Fireflies E07 preview
More mass, slower temperature change. So it takes longer to overheat, but it also takes longer to cool down. It doesn’t really increase the maximum sustainable brightness.
The algorithm in Bistro is really slow and makes small adjustments, which is how things should work with a relatively large heat sink. The algorithm in RampingIOS V2 is faster and makes much larger adjustments, because it has a much smaller heat sink. And the algorithm in Anduril / RampingIOS V3 does both, adjusting the speed and magnitude of its response to match the hardware.
If I understand correctly, the E07 is designed to use Anduril. So it should work with a large or small heat sink. The sustainable level depends mostly on the light’s environment, like whether it has a hand or moving air to wick away heat.
As a side note, I’m tempted to put in a factory reset / auto-calibrate function. Like, hold the button, screw on the battery tube, continue to hold the button for 5 seconds, and then it’ll reset everything to defaults and calibrate itself based on the assumption that it is currently at room temperature. And, by “room temperature”, I mean … um, maybe 22 C? Not sure how warm everyone’s rooms are, but I think that’s generally considered average.
“Mere 10,000 lumens”??? How many lumens were you outputting?
Personally I’m not a big fan of titanium unless it’s for AA/14500 lights because as you said, it is basically a thermal insulator. But at least TI is better than SS, which has poor conductivity and heavy. Copper combined with aluminum seems to be the best in terms of price and performance.
Any idea why they couldn’t retain the deeper fins in the final X6 and X5?
Yep that’s exactly what I’ve observed from playing with all my lights. Still to me that is very desirable because we can’t expect to sustain output anywhere near turbo, we can at least extend those high output blasts to more usable durations without rapid dimming.
Good news is FF responded and said the Final E07 sample will have shelf thickened to a whopping 8mm which should help increase heat transfer rate to exterior wall surfaces, weigh about 180g instead of the measly 138g, and deepened fins for better heat management! So it will have both increased mass and surface area! :laughing:
Considering this is a bit smaller than the D4S, the E07 will be a beast of a small light. With 7 emitters and high current 21700, E07 should have more output, higher efficiency, and potentially longer, more steady brightness at high output levels. Both the D4S and E07 with batteries loaded will weigh about the same so shouldn’t be a weight concern to anyone. Good job FF! :+1:
Nicely done.
What was the shelf thickness before? Will this increase the exterior length?
Not sure what it was before but 8mm is 0.315”, which is pretty freaking thick for a light of this size. We will get more info when the final sample/prototype is done.
Some thoughts about the E07’s proposed 7x CREE XPL HI V3 NW 5000K emitters:
My Fireflies ROT 66 has 9x of those same emitters. The ROT 66 is hyper-bright, floody, has some throw, but not much. The E07 would likely be similar. The ROT 66 has three 18650 batteries (9-10,000Mah total), this will have one 21700 (4-5,000Mah). Anticipate shorter run time between battery charges. The E07’s small size and mass means it will probably heat up and step down quickly. The E07’s small size will be nice - even with a 21700 it will still be an EDC for most of us.
Among it’s competitors is going to be the Emisar D4S. The D4S has a 26650 battery (5-6,000Mah) and four emitters. My D4S has CREE XPL HI V2 NW 5000K. The EO7 should be brighter - though the D4S is extremely bright. The E07 will be not as stocky as the D4S; some find the D4S to be an EDC, others don’t. The E07 run times will be shorter than the D4S. The E07 will likely heat up quicker. The E07 probably won’t the throw distance of the D4S.
I like the proposed emitter choices of the E07 and the availability of the Champagne color.
I like where they’re going with this… :slight_smile:
SKV89, Richard (RMM) built an TR-J20 with XHP-50.2’s I believe, also added a slave driver. It made 39,000 lumens and got too hot to hold within seconds. I made a heat sink to tie in the excellent finnage and he said it would then run til the cells died, it got hot, yes, but was dispersing it faster than than the cells could hold up. I had also made him an extension that was finned to match, for a 4th cell in that big light. 4 32650’s in series. :wink:
My own is still running 3 32650’s and has 4 of the 9V MTG2 emitters. It’s making a lot less than Richards, but a lot more than 10,000 lumens. :slight_smile: Same heat sink. (made the same of course) I also added a 1/4” thick spacer up top to accommodate the reflectors.
Edit: Rested and at 4V it makes 11,612 lumens. Edit II: 12,976 with the cells fresh charged and at start. Mind you, the cells and emitters are going on 3 years old.
Enough shelf under the emitters to conduct heat to well placed and well spaced fins, and it works. Kudo’s to Fireflies for paying attention! :slight_smile:
Very good news but I hope this will not end up with a head much larger than the front SS bezel. It’s the only thing that I don’t like with the ROT66 : protruding fins, even if i prefer this to no fins at all.
Omg I’m in this thing is getting better all the time.
TallyHo I have four ROT66 myself. I think those fins are small all things considered. They barely stick out if you stare down at it from the muzzle, er bezel :slight_smile: end.
Yeah I agree the Cooling Fins help tremendously with heat management so the bigger the better IMO. Some awesome fins in this thread. This one needs some character to set it apart from a ROT66, which I already admire.
I’m wondering about the “deeper fins”… I’ve been studying the design and I’m really liking how the switch area is raised above the head, the head has a slight bevel cut to it such that as it gets closer to the tube it’s narrower but the switch area stays proud, makes it easy to locate the switch in the dark if you have the switch lights turned off. (I don’t normally leave this lights on, too many lights to have all of them shining around saying “Pick me! Take me with you!”
So I hope they keep this switch-area-proud design. The tapered head as well, it’s just a unique look that sets it apart from others.
I also personally think it would be awesome if they could change the cut-out’s on the clip… make it read FF E07 to identify the light. :slight_smile:
That is insane. Are you saying, with your heat sink, it was able to sustain 39,000 lumens!? Holy cow! :open_mouth: Was the heatsink aluminum like the one in your photo or copper? I didn’t think sustaining anything over 15k lumens even in the largest lights was possible without active cooling.
Any idea when we might see some updated renders?
Hey skv89, i tested my trj20 sst40 dedome. It make 5900 lumen.
“Sustain” is perceptual here, cells die fast when you’re pulling a high C discharge rate, if you have enough dispersion to outlast the cells then… the difference was that the light couldn’t be run 20-30 seconds before it had to be shut down, with the sink it would drain the cells. It’s not as much the sink at work as it is the factory cooling fins actually getting the heat (through the sink) to disperse it. :wink: Without the sink, the lower head where all the fins are only touches the underside of the emitter shelf with about 1/8” wide band of almuminum where the threads are, totally insufficient to pull the heat down into the deep fins. The sink remedied this, giving enough surface contact at the emitter shelf and enough mass to redirect heat to those fins.
I think this is what you’re looking for. That’s the best finning I’ve seen for a light of that size and it’s actually done in copper.
Dont forget our own member’s creation, C8TT:
That C8TT is nice too. I have it and it looks better in person.
Wow!! What is this treasure called? Where is it for sale?
