Dunno maybe it wouldn’t. But the stock driver is very thick. And I have a similar construction by CRX in a Thrunite host, so that was an obvious inspiration. 3s 10160 is an option too.
White Flat would need a SMO reflector to really perfofm. And bezel is quite thick. Though low Vf is interesting. Anyway, not for me, I want a pee light, ideally with 1000+ lm.
Just received two Copper P60 Quad shells. Excellent quality as always, awaiting parts to build with.
Yeah, dunno if I mentioned this when I got ’em, but the pills for S2+ triples came in perfectly, nice sturdy box to hold everything, and shiny! :laughing:
Just received my S2+ copper pills. Thanks!
Hi Kirill, do you offer Convoy C8/C8+ retaining rings?
Im sorry I cant find C8 pill ATM.
Does C8 rings interchangable with S2+?
Have you started a batch of copper S2+ full triple pills yet?
Sorry, dont see it reasonable since Hoop’s pills will be available soon.
Do you have a link to Hoop’s pills please?
Thank you kind sir.
Received a large order from Kiriba-RU. Everything looks good as usual. :+1:
I just, quite accidentally found out about the existence of “C8TT”. This is very, very cool!!
Do you have more details about this? It looks really nice, but i don’t see how to use it
Im building big belt grinder. It took very long time, same time Ive made a batch of parts that allow use angle grinder as belt grinder. I could not wait longer to try 3M green belt in some difficult job so I temporary set my battery powered angle grinder as belt grinder and tried to sand flat C8’s stainless bezel. Tiny machine dont work as good as big one but anyway it didnt take much time.
Regular SS C8 bezel sanded flat with some laser engraving. How to use it? Probably will make another one for special C8TT set for 2k post GAW.
I’d be in for a flat one
Looks nice Kirill !
I have done it myself some time ago…
Does anyone make a more narrow optic that fits your heat sink head?
This one is a bit too floody for me. I would like to mimic the beam profile on the stock convoy C8 with an orange peel reflector.
Thanks
If you are searching plug and play decision - no, noone.
I think blf members have build several thousands of lights using cute-3 optics. Somebody used to sand optics top flat and polish it clear.
Another optics (angie-s) do exist but:
- Im not sure it will give more throw
- It have different diameter and height
- the only place where you can pcb for angie is led4power.com. If you want to try you can ask Neven about suitable hosts and parts…
