I ordered two of these to replace my aging(10+ years old) camping headlights. Needless to say the HO3’s are brighter on medium low tier setting than old lights on high, and with longer run time.
They are amazing for the money. I dropped Nichia 219C 4000k 90+ CRI LED’s into mine as for a headlamp especially i care about tint/CRI alot more than throw or total output. Turned out great.
Hello Chris , I’m not sure that I’m understanding what you mean by quickly double clicking to get to mode 2 , it sounds to me that you think you can set it to either mode 1 or mode two.
The way I understand how mine works is that it is very similar to zebra lights UI ,
Eg it has low ,medium ,high & turbo , & it has a sub setting on each which will be remembered ,in other words it has 4 settings with a choice of 2 outputs for each one.
Is this what you were saying or have I misunderstood ?
I still use mine, although not often. I use it for close up work in the house (with the head band), so the diffused beam is really a requirement. This is also the reason that I haven’t purchased another angle light with a regular reflector. No issues so far.
Issues, none so far. But it now has a LH351D 4000K and a Lexel driver running Anduril.
Hint: 16mm MCPCBs fit VERY snugly from the driver-side. Better sand them down to 15mm
The only thing I would also upgrade is the magnet. While it works, it doesn’t have “too much” like the Emisar D4
Any of you all have any issues with this light? I am looking to pick one up to use for caving wondered about durability and what you guys thought it long term
I’ve had the older Skilhunt H02 for several years now. I live in the US desert Southwest, and give four wheel drive tours of the desert East of Palm Springs. The H02 stays in my backpack full time, and gets bounced around a lot and is routinely exposed to over 100 degree (F) temperatures. It’s used one or two times a week during the winter, when we give “sunset” tours. No problems with this light. I just ordered one of the H03’s that Gearbest had on sale for 11 11.
While it’s probably not considered true caving, I also used the H02 in several talus caves when I went hiking at Pinnacles Natl Park two years ago.
I finally joined the H03 club yesterday. It looks like a good quality light with a nice UI.
Trying it on my head it’s a bit heavy though. OK for short tasks, but I wouldn’t want it on my head when I go out walking. I’ll stick to my Nitecore TIP or even some single AA light for that duty.
I suppose I could try the 18350 mod if I can figure out how to remove the original tube from the head.
I have been very pleased with my H03RC, first edition. I find it to be a well thought out headlamp.
My only gripe is that the documentation mentions only 2 indicators for charging — red (battery being charged) and blue (battery fully charged). Nothing else. But here is what I observe:
Red - battery being charged
Red/Blue rapid flash - no battery detected (not documented)
Blue - battery fully charged
Blue 5 sec/Red 2 sec - unknown, not documented
I noticed #4 with one of my 18650 batteries. When I tested the battery outside the flashlight, it shows 4.1v. However, when inside the H03RC and charging cable attached, I get the #4 status indicator. My other 18650 batteries inserted shows just steady blue. Does anyone here know what this status means (#4 above)? Does this indicate some kind of battery deficiency?
