, placing an order and leaving a message from the BLF.
Thank you.
https://vapcell.aliexpress.com/store/1084158?spm=5261.11152143.header.29.147f3e5f0inAe7
19/04/2019
Hello, everyone.
To repay BLF fans, vapcell launched four discounted batteries. Add a button top to fit the flashlight better.
$20.01/pair Vapcell 18650 2600mah 25a rewrap H26 “:https://www.aliexpress.com/store/product/1-dollar-coupon-Vapcell-18650-2...
$19.94/pair “Vapcell 20700 3100mah 30a https://www.aliexpress.com/store/product/1-dollar-coupon-Vapcell-20700-B...
$21.24/pair“Vapcell 20700 3200mah 30a rewrap sanyo 2070A”: https://www.aliexpress.com/store/product/1-dollar-coupon-Vapcell-Genuine...
$24.29/pair “Vapcell 20700 3500mah 30a rewrap best sanyo 2070C”: https://www.aliexpress.com/store/product/1-dollar-coupon-Vapcell-Green-2...
If you don’t like it, please tell me which one you like, and we will make a discount for you next time.
Have a great weekend ahead of time.
05/04/2019
The new product releases vapcell 16340 batterys with high capacity. Battery with button top , which is
more suitable for flashlight. If you are interested in review or test, please contact me by private letter. and this battery will also sell in Ali-express
16340
08/11/2018
And 14500 1000mah battery can replace Sony 14500 680mah and Sanyo 14500P 840mah.
At present, the battery is flat top, which can process button, but it will increase the length.
Unit price concession, you deserve it. Big Smile
Edited by: vapcell Dennis on 05/21/2020 - 04:38
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 7 hours 26 min ago
Very much interested! PM sent. Wink
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
djozz
djozz's picture
Last seen: 6 hours 4 min ago
Very nice! Good work Vapcell! I will wait for it to appear on your website.
Any progress on a good capacity high drain 16340 cell as well?
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 8 months 1 week ago
Nice to see another option to the Sanyo 14500P. Waiting to see them in your Store!
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
nick779
nick779's picture
Last seen: 2 days 9 hours ago
Ooooo get one to Hkj for further testing!
AlexGT
AlexGT's picture
Last seen: 2 days 38 min ago
I am interested in 3, what is your best price? Where to order, link?
Kindle
Kindle's picture
Last seen: 1 month 10 min ago
Subscribed
plasma327
Last seen: 1 year 6 months ago
Oh ! I want some!!
JaredM
JaredM's picture
Last seen: 14 hours 21 min ago
+1
Got a few V11R’s that need good 16340s as that o-ring groove just doesn’t leave enough meat for boring for 18mm cells
djozz
djozz's picture
Dear Djozz
Thanks you very much
16340 battery,it seems that progress has not been made for many years. We are looking for a better 16340 battery.
I have questions to consult you.
What is the main purpose of this battery? What is the market share of battery power requirements compared to 18350?
Look forward to your reply Blushing
Hi Dennis,
The main purpose of the 16340 battery is flashlight use. Many popular pocketable flashlights are on the market that make use of in the USA widely available (non-rechargable) CR123 batteries, these flashlight are often used with (rechargable) 16340 batteries.
The 16340 is noticably smaller than 18350 batteries and flashlights for 16340 batteries are often used in the pocket of your pants, while 18350 flashlight are found by many people to be a bit too big for that.
The market share in general is not high (the 16340 is not used much in vaping), but for flashlights the 16340 is a very common battery.
JaredM
JaredM's picture
As Djozz has stated, a number of compact flashlights use CR123 and are compatible with rechargeable 16340/16350s. Current draw for these applications is 1-3Amps most commonly. But the nature typical of BLF forum users are to prefer higher current capable cells. So continuous 5A would be a good limit for this size cell, in my opinion. I feel that a minimum requirement is at least STRONG performance at 3A.
HKJ
HKJ's picture
Last seen: 5 hours 47 min ago
We will send it to him ,hope HKJ will test it
Of course I will test it.
