Fireflies E07 preview
I don’t have any data on how is the weight split between the head and the rest, so I assumed that each gram of light affects turbo time the same regardless of where it’s placed. Yes, this is not really correct as I stated before, but I believe that it’s much better than guessing.
BTW, according to TK D4 can sustain ~600 lm, though it indeed falls way below that right after turbo.
I use the word Turbo not to denote the highest mode, but any mode that can’t be thermally sustained. I know this is ambiguous, but I don’t see a better word. :frowning:
So under my fingers “Turbo” can include middle modes of hot rods. But not low ones.
Not-sustainable modes are the only ones that benefit from higher mass. Their runtime is directly proportional to thermal capacity, which is often closely related to weight (though it doesn’t have to be). Sustainable ones just don’t benefit from that, unless we’re talking about totally marginal stuff like Vf change with temperature during the time before the host is thermally saturated.
I won’t comment on whether 20 minutes is a long use for most users. I don’t know.
Yes, I think we just agree about that part.
Frankly, I don’t think there’s another light in this class yet. And I listed throwers larger than C8. That’s really not comparable.
Is a 40g increase “hardly noticeable” really? Let’s not talk 140 vd 180g, nobody will use this light w/out cell. It’s 210 vs. 250 grams. Now….is this “hardly noticeable”?
For me definitely not. I believe most would notice that easily. Would they care? I don’t know. I would.
I really don’t see how a D4 can sustain 600 lumens without active cooling. I just tested my D4 XP-L HI using my Texas_Ace lumen sphere calibrated with Maukka calibration lights and here are the results:
0s - 496 lm
4min - 256 lm
8min - 60 lm
12min - 31 lm
I’m not sure how Toykeeper calibrated her lumen measurement device but most lumen readings on BLF and manufacturer’s specs are much higher than ANSI certified lumens. Not sure if she got 600 lumen sustained under active cooling. I also did left it tail standing while waiting for the next measurement point instead of holding it throughout the test so it loses the heat sinking benefit from a human hand. The temperature of the light was pretty warm at each measurement interval. I doubt with a human hand holding it tightly will allow it to maintain anywhere near 600 lumens unless you set the allowable temperature to the max, which is not usable without gloves. Also these runtime measurements are normally conducted without a human hand holding the light. Almost everyone on BLF own a D4 so it can easily be confirmed. All you have to do is set the light to about 500 lumens calibrated with another light rated at 500 lumens (if you don’t have a measurement device) and leave it on the table. 10 minutes later, compare it with a 30 to 100 lumen flashlight and you will see how dim it is.
Regarding your concern about adding weight (210 vs 250 grams), I would say it would be pretty hard to tell which weighs heavier if you were given one light after another. Even if you were holding one in each hand, it is still not going to be immediately obvious. I just tested it comparing lights with similar differences. However, the performance advantage will be far more noticeable as I have described previously from my testing.
Of course it will step down… all the heat inside the tube will cause the light step down…
“Runnnnnnn! Gooooooo! Get to the Coppah!”
Guys … Another question about batteries …
I prefer a flat top batteries.
Do you think it would be a problem for FireFlaes E07?
A copper version of that thing will likely cost in the thousands. Also copper is relatively soft so not sure if it’s good for deep fins although those fins appear pretty thick. But that would be a super sweet light. Can probably handle any realistic output levels until batteries run out. You will need to do some dumbbell training to build up some biceps before you can handle that light though.
I have a tr j20 with the sst40 dedome… i break the lense… lol… anyone know where i can buy a replacement lense ??
I don’t own one. Was this a VN light? Is it using the stock driver or modified? How many lumens does it make?
It was modded by one blf member… i believe FET driver… i will measure lumen tonight.
Not that exact tr20 thingy— that looks like a ginormous 26650 thrower. But borrow some of the millwork concept, thin fins 1/16(1.6mm) or so thick, spaced the same on a ~1.5+ inch head they couldnt be very deep maybe 3/16”, or so. Yeah, and do it in copper. There was an astrolux i remember seeing a few years back— sc ? Maybe a bit like that form factor wise but slightly deeper on the fin milling. But narrow 1/16” fins and spacing. This, as opposed to the e07 cad drawing with 3 fins at approx 3/16 - 1/4” thick.
