Even if the campaign doesn’t make the goal, this whole process from concept onward has been a lot of fun for me. Everyone has been very supportive and kind. Thanks for that! :+1:
I think she was mostly just asking what the “dark patterns” were… But I certainly enjoyed watching the look on her face while she tried to figure out if she just accidentally got volunteered to help.
I would say it is missing something. I wont define it but I will try to describe it as I see it. However, maybe these are related to your other points in some deeper way that requires acronyms before or after your name.
Depending on your audience/content I think it also helps to have one or more of these:
Ok guys and gals… I would really like to see this effort go into production. As I stated, I have a beta unit. Hoop asked me to use it and to provide any feedback that I might have. We discussed top and bottom modes, mode counts, ramping, magnets, pocket clips and finish over the duration of use. I have carried this one pretty often to work over the last nearly 2 months. It has been dropped, it has been run hard and is no worse for the wear. I did not even melt it’s face off!
This just gets dropped in my jeans pocket with change, finger nail clippers and pens. It has survived very well. It now lives on my desk at work, gets lots of looks from flashlight newbies… when I turn it on high, the general question is OMG how is it so bright?
Post it on Instagram and hashtag all the flashlight sites. Start a FB group and point the instagram to that group. I sold 200 custom Ti-Lans in a month doing that.
With a fresh cell mode 5 at ~300 lumens starts to get pretty warm at 2 minutes if you aren’t touching it. If you use your “meatsink” and switch hands often it can be run continuously without getting to hot to hold, but almost does. If your hands are cold it’s no problem. Measured 258 lumens at 4 minutes, 235 at 7 minutes and getting cool. Stopped test. Mode 4 only ever gets warm.
The driver development has been an iterative process. Tiny13a-mmu is 3x3mm 10mlf package. The more capable mcu’s are 20QFN package which is 4x4mm and a tighter squeeze, but doable. I have Tiny25, etc. drivers just about ready for fabrication now and they may end up in the light, in which case it will gain thermal regulation. Tiny13a can do thermal regulation but requires an external thermistor, and the protection would be basic mode reduction rather than something more complex. This was the plan for rev2 of the driver but now I’m probably moving to the more capable mcus which have on chip temperature sensors.
A magnet will most likely end up in the production light.
Very cool Hoop, its incredible how small that driver is. Sounds like that mode level is pretty good too considering it it varies based on cell voltage. (320lm -> 235)
Im already sold because owning a “custom” light has been growing higher on my list, and what better than to support a KS by a BLF member. I just pledged in today.
What exactly does:
mean?
8+ cycles for a 30 second full turbo timer then it steps down?