SKV89
Last seen: 30 min 18 sec ago
This is very exciting news! I love the 14500 size because I have a ton of AA/14500 lights that can use this. I have a number of Sanyo 14500P but always wish the capacity can be higher. This will help a bit. What cell is under the wrap? Surprise it can beat the Sanyo in energy density.
Also, did you send the Sanyo NCR21700A to HKJ for testing? Really like to have that on his comparator. It seems to be the best 21700 for most flashlight use cases unless very high current is required.
duvallite
Last seen: 1 day 5 hours ago
Interested in the 14500, and hope you can do a good 16340 also. Have several of both types of lights since I prefer those sizes for edc.
Firelight2
Firelight2's picture
Last seen: 1 hour 30 min ago
Very interested in this 14500.
I have a number of 14500 flashlights and so far the best high-drain cells I have only hold 650 mAh.
Question on your new 14500s Vapcell: What is the sustainable current? 3A? 4A?
mihlit
Last seen: 1 week 6 days ago
On one of these cells, you can read “Max continuous discharge 3A”
Anyway, looks good. The price is secret intentionally?
Sillen
Sillen's picture
Last seen: 1 week 2 days ago
Got 4 sofirn 14500 on order but could go 2-4 of these if ship to Oz
duvallite
Link to your website?
djozz
djozz's picture
It is not listed yet.
Freedom
Freedom's picture
Last seen: 1 year 3 weeks ago
Thanks, HKG. The protected cell form factor (apparently) receives little love of late.
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
djozz
djozz's picture
This is not a protected cell, it has no electronics that prevent overcurrent or overcharge/-discharge. The PTC is a one-time fuse that will blow in case of a direct short, all li-ion cells from major brands have that.
DavidEF
DavidEF's picture
Last seen: 1 day 23 hours ago
I’m looking forward to this 14500 coming on the market. Thanks Vapcell!
- The YKK Philosophy
d_t_a
Last seen: 1 min 37 sec ago
Interested.
But the Vapcell AliExpress store doesn’t seem to ship to my country, the Philippines.
Is there some way to have it shipped in a reasonable price?
HKJ
HKJ's picture
We have sent a few weeks ago, HKJ probably almost received the sanyo NCR21700A battery. Smile
I got a parcel with batteries from your yesterday, I have not checked the contents yet.
Kepling
Last seen: 5 months 5 days ago
It is listed on the Vapcell aliexpress store now.
https://www.aliexpress.com/store/product/Vapcell-ICR14500-1000mah-3A
US $6.99 for a pair.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 min 49 sec ago
Items in my Cart, Currently not available to order?
KB1428 “Live Life WOT
djozz
djozz's picture
Dunno, just bought 4 of these, I have seen no availability messages.
Geuzzz
Geuzzz's picture
Last seen: 5 hours 59 min ago
Nice but it would be perfect if there were new 16340 cells. By far my most used cells.
Freedom
Freedom's picture
This can be 14500 battery with pcb. protection of current and voltage
But it will increase battery length.
(djozz) Thanks for the clarification.
(vapcell) Thanks for stating the obvious and the offer of making something happen if needed. I have never witnessed such hostility on this forum to the protected cell form factor. As folks are heaven forbid injured moving forward it will unfortunately be difficult to spotlight but not hard to explain.
KawiBoy1428
Glitching on my side there chief, 4 times, finally went thru, kept faulting out going into PayPal, kicking me back to the website? Angry
Barkuti
Barkuti's picture
Last seen: 11 hours 15 min ago
Thanks for endorsing progress here Dennis. Me and others would also have liked a higher drain cell, but thanks anyway. The pricing is fair also. Thumbs Up
The only 14500s I bought more than a couple years ago are installed inside a li-ion converted hair clipper LoL! Big Smile
Cheers Smile
P.S.: will post this at ForoLinternas' Recommended batteries updated thread, deserved it is (link to mentioning post).
Sat, 11/10/2018 - 10:47; Sat, 11/10/2018 - 11:29
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