I dont find that copper unless annealed is softer than say 6xxx alloy aluminum. But it is pretty close. I handrout alot of aluminum and even the 6xxx series alloys ‘melt’ and gum up the bits unless you use a s#!tload of wax. I cant say that brass or copper do the same, mainly because theyre harder or perhaps denser, the harder non-ferrous materials seem to cut better for some reason, i dont know exactly why—my guess is that the softer it is the more a cutter will grab and pull on clearance of chip versus, slicing or chopping a chunk of chip and eject it, call it just some kind of practical jnstinct. For instance the 3xxx series aluminum (almost pure) just cant be milled by hand because it is so soft it clogs up cutters instantly. The cncs we use have a helluva time with anything other than 6061 because the mg makes it harder. 3xxx (pure/soft) even with tons of lube just makes it look like a plasma cutter did it.
Anyway, moot point. Probably too expensive like you say.
But it would be a pretty sweet light.
No it wasn’t a VN light, it was reasonably priced and worked well, search Chunky Monkey on BLF
Did you see that research about how a Sharpie changed the surface sufficiently to significantly improve machinability?
[/quote]
I think youre having a bit of fun at my expense.
I have heard that you can use a sharpie to aid in a flipper knife lockup, it acts similar to graphite powder in that case—so for very small scale application maybe. As for milling i have not heard of this, but i dont do this for a living, and i am not a machinist. I kind of do multiple trades and have access to some neat machines. I used to fabricate large architectural aluminum signs. Basically large shaped boxes. We cnc’d mainly sheet stock. Now, I have a neighbor near my current shop who has a 5 axis milling machine who cuts aluminum billets, big honking chunks to make hotrod clutch parts for racing motorbikes—he wont do anything but his parts, which sucks cause i asked. In either case, the milling machines either use a spray lubricant that constantly coats the cutter at point of cut, or in the 5 axis gadget i think it just constantly pours a shower over stock and recirculates back onto the stock. I cannot imagine how a sharpie would be practical for an industrial application of this type and scale, it cant be composed of more than alcohol, a dye and maybe a binder.
Nonetheless, when we’re routing aluminum by hand it is preferable to work in the 6061/6xxx/5xxx alloys. The magnesium/ silicon content stiffens it enough so it doesnt melt as much. When in doubt you can use cutting oil or we prefer a cutting wax. But it is a pain to use the wax or oil because its a pain to clean it up—and can fisheye paint if not prepared properly.
Thw whole point was in my opinion copper strikes me as an outstanding material to make a flashlight head out of. it is a better conductor of heat, it machines up nicely—the caveat was whether it was too soft for skinny fins. I dont know. I was adding my 2 cents because it was my opinion that it would do as well or better than aluminum. I suspect they may even cast the aluminum then machine it, which seems like a production advantage
[edit: cast and milled= production advantage but cast seems likely to be more brittle].
compared to titanium or steel it is considerably softer, but i think versus aluminum copper might be slightly harder on a rockwell hardness test. But this is an opinion and based on material i have personally handled and worked with. There are multitudes of alloys of both these base metals. So it seems slightly subjective—without actual data, and specificity.
But skv89 was right about cost. I think from a production standpoint aluminum is going to be king. Copper is for one offs and small expensive batches. Which makes me sad. Because if the e07 was done with a fat copper head i would never have to buy another flashlight.
Ha.
Not at all. It’s not practical for production, but it might give ideas on how problems with difficult materials can be fixed.
You’re probably thinking about the BLF X6 / Astrolux SS. The fins are very shallow though. That thing is a beauty and a true heavy weight. I actually have both the BLF X6 and Astrolux SS. Without batteries, the X6 weighs 371.4g. Just the copper pill without the top bezzel already weighs 196.6g. The massive copper pill allows it to handle turbo like a champ. I just took some measurements out of curiousity:
1s: 1,271 lm
30s: 1,254 lm
60s: 1,250 lm
90s: 1,241 lm
120s: 1,232 lm
At 2 min., the copper is warm but the stainless steel remains cool, which is unfortunate. SS has very poor heat conductivity so the heat is almost entirely absorbed by the copper pill and due to the limited surface area of the pill to radiate heat, it takes a long time for it to cool. If the SS parts were aluminum, they can be used for heat shedding and performance should be much better.
