Latest release Vapcell 21700 5600mah 12.5A battery
Link to your website?
It is not listed yet.
https://vapcell.aliexpress.com/store/1084158
Thanks, HKG. The protected cell form factor (apparently) receives little love of late.
This is not a protected cell, it has no electronics that prevent overcurrent or overcharge/-discharge. The PTC is a one-time fuse that will blow in case of a direct short, all li-ion cells from major brands have that.
I’m looking forward to this 14500 coming on the market. Thanks Vapcell!
Interested.
But the Vapcell AliExpress store doesn’t seem to ship to my country, the Philippines.
Is there some way to have it shipped in a reasonable price?
I got a parcel with batteries from your yesterday, I have not checked the contents yet.
It is listed on the Vapcell aliexpress store now.
https://www.aliexpress.com/store/product/Vapcell-ICR14500-1000mah-3A
US $6.99 for a pair.
Items in my Cart, Currently not available to order?
Dunno, just bought 4 of these, I have seen no availability messages.
Nice but it would be perfect if there were new 16340 cells. By far my most used cells.
(djozz) Thanks for the clarification.
(vapcell) Thanks for stating the obvious and the offer of making something happen if needed. I have never witnessed such hostility on this forum to the protected cell form factor. As folks are heaven forbid injured moving forward it will unfortunately be difficult to spotlight but not hard to explain.
Glitching on my side there chief, 4 times, finally went thru, kept faulting out going into PayPal, kicking me back to the website? :rage:
Thanks for endorsing progress here Dennis. Me and others would also have liked a higher drain cell, but thanks anyway. The pricing is fair also. :THUMBS-UP:
The only 14500s I bought more than a couple years ago are installed inside a li-ion converted hair clipper LoL! :-D
Cheers :-)
P.S.: will post this at ForoLinternas' Recommended batteries updated thread, deserved it is (link to mentioning post).
Sat, 11/10/2018 - 10:47; Sat, 11/10/2018 - 11:29
I don’t know how big the 16340 market is, but I was just buying new batteries and there was not much to choose from. So I’d appreciate if there were some (new) good 16340 cells.
+1 here for the 16340s development!
I have now more 16340 flashlights that need high drain cells for them, so I will be looking for some more news about it Dennis! And when I get back to market to buy cells, your store will be on my radar for sure! Nice to have cell manufacturers/sellers on BLF :wink:
Here are a few lights that use a 16340, they are several more that’s still not in that list.
A lot of newer lights are pushing the current limits on most 16340’s, we have no true 16340 high current cell. What is needed is a high capacity cell that can deliver around 2 amps at 800 to 1000 mah and a high current cell (INR16340) that can deliver around 5 amps or more at 600 mah or so.
Basically, just take the Aspire (Vapecell) INR18350 1100 mah cell and shrink it down into the 16340 size. You’ll have a best seller on your hands. :+1:
Why so low specifications? ;-) Dream on!
The TrustFire IMR16340 650mAh (red-gold) is one of the current references:
I've seen that wide tri-lobe/leg top in some other rewrapped 18650s, BlueSwordM said me here chinese OEM BAK was making them (the 18650s).
With more than 40% innards volume versus 18650s I think aiming for well above 1000mAh and mid to high discharge rate is doable.
E-Moli One Energy Corp (Molicel) may be a nice choice to aim for developing newer small cells, they make really good cells. Check this Mooch Poll: What is most important to you in a new battery? @ E-CigaretteForum
Cheers ^:)
I think the problem for 16430 is that other than flashlight enthusiasts, the market for high-drain cells is fairly small.
18650s have a whole host of high-volume applications. 21700 get volume from the EV market.
The 18350 doesn’t have the same sorts of volumes, but it did get enough of a boost from the vape market to make a good step forward.
Maybe someone needs to promote a small vape device that depends on the 16430. Maybe something you can stick in your nostril and leave there, or your ear!
Those are my favorite 16340 cells for high current lights. Even though the graph looks good at 3 amp discharge when you apply that to a flashlight, it’s still under performs. Voltage sag creeps up really quick on these cells even though they are the best 16340 cell for high currents.
From my testing at a 3 amp load the cell is at about 3.5v within seconds of applying the load, then in about 20 to 30 seconds after that its at 3.4v or so. At 3.4v it holds fairly well, dropping voltage gradually for several minutes until it gets to 3.0v. I got a little over 500 mah in 10 1/2 minutes with a 3 amp load at a cut off of 3.0v. Not really what I would call a great cell but it is currently about the best 16340 cell around for now.
