CRX Rotary - 6th Annual BLF/ Old Lumens Contest Winner
149 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 4 months 1 week ago
Amazing.. Shocked
Not clear to me what the purposes of the parts are though, but it’s clear you have a well thought out plan. Thumbs Up
CRX
CRX's picture
Last seen: 2 weeks 3 days ago
Thanks mate Beer
There are still some components to go into it, but I ran out of solder paste, hopefully that will arrive within the next few days.
MRsDNF
MRsDNF's picture
Last seen: 13 hours 11 min ago
That is a work of art in miniaturisation. I have no idea how you do work like that. Thumbs Up
MtnDon
MtnDon's picture
Last seen: 30 min 4 sec ago
Incredible stuff! Makes me wonder why I bother. Wink
Jerommel
Jerommel's picture
^ Exactly…
MRsDNF
MRsDNF's picture
To impress us mere mortals with amazing wood working skills. Love
vwpieces
vwpieces's picture
Last seen: 1 week 6 days ago
awesome as usual.
I missed the BooBoo pic Big Smile
Cant believe its contest time already, Another year passed too fast
FmC
FmC's picture
Last seen: 4 months 4 weeks ago
That switch work alone is just crazy… Shocked
By now, you surely have copper, brass, & lead poisoning at the least…. Silly
CRX
CRX's picture
Quite possible, might explain a few things..  Big Smile
Redesigned rotary switch contact board.
So, after thinking about the contact board further I realized it had a design flaw so I made a new board Facepalm
The contact points should have minimal space between them to minimize LED flashing effect when changing modes.
Start again, I cut out & drilled a board from the FR4 same as before.
The red circle shows where the sprung brass contact corresponds.
This time I decided to make a small wedged shaped copper piece to help me mark out the contact points on the board, the little hook catches in the centre hole.
Works like this.
Holding the copper marker in place I score the kapton tape with a scalpel blade, move it to the next section leaving a thin gap and repeat then take out the unwanted trace lines and place the board in the ferric chloride solution again.
After a few minutes the board is removed from the solution, cleaned and the remaining kapton removed.
This is a far superior design to the original, I think  Wink
Soldered the contact enclosure posts in place and filed down, sanded & polished the brass centre bolt.
Soldered the brass bolt in place using the M4 nut tightened on the other side to keep it straight then soldered on a 10mm x 8mm x 2mm neodymium ring magnet which fits around the head of the bolt, this will be the negative cell contact.
Anti-surge 1% tolerance resistors soldered onto contact board and holes drilled for vias.
The resistor values are: 1R, 3R3, 15R, 180R, 820R to give five main modes, there will also be another direct drive connection which will double as the neutral charging unit connection.
First test of the rotary switch Smile Thumbs Up
The switch can start from the highest mode or lowest depending on which way it is turned.
MtnDon
MtnDon's picture
Way cool!!!! Thumbs Up Smile Big Smile Beer
Flashy Mike
Flashy Mike's picture
Last seen: 2 days 3 hours ago
I love this rotary switch! I guess the contact rods are round enough to not connect 2 pads at the same time?
CRX
CRX's picture
It’s just one contact rod, the other is only there to balance, has a piece of plastic on the end of the spring.
I did round the end of the brass post slightly but don’t think it matters as the least resistive path will be taken, I’m sure both pads are connected momentarily during rotation, this was partly the reason for remaking the board with larger pads/ minimal gaps, the transition is a lot smoother although doesn’t show that well in the gif.
Still some tweaking to be done on it too but it’s working pretty well as intended.
Flashy Mike
You are right, with the given steps from resistor to resistor you probably won’t even see when 2 of them are connected at the same time.
CRX
CRX's picture
I’ll make a better video when it’s more together.
gchart
gchart's picture
Last seen: 6 hours 13 min ago
That is super slick CRX! Very nice.
MRsDNF
MRsDNF's picture
Maybe I’ll have to join in on MtnDon’s earlier comment. Thumbs Up
FmC
FmC's picture
Yep, just as I suspected. Definate poisioning… Sick
Thumbs Up Beer
DavidEF
DavidEF's picture
Last seen: 3 days 18 hours ago
CRX never ceases to amaze! Shocked
I would call the contest yours just for that switch. Party
- The YKK Philosophy
Coppet
Coppet's picture
Last seen: 4 days 9 hours ago
Very good idea as always and a perfect implementation, I always wonder where you get these many and unbelievably good ideas from. But what comes to my mind right now, a Novatac Rotary, a HDS Rotary Killer Wink Big Smile
CRX
CRX's picture
Wink
Magnetic pill contact board & wiring.
I decided to use some copper dual sided 1.5mm thick FR4 board here for the pill contact plate.
Marked out, cut the board with snips, filed and smoothed the edges with sharpening stones until made good into a circle.
This disc fits nicely into the brass ring of the pill but protrudes enough to keep the top copper layer clear of contact.
Marked centre circle in pill contact board, drilled a 1.5mm hole and removed some copper from the reverse side to avoid electrical shorts.
20 AWG silicone positive wire end stripped and put through board hole, this will be soldered to the side of the positive contact magnet.
Showing how the pill goes together.
Three 2mm diameter holes drilled in the pill for wires, the negative wire will come out through the side of the pill and be soldered there.
Soldering of a 6mm x 2mm neodymium magnet onto board next to wire for positive contact point.
I used more magnets stacked on the board to keep the ones on front in place and take away some heat as too much heat will demagnetize the delicate rare earth magnets, you got to be quick soldering these!
Wires poked through pill holes, contact board JB welded in place, 20 AWG negative soldered to pill and unit cleaned up.
JB weld applied around positive contact magnet and test Thumbs Up
MtnDon
MtnDon's picture
INCREDIBLE!!!!!!!*
jon_slider
jon_slider's picture
Last seen: 3 hours 12 min ago
Coppet wrote:
a Novatac Rotary
Brilliant!;-)
reminds me of an HDS.. except they dont come in copper (they only come in Bronze or Brass) LOL
Geuzzz
Geuzzz's picture
Last seen: 2 hours 44 min ago
Just awesome.
DavidEF
DavidEF's picture
Okay, I have to admit I’m lost have been for a while. I have absolute faith that CRX knows what he’s doing. But I sure don’t! Facepalm
ChibiM
ChibiM's picture
Last seen: 6 hours 34 min ago
MtnDon wrote:
INCREDIBLE!!!!!!!*
+2
pinkpanda3310
pinkpanda3310's picture
Last seen: 9 hours 12 min ago
Making your own multi mode rotary switch from scratch .!!! OMGShocked
You’re a true torch building professor Crown
MRsDNF
MRsDNF's picture
We both agree on something. Smile
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 14 hours 25 min ago
Very nice job Thumbs Up
CRX
CRX's picture
Interlocking copper core sections.
Previously made to fit inner core copper tubes.
I cut a 33mm section off the outer core tube and filed ends flat, then cut a 16mm section.
Cut a 25mm section off the inner core tube and marked out slot positions on the ends of both sections.
Cut slots into both ends.
Using the file then flat stones I smoothed off the end sections square...
To make two neatly interlocking inner core tube sections.
The idea being, with the rotary tail switch, the sections will not move when holding the light/ rotating the switch. Most of the inner & outer copper core pieces, exploded view.
Showing interlocking sections and head rubber o-ring placement. Inner body cores roughly put together. The tail end still requires to be shortened to fit the cell & rotary switch.
MtnDon
MtnDon's picture
Thumbs Up Beer