If FF decides to make a copper head version of E07 with aluminum body, I will definitely buy it. Should be a solid performer for long steady turbos or any output levels for that matter.
Yup. Thats the one. Almost pulled the trigger on that one but didnt.
Frankly, i dont care about weight unless it is on my keychain. Size matters for this—for me, weight is hardly a concern. Lets put it this way if weight is the tradeoff for extended runtimes then it seems like a nobrainer to me, all things considered highpowered led flashlights are still in their infancy if we cant run a torch on high power for more than a minute. We—flashlight consumers/addicts have grown to accept this anomolous reality, because its all we have known. I submit that runtime trumps weight for this particular unit. i dont really want to go with the zebralight 700/21700 offering so i hope this conversation gets heard by ff. They could make something truly special.
And i will still end up getting the zebralight 700 thingy if Just to keep my new 21700s warm.
Fair enough.
I suspect it is like a carpenters pencil trick to cure a squeaky hinge. Rub a pencil over a hinge and it will stop squeeking—on the fly graphite lubricant, it may not be the best thing for the job but will work in a pinch. There are alot of really smart guys who work machines and make things who when short on engineer approved process and materials can macguyver their way thru a problem. (Anderson, not the new guy). I would venture a guess this sharpie trick is just this sort of thing.
I’ll have to look it up again, but iirc, it helps the formation of a chip by holding the top of the material together enough so that it’s not permitted to gum up and much form a chip instead. Scotch tape had the same effect.
I want the 7 emitter 26650 light please with copper head option lanyard hole and magnetic tail with ramping UI. shorty tube also 26350.
That was a really nice item. It’s also the reason why Bistro’s thermal code doesn’t work on smaller lights — it was designed and calibrated for something with a big solid heat sink, so it responds too slowly on lights with a higher power-to-mass ratio. To put it another way, the massive heat sink made it so the thermal algorithm could be pretty bad and still work. But smaller lights require a smarter algorithm.
I must admit I don’t really use my X5 or X6 any more, because both were kind of obsoleted by the Emisar D1 / D1S. But they’re still very nice, and I keep mine out on display with their nice wooden case along with the other items I helped make. It’s kind of nice having a physical remnant of projects past, something to look at as a reminder.
Weight definitely matters though. Carrying the steel/copper X6 was like carrying a brick. It’s very pretty, and performs well, but if I wanted to actually carry one around I used the aluminum version instead. Even if I had it in my purse, with the steel version, it would make my shoulder sore after a while. Granted, I have all sorts of other toys in there too; there’s a reason they call me ToyKeeper. But still, the weight was a big drawback for practical purposes.
Understood. However, this seems to support what skv89 has been proposing about mass. Plus, more fins, plus copper. He suggested 40g of extra mass. There was some discussion about whether this would have any effect. Based on what you have observed it seems that it does have quantifiable effect on runtime. In addition, pairing a beefier aluminum head or as i have proposed—copper. I think the original impetus for me to engage was that the e07 fins seem a bit ill suited. Many of the original comments were “thats a lot of light in a small package”. The astrolux came up because i had a vague memory of a copper head with many thin fins. I think a stainless battery compartment isnt appropriate. Throw a weightier multi finned head on an aluminum body i think is where my vote would go. Kind of a bridge between ideas, not a full on copy of the astrolux or trj20.
But honestly we’re all just fussing on about things that are probably just dreamy kids stuff. Fireflies asked what this community thought and i want awesome to happen—it seems to me theyre on pace for awesome. It seems to me like there is some growing enthusiasm for this fledgling little outfit.
And just imagine a big heatsink with an efficient driver/firmware thingy—which is to say thermal algorithm. Wow.
