3A is just like 3D, except about 250K colder. I like both, but I like 3D a little more. I’m pretty happy with 3A, 3D, or 4A.
Typically, the “A” and “D” tints are the ones which look best, and the choice of which one depends entirely on what color temperature you prefer. This chart shows where each tint bin is in the spectrum:
Can you let me know how it goes, I may follow your lead. The only reason I haven’t done so already was that I am wondering how it will go in the same pocket with credit cards.
I do wish there were a longer tailcap available. I just want it to be longer, but would happily accept additional functionality with a strong magnet and lanyard loop, maybe even a tripod mount.
Thanks for posting this. I looked a bit for a countersunk 1/16” magnet, not found yet. Why countersunk, or even a hole in the magnet at all? Were you able to find a single magnet, or did you end up buying a handful?
Looks like you used super glue for the attachment, guessing it is still holding up fine?
First time trying this glue. I wouldn’t call it a super glue. Sets in 30 minutes cures in 24 hours. Don’t stick your fingers together like super glue does.
A 1/16th inch disk would probably been enough. Was thinking the hole could be filled with epoxy or black JB weld. I still might. I have had better luck completely covering neo magnets in the past. They tend to chip off on the edges. They are brittle.
K&J Magnets is where I found these. I will probably order some more. I remember a coated version.
I don’t feel I need to glue the clip. It has not moved at all in the few days I have carried it.
This is still a work in progress. I also would like a way to attach a small 3” loop lanyard. It might work on the clip itself. Will update.
I love magnetic tailcaps. Ideally, I fit a small magnet within the tailspring, but some lights won’t allow that.
For securing magnets to the outside of tailcaps, I’ve had good luck with Loctite 5-minute Clear Epoxy. I scratch up the nickel coating of the magnet and the anodizing of the tailcap before installing.
I suggest N52 grade magnets, which are stronger than N42 grade.
My Zebralight SC5w weighs 90 grams (3.2 oz) with an AA Eneloop installed.
Amazingly, a 1/32” thick x 3/4” diameter N52 magnet holds the SC5w to even a painted vertical steel surface. My H51w has one too.
The D4 with a cell weighs about 120 grams, so I’d go with at least a 1/16” thick N52 just to be safe.
